jeff(at)westcottpress.com Guest
Posted: Tue Dec 19, 2006 11:30 am Post subject: Skin Edge Deburring |
I see some discussion today about edge deburring, and thought I'd
share a method I learned from another 10 builder (Nick Gautier) a
couple of miles from me. This technique has cut my edge deburring
time from 15-20 minutes per large skin down to 2-3 minutes and it is
unbelievably simple:
Take a curved tooth file (with the handle removed) and run it
lengthwise flat to the edge of the skin. On the return trip, run the
file lengthwise at a 45 degree angle to the top side of the edge and
make a final pass with the file lengthwise at a 45 degree angle to
the bottom side of the edge.
The result is an edge that is far smoother than anything I've been
able to accomplish with my double edge deburring tool... or any other
method I've fumbled around with.
Jeff Carpenter
40304
bpattonsoa(at)yahoo.com Guest
Posted: Tue Dec 19, 2006 3:56 pm Post subject: Skin Edge Deburring |
Yes, but always wear a leather glove. If you slip off the edge, the result is a nice long cut.
eagerlee
Posted: Wed Dec 20, 2006 11:49 am Post subject: Skin Edge Deburring |
The best advice on the deburring of edge of skins came to me from a seasoned vet. He took a 6" stainless steel machinist ruler used as a knife and passed over the edge at about a 45º angle. Two passes in each direction ( ten seconds max) and the edge was deburred and burnished to a smooth finish. I use it every time now.
Paul Hahn
