Nick(at)Scholtes1.com Guest
Posted: Wed Dec 20, 2006 8:16 am Post subject: Sealing NPT Threads against fuel |
Kurt,
I'm not a plumber either, but I live on a farm and we end up very often
becoming "jack of all trades" in some ways!
I had been trying to find a descent pipe sealant that would work with
fuel (gasoline or diesel) applications for years and years. Teflon tape
just simply does not work, it "melts" from the fuel and gums everything
up, it's terrible. I also tried a Locktite product that was supposed to
be OK with fuels, but I didn't think it worked very well either.
Anyway, about 10 years ago I found a product that absolutely,
positively, works absolutely perfect to seal NPT (tapered) pipe threads
against petroleum products. It is a thick black graphite paste. I buy
it at McMaster-Carr supply company. If you want to see it, go here:
http://www.mcmaster.com/ and search for this part number: 4586K8,
it's called "Key Graphite Paste".
We have overhead fuel tanks to fuel up the tractors and stuff, and there
are a bunch of joints on the tanks that connect the filter to the hose
to the valve, etc. We've been using this graphite paste on these NPT
fittings for 10 years and it really works, holds up in weather and
everything, lasts forever.
Best,
Nick
Time: 06:04:49 AM PST US
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Subject: Re: 912 Oil Leak - cracked fitting
I had to buy a new gascolator for this too. I could
only get 3 threads turned into mine with the pipe
fitting to hose coupling. Thought that wasn't enough
for security and to prevenbt leaks. I cut the threads
a bit deeper to get more turns in. Instead the
fitting hit the interior of the gascolator and split
it open.
I've been called a plumber, but....
I have been using teflon paste on the outer threads on
my plane's fittings instead of tape. Tried blue
colored auto store sealant first (ATV?) but had 7
leaks with it on the first try with fuel. So far this
has worked and no junk in the lines. But you must be
careful to only paste the last few threads.
A non-plumber's 2 cents worth.
Kurt S.
kitfoxmike
Posted: Wed Dec 20, 2006 8:40 am Post subject: Re: Sealing NPT Threads against fuel |
I went and resealed all my connections, at the tank, the fuel check at the bottom of the tanks, the header tank connections and used this. permatex high prefomance tread sealant, item# 56521. I did this about 1.5 years ago and about 400 hrs. The connections are still great with no leaks.
kitfoxmike
Posted: Fri Dec 22, 2006 8:15 pm Post subject: Sealing NPT Threads against fuel |
Thanks Nick,
And just in case, I have been a good boy (mostly) this
year Nick.
Merry Christmas to you all too.
I'll add that reference to my KF info. Next year when
I retire (Mar 10) I intend to redue my fuel system on
my Fox as well as many other upgrades and will try
your graphite paste.
Kurt S. S-5
--- Nick Scholtes <Nick(at)Scholtes1.com> wrote:
| Quote: | Kurt,
absolutely,
see it, go here:
number: 4586K8, it's called "Key Graphite Paste".
filter to the hose
paste on these NPT
in weather and
Best,
Nick
