btucke73(at)yahoo.com Guest
Posted: Sat Dec 16, 2006 6:11 pm Post subject: Taildragger |
Carlos,
I tried e-mailing this to your address, but it returned. So here it is for all to read...
Carlos,
I recently finished my HDS taildragger. I did not, however, use
the standard bungee cord gear. I fabricated and installed an aluminum
spring gear. I don't believe that the main gear installation would be
any more difficult to install forward of the spard rather than aft.
Due to the curvature of the nose ribs and LE skin, this area is much
stronger than aft of the spar, and lends well to gear installation. The
tailwheel installation is pretty straightforward. Once you receive the
plans from ZAC, you will see that there are basically 2 4130 components
to fabricate / purchase from ZAC. I have a plasma cutter and welder,
so building the pieces was very easy, probably less than a day of
fabrication. If you did not read my post a couple of weeks ago regarding the
Matco tailwheel and leaf spring, look into the archives. The price is
right, and makes installation a snap.
I chose conventional gear because I fly tailwheel
aircraft comercially, and simply have an affinity for them. The
Zodiac behaves reasonably well, as far as taildraggers go, with the
rudder effective enough to handle significant crosswinds. My first high
speed taxis and short flights down the runway were in a 15 knot
crosswind, and while it was a bit squirley, it was not a problem. Make sure
that if you do not have a good amount of tailwheel time, you get some
under your belt before test flying your aircraft.
Bottom line - taildraggers just [quote][b]
carlossa52(at)gmail.com Guest
Posted: Sat Dec 16, 2006 8:24 pm Post subject: Taildragger |
Hi, Brandon
Obviously I can't type worth a rat's tail... My address is carlossa52(at)gmail.com (carlossa52(at)gmail.com) (not "51").
It seems that the actual construction of the TD option is not a problem.
What may end up being a show stopper is (1) insurance, given I have no TD time at this point and (2) getting TD time: the two airports within 30 min driving have no TDs for rental/instruction... Bummer
Thanks for your comments
Carlos
CH601-HD, plans
Assembling wings.
On 16/12/06, Brandon Tucker < btucke73(at)yahoo.com (btucke73(at)yahoo.com)> wrote:[quote]Carlos,
Carlos,
tailwheel installation is pretty straightforward...
ggower_99(at)yahoo.com Guest
Posted: Sun Dec 17, 2006 10:30 am Post subject: Taildragger |
Carlos... I think you have to learn to fly and forget about the "training wheel"
Our Instructor and local bush pilot, here owns only taildraggers (3) and when asked why taildraggers he answers with a question: "Are there other type?" jokeing of course.
Saludos
Gary Gower
Flying from Chapala, Mexico.
701 912S with training wheel.
Carlos Sa <carlossa52(at)gmail.com> wrote:[quote] Hi, Brandon
Carlos
CH601-HD, plans
Assembling wings.
Carlos,
spring gear. I don't believe that the main [quote][b]
dougsnash(at)yahoo.com Guest
Posted: Mon Dec 18, 2006 4:17 am Post subject: Taildragger |
Careful Carlos, taildraggers are addictive. I did my
Rec Permit in a Citabria 7ECA. It just feels right.
The C-152s that the school runs most of the time are
kind of boring to fly after the Citabria.
Unfortunately for you, I did/am doing my training at
Harv's Air in Steinbach, MB (Canada) which is about 25
miles SE of Winnipeg. That's a little far away from
Montreal. They have a total of four taildraggers for
training but only the two Citabrias are commonly used.
The other two are a Pitts and a Taylorcraft.
They do have on base living and rental houses in town
if you were interested in spending a week or two of
vacation time getting a tailwheel checkout. If you
are interested in more information, the website is
www.harvsair.com.
It's not a simple option for TD time but it is an
option.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
