fderfler(at)gmail.com Guest
Posted: Sat Dec 16, 2006 4:46 am Post subject: The Puzzle of the Yellow Fuel |
Here is the mystery.
This is a brand new airplane. AMD-manufacturerd CH601XL with all new everything and 20 hours on the Hobbs. It has never been fed anything other than blue 100LL. The fuel samples from each wing tank are always blue and have never shown any water or strange stuff. But, the fuel samples from the Gasloator are always unmistakably Yellow. Oh, and the engine always roars sweetly.
Does anyone know definitively what's going on? My theory is that the brass/copper alloy gasolator, being new, is giving some color to the fuel sitting in it. (Yes, as I'm writing this I realize that I should check the sample color right after flying... thus the value of public confession. Although... I have pulled as many as 5 sample tubes of fuel from the Gasolator during pre-flight and they were all yellow.)
Has anyone else experienced the yellow tinge?
Frank Derfler N183AM
See my views and reviews at www.derfler.biz
See my information for pilots at www.flyinflorida.com
Posted: Sat Dec 16, 2006 6:32 am Post subject: The Puzzle of the Yellow Fuel |
the yellow may be water collecting in the gascolator. the engine will run because the screen will not allow the water to go to the engine. the little doohiccy is doing its job.
Juan
dredmoody(at)cox.net Guest
Posted: Sat Dec 16, 2006 6:48 am Post subject: The Puzzle of the Yellow Fuel |
Someone's probably peeing in your gascolator. The good news is apparently the engine loves it.
Sorry, I couldn't resist,
Ed
Do Not Archive nor Eat The Yellow Snow
jhstarn(at)verizon.net Guest
Posted: Sat Dec 16, 2006 10:59 am Post subject: The Puzzle of the Yellow Fuel |
I couldn't resist either.....
Ed, some may rate your humor as a ten others only as a 2 or 3
BUT "Your an 8".
Do Not Archive... KABONG 8*0
xl(at)prosody.org Guest
Posted: Sat Dec 16, 2006 2:45 pm Post subject: The Puzzle of the Yellow Fuel |
The fuel pulled from my gasolator was discolored for awhile after
I started flying 633Z. I didn't note when the yellow to dark yellow color
went away, I haven't seen it for 1++ years. I attributed the color to
leaching of the rubber fuel lines. Easy to test - put some fuel in a new
line, plug the ends, and check for color in a week or two.
If you don't have rubber lines check for other sources that could leach.
Joe E
N633Z (at) BFI
CH601XL, 412 hours
Jabiru 3300, Sensenich 64x49 wood prop
On Sat, 16 Dec 2006, Frank Derfler wrote:
Quote: | This is a brand new airplane. AMD-manufacturerd CH601XL with all new
sweetly.
.................snip
MElrod3732(at)aol.com Guest
Posted: Sun Dec 17, 2006 8:12 pm Post subject: The Puzzle of the Yellow Fuel |
I had the same problem after using the fuel line supplied by Zenith in my 701 I bought in October of 2003. I ended up replacing all the Zenith supplied fuel line with fuel line purchased at Auto Zone and have had no further problems with tinted (yellow) colored fuel.
I informed Zenith about the problem, returned the problem fuel line and they credited me the amount I paid for the new fuel line.
The tinting occurred with both Avgas & auto gas.
Hope this helps.
Mike Elrod
