vickiajones(at)hotmail.co Guest
Posted: Tue Dec 19, 2006 6:26 am Post subject: Lower Motor Mount Tube Clearance |
The clearance between the oil sump on my Mattituck TMXIO-540 D4A5 and the
lower mount
tube is 1/8". I have heard that Van's recommends a minimum of 3/16" but
prefers 1/2".
Has anyone had a 1/8" clearance but not had the modification completed by
Vans? If so, have you had any problems?
Vicki
Your Hotmail address already works to sign into Windows Live Messenger! Get
it now
coop85(at)bellsouth.net Guest
Posted: Tue Dec 19, 2006 7:10 pm Post subject: Lower Motor Mount Tube Clearance |
Vicki,
Mine was a little over 1/8" so I checked with Van's and they said it wouldn't be a problem. To date with 119 hours it hasn't been an issue. However you could always check with Vans again to see if they have any newer thoughts.
Marcus
