Blue Mountain EFIS One Orientation
jeremy.p.harris(at)boeing
PostPosted: Mon Jan 30, 2006 6:09 am    Post subject: Blue Mountain EFIS One Orientation Reply with quote
All,
As someone pointed out in one of our photos of the Blue Mountain
Avionics EFIS one over the weekend, our unit is mounted differently than
the website recommends. Greg Richter's gang has a modification
available to install the BMA EFIS One CPU rotate 90 degrees so the
connectors point aft making install in the -10 much easier. Anyone out
there considering the BMA EFIS one should definitely consider having
them change the orientation of the CPU for you. This requires rotating
some of the accelerometers in the box and recalibrating. However, it's
well worth it when you're short on space like we are in the -10 panel.
http://jharris.net/Aviation/RV_10.htm
Jeremy P. Harris
Integrated Missile Defense
BMDS Architectures Lab
The Boeing Company
Washington, DC
Desk: (703) 414-6057 Dept: AV-2L-B27T
Cell: (703) 627-6500
Fax: (703) 414-6372
MC: 793C-G007
Office: 825B
Tdawson(at)avidyne.com
PostPosted: Mon Jan 30, 2006 7:18 am    Post subject: Blue Mountain EFIS One Orientation Reply with quote
Jeremy:
On your web site, your pre-oiler grounds your mags when on. Why's that?
Can't you have the pre-oiler on when running the engine? I guess I have
seen Infinity's web site mention a pressure switch that could turn the
pre-oiler on/off based on the oil pressure . . .
TDT
40025
noel(at)blueskyaviation.n
They should have done that years ago!
Noel
PostPosted: Mon Jan 30, 2006 8:44 am    Post subject: Blue Mountain EFIS One Orientation Reply with quote
The pre-oiler grounds the mags so that the engine can be turned over
with the starter while oiling without firing the engine. It keeps the
lazy pilot in the cockpit instead of going outside and hand propping the
engine to break up the cold oil.
Jeremy
Jeremy P. Harris
The Boeing Company
Washington, DC
Fax: (703) 414-6372
MC: 793C-G007
Office: 825B
rick.conti(at)boeing.com
PostPosted: Mon Jan 30, 2006 1:14 pm    Post subject: Blue Mountain EFIS One Orientation Reply with quote
This is the Lazy Pilot. There will also be a switch to engage the
preoiler without grounding the mags for use in flight should the oil
pump fail.
Thank You
Rick Conti
office: 703-414-6141
cell: 571-215-6134
