		lsbrv7a(at)yahoo.com Guest
				 Posted: Mon Jan 30, 2006 7:27 pm    Post subject: Rudder questions |
				1.  I saw a very well done RV 7 this weekend with a trim wedge mounted on the side of the rudder.  Has anyone used an adjustable trim tab?   It would be easy to slip in while building the rudder.
   2.  Has anyone had experience with 3M polyurethane adhesive?  I am thinking about using it on the trailing edged assembly.
   Sherman Butler
   RV 7a Empennage
 Sherman Butler
 RV-7a Empennage
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		deruiteraircraftservices( Guest
				 Posted: Tue Jan 31, 2006 2:12 am    Post subject: Rudder questions |
				The proseal in the traling edge is only there to assist novice builders in
 the novice nuisance of double flush riveting. It can be build without
 proseal. There are 3M adhesives for aerospace use more commonly used in the
 composites structures. I'm not 100% about the numbers, but 3512 I think is
 the fast drying and 2266 the slow one. I is quite a few years that I used
 these adhesives. The slow one is in a Boeing material spec for the filler of
 the Rudder on the 737 Classic and 737X.
				 Posted: Tue Jan 31, 2006 4:26 am    Post subject: Rudder questions |
				Jim,
   Sounds like a craftsman.  Actually I was thinking about a ground adjustable trim tab.  On my Grumman the exposed edge of  0.16 was about 6" X 1.25" on the rudder and ailerons.
 sears(at)searnet.com wrote:
  	  | Quote: | 	 		   1. I saw a very well done RV 7 this weekend with a trim wedge mounted
 on the
  	  | Quote: | 	 		   side of the rudder. Has anyone used an adjustable trim tab? It would be
 easy to
  	  | Quote: | 	 		   slip in while building the rudder.
 A fellow I know has a trim tab mounted in the rudder of his RV-3 and will do
 it for his RV-7. May have already done it. If I remember, the horn for the
 tab is also hidden. He does very nice work. If you're close to Louisville,
 KY, he may show it to you.
 His name is Chuck Brietigam at brietigam(at)earthlink.net, if this address is
 still good. His workmanship is beautiful.
