dlm46007(at)cox.net Guest
Posted: Tue Dec 12, 2006 11:52 am Post subject: AOPA rebate closeout |
If you have not filed for your AOPA fuel rebate you can do so online using you old logonid and password at https://www.bankofamerica.com/index.jsp. get your account on the screen and "view options" then "more options" then "features and benefits", then third line is the AOPA old rebate claim form.
apilot2(at)gmail.com Guest
Posted: Tue Dec 12, 2006 12:07 pm Post subject: AOPA rebate closeout |
Currently considering EAA Visa or Air BP cards as possible
replacements. Any other suggestions for rebates?
On 12/12/06, David McNeill <dlm46007(at)cox.net> wrote:
rleffler
Posted: Tue Dec 12, 2006 1:05 pm Post subject: AOPA rebate closeout |
I canceled my AOPA card and went with both the EAA and Air BP Card.
The only thing I don't like about the Air BP card is that they issue a check
for the rebate. I would much prefer just a credit to the account. Almost
all the avgas within 50 miles is BP, so this one works well for me.
The EAA Card is too new and hasn't had a bill yet. I figured that with the
amount of stuff I will most likely be purchasing from Aircraft Spruce, it
may worth having the account. Although, I haven't found anything that
specifies the exact amount of the rebate. Everything that I've found stated
"up to 10%". I went with the version that also gives a cash rebate. I
don't need any programs that just issue points.
_________________ Bob Leffler
N410BL - Phase I
coop85(at)bellsouth.net Guest
Posted: Tue Dec 12, 2006 4:17 pm Post subject: AOPA rebate closeout |
I'm thinking of staying with AOPA because even though the fuel rebate is
going away, my understanding is a rebate on ALL purchases, although at a
lesser rate.
Marcus
