sarg314(at)comcast.net Guest
Posted: Sun Dec 17, 2006 3:02 pm Post subject: EGT on vetterman exhaust |
The VisionMicro EGT probes are supposed to be 3.5 - 4" from the exhaust
flange. The vetterman exhaust (for the O-360, anyway) on Cyl #1 and Cyl
#3 has the welded pin that locks the 2 pipe segments together positioned
right where you'd want to put the EGT probe. I can position the probe
too high (3" or less from the flange) or too low about 4.2" from
flange. The lower position has the clamp slip in just under the pin
bracket. The clamp is held captive by the bracket, but it straddles the
junction where the 2 pipes fit together.
Is there any argument for choosing the too hi or the too low position?
I assume the higher location will read a little hotter. It may not
matter. What have other vetterman users done?
Thansk,
Tom Sargent, RV-6A.
n616tb(at)btsapps.com Guest
Posted: Sun Dec 17, 2006 8:04 pm Post subject: EGT on vetterman exhaust |
Mine are under in the lower position and it works just fine.
[quote] --
Posted: Fri Dec 22, 2006 2:08 pm Post subject: EGT on vetterman exhaust |
I finally talked with Larry Vetterman about EGT probes. I think Larry's
the best expert we have on RV exhausts. He continues to do careful
experimentation with exhausts and speaks from experience.
Larry's advice is to place the EGT probes no more than 2.5" down from
the flange of the exhaust port of the cylinder. 1.5" to 2.0" is OK. He
has experimented with different positions. You will get more consistent
temperature readings this way, says Larry. Yes, the EGT probe won't
last as long as one mounted further down. It still lasts pretty long,
though. Larry's RV-4 has 1000hrs on its probes and they're still OK.
This fits with Dale Walter's note that his are 2" down and have 736 hrs
on them and work well. So, that is what I am going to do.
Note that the 2.5" is measured from the face of the cylinder, so it
includes the thickness of the gasket and the flange welded onto the end
of the pipe. It's really up there close to the cylinder.
Tom Sargent, RV-6A
