chasb(at)satx.rr.com Guest
Posted: Sat Dec 16, 2006 10:29 am Post subject: Off topic - Battery Corrosion |
I recently fished out an old MagLite Flashlight. The D-cells in it
were dead, corroded and had spilled acid throughout most of the
inside of the flashlight. I managed to get the swollen batteries out
and cleaned up the threads in the base of the flashlight. But I can't
figure out an easy way to get the corrosion out of the inside of the
flashlight barrel.
Is there a acid counteracting fluid that will neutralize/remove the
corrosion? Any suggestions other than pitching the light?
Charlie Brame
RV-6A N11CB
San Antonio
kensmith(at)springnet1.co Guest
Posted: Sat Dec 16, 2006 1:00 pm Post subject: Off topic - Battery Corrosion |
Baking Soda!
Charles Brame wrote:
--> AeroElectric-List message posted by: Charles Brame <chasb(at)satx.rr.com> (chasb(at)satx.rr.com)
I recently fished out an old MagLite Flashlight. The D-cells in it were dead, corroded and had spilled acid throughout most of the inside of the flashlight. I managed to get the swollen batteries out and cleaned up the threads in the base of the flashlight. But I can't figure out an easy way to get the corrosion out of the inside of the flashlight barrel.
Is there a acid counteracting fluid that will neutralize/remove the corrosion? Any suggestions other than pitching the light?
Charlie Brame
RV-6A N11CB
San Antonio
retasker(at)optonline.net Guest
Posted: Sat Dec 16, 2006 1:46 pm Post subject: Off topic - Battery Corrosion |
Baking soda will definitely neutralize any remaining acid, but the
corrosion will probably have to be removed by hand.
Dick Tasker
kensmith(at)springnet1.com wrote:
| Quote: | *Baking Soda!*
> Charlie Brame
> RV-6A N11CB
> San Antonio
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Posted: Sat Dec 16, 2006 6:08 pm Post subject: Off topic - Battery Corrosion |
flashlight barrel.
Charlie Brame
RV-6A N11CB
San Antonio
If you kept the batteries & they are from a major maker, send them & the
flashlight to the battery company & get a free replacement.
nuckollsr(at)cox.net Guest
Posted: Sun Dec 17, 2006 7:05 am Post subject: Off topic - Battery Corrosion |
At 12:28 PM 12/16/2006 -0600, you wrote:
flashlight barrel.
Charlie Brame
RV-6A N11CB
Actually, the active ingredients in flashlight batteries
is more basic than acid (re: alkaline batteries . . . carbon
zinc were also alkaline).
Your chore is to find a solvent for the dried on remnants that
is not also antagonistic to the metal of the flashlight. I often
clean certain kinds of contamination off of parts using a dishwasher
but dish washing powder is exceedingly alkaline and attacks the finish
and base metal of aluminum.
I believe you're going to find that the labor to recover this
flashlight exceeds the value of the flashlight by several times
and after you get the contamination removed, you may have only
increased the damage to the flashlight.
< with experiment. >
< --Lawrence M. Krauss >
dsleepy47(at)hotmail.com Guest
Posted: Sun Dec 17, 2006 11:40 am Post subject: Off topic - Battery Corrosion |
| Quote: | Is there a acid counteracting fluid that will neutralize/remove the
Charlie Brame
RV-6A N11CB
San Antonio
Have you tried the Alumaprep and Alodine used on aircraft parts?
Deems H
N1491R
Express yourself with gadgets on Windows Live Spaces Try it! [quote][b]
