echristley(at)nc.rr.com Guest
Posted: Fri Dec 22, 2006 3:32 pm Post subject: Some experiments fail |
Some ideas look good, until you try to implement them. Like using the
pitot tube for an antennae. It's worth a shot, right? There's even
some documentation of the technique at
http://contrails.free.fr/instruments_ant_sonex.php
Pictures of my attempt are at
http://ernest.isa-geek.org/Delta/Pictures/PitotAntennae1.jpg
and
http://ernest.isa-geek.org/Delta/Pictures/PitotAntennae2.jpg
I was able to borrow a "MFJ HF/VHF SWR Analyzer, Model MFJ-259B", do a
sweep from 110 to 140 MHz. A few readings are:
MHz SWR R X
110 15.4 20 81
115 20.2 2 21
120 14.9 3 1
125 10.8 14 47
130 8.6 403 0 (lowest SWR)
135 14.4 9 72
140 18.6 3 25
I didn't think I could get much below an SWR of 2.5 or so, and was
willing to accept the resulting poor performance; but, 8.6 is really
high. But then I put the rubber ducky antennae from my handheld scanner
on the instrument. Everything in the aviation band was ">25", ie out of
the instruments range. It dropped into range at 130MHz and to 1.6 at 149.5.
Considering that the handheld scanner seems to work, how viable would an
SWR of 10 to 20 work over here on the crowded eastern seaboard for
mostly day VFR operations?
Ed Anderson
Posted: Fri Dec 22, 2006 5:24 pm Post subject: Some experiments fail |
Gee Ernest, being an old Ham radio operator, I would be horrified to see
anything higher than 2 SWR on my antennas {:>) But, don't have any idea how
it would affect aircraft air ground comms.
Ed
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
sportav8r(at)gmail.com Guest
Posted: Fri Dec 22, 2006 7:18 pm Post subject: Some experiments fail |
what kind of impedance matching schemes did you try?
The angle between the antenna and ground pigtails in the picture looks
really narrow for best results. What sort of ground are you working
against?
Maybe a better approach would be to engineer a suitable antenna, then
hollow it out to act as a pitot, versus designing a pitot and then
trying to match it electrically to a transmitter.
-Bill B.
On 12/22/06, Ernest Christley <echristley(at)nc.rr.com> wrote:
and
MHz SWR R X
110 15.4 20 81
115 20.2 2 21
120 14.9 3 1
125 10.8 14 47
135 14.4 9 72
140 18.6 3 25
Gilles.Thesee(at)ac-greno Guest
Posted: Fri Dec 22, 2006 7:32 pm Post subject: Some experiments fail |
Hi all,
In my buddy's article at
http://contrails.free.fr/instruments_ant_sonex.php, he says he designed
the antenna out of an aluminum tube, and matched it to the particular
form of the vertical fin, acting as a ground plane.
He as not flown yet, and advises to wait for real world tests.
Season's greetings to all,
Best regards,
Gilles
Posted: Sat Dec 23, 2006 7:54 am Post subject: Some experiments fail |
Gilles Thesee wrote:
<Gilles.Thesee(at)ac-grenoble.fr>
Hi all,
designed the antenna out of an aluminum tube, and matched it to the
particular form of the vertical fin, acting as a ground plane.
That would be the intelligent way to do it, but like Bob has said
several times, the normal procedure is for structural guys to have their
say, then the aerodynamics guys, yada, yada, yada, and somewhere down
the list the antennae guys get to say something. In my case, I'm using
Dynon's AOA indicator. It doesn't include a static port (which you
think it would for $200US), and there isn't a nice place for one on the
sides of a Delta, so I had to engineer one in. The antennae experiment
proceeded from that point.
I tried adding some coils of 22AWG. Wrapped around a drill bit, and
held with tape, I put them in series with the element. It made things
so much worse that I didn't even bother recording numbers. I've got
some ferrite beads, but don't know if it's worth disassembling the coax
connector to install them. I guess it couldn't hurt at this point. The
ground is basically the entire welded tube airframe. The black wire
coming from the coax connetor is grounded next to the antennae's base.
The connector is also mounted on a strip of stainless that is riveted to
another piece of stainless that is in turn welded to the airframe.
Is it possible that some combination of fiddling can bring the SWR down
from the astronomical 8.6 to something below a 3? I think something
below 3 would be marginal but acceptable. I think.
VE3LVO(at)rac.ca Guest
Posted: Sat Dec 23, 2006 7:59 am Post subject: Some experiments fail |
Ernest,
Tying a VHF antenna to a pitot design is very ingenious..... and deserves
some serious thought! Kudos to you for the idea.
What needs doing is to revise the length of the pitot to match the needs of
a 1/4wave monopole OR devising matching circuit to adjust the pitot to 50
ohms impedance at 127 Megs. I don't think devising apitot system from an
antenna is the way to go.
I am hesitant to believe the matching scheme shown would measure the
true impedance/results, but can't offer any advice in that area.
The latter would be the easiest if not the best (one always seems to
prefer a natural resonance) but it cries out for a suggestion......... It
strikes me that the vertical length might be the problem since the greater
depth would reduce losses due to some horizontal content - the pitot need.
Is this a metal skin or fibreglass?
Good luck!
Ferg Kyle
Europa A064 914 Classic
Posted: Sat Dec 23, 2006 10:23 am Post subject: Some experiments fail |
Fergus Kyle wrote:
Ernest,
Good luck!
Fiberglass and fabric skins over a 4130 frame with stainless steel rib
structure.
I've been playing with the position of the jumper from the pitot to
connector, and the best I've been able to come up with is a low SWR of
6.5 or so.
khorton01(at)rogers.com Guest
Posted: Sat Dec 23, 2006 2:05 pm Post subject: Some experiments fail |
On 23-Dec-06, at 11:52 AM, Ernest Christley wrote:
| Quote: | I'm using Dynon's AOA indicator. It doesn't include a static port
(which you think it would for $200US), and there isn't a nice place
for one on the sides of a Delta, so I had to engineer one in. The
antennae experiment proceeded from that point.
Static ports need to be in a location where the pressure is very,
very close to the ambient pressure if they are to provide an accurate
static source. Pitot tubes in single-engine aircraft are almost
always mounted below the wing. The pressure below the wing is higher
than the ambient pressure - otherwise no lift would be generated.
This makes a pitot tube a very poor place to locate a static source,
unless you are prepared to test a large number of different
locations, with several test flights at each location.
I've watched one small aircraft manufacturer do this exercise with a
Piper pitot tube. They invested many hours of flight testing on
several different configurations before finding a location that
worked acceptably well with a custom angle on the bottom of a Piper
pitot tube - the angle changes the pressure sensed at the static source.
Kevin Horton
RV-8 (Finishing Kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
kayce33(at)earthlink.net Guest
Posted: Sat Dec 23, 2006 4:50 pm Post subject: Some experiments fail |
Hi Kevin,
I'm building an RV9A and have installed the Dynon pitot.
Besides the ram air,there's a small hole on the bottom for static air, that
way I suspect the engineering's already been done.
Food for thought at any rate.
Harold
Posted: Sat Dec 23, 2006 5:08 pm Post subject: Some experiments fail |
Kevin Horton wrote:
<khorton01(at)rogers.com>
Static ports need to be in a location where the pressure is very, very
unless you are prepared to test a large number of different locations,
That's why I copped out and just used the location the plans called
for. Heh, I can't run but so many experiments at once!! 8*)
After 4 hours of fiddling, I was able to drop the SWR to 7.3 by moving
the point where it attaches to the tube. I actually was able to get it
to drop to 1 at one point. I installed a T connector...the antennae on
the leg, the line coming off one side of the top and a 50 ohm
termination on the other side. I don't think that counts though.
Posted: Sat Dec 23, 2006 5:10 pm Post subject: Some experiments fail |
Harold Kovac wrote:
<kayce33(at)earthlink.net>
Hi Kevin,
that way I suspect the engineering's already been done.
Harold
The hole in the bottom rear is a drain hole. The hole at the front on
the slant is for the AoA indicator. There's no static.
Posted: Sat Dec 23, 2006 5:24 pm Post subject: Some experiments fail |
Thanks, I don't have the instrument yet, and assumed....it's plumbed to the
wing root...probably another year to get a look at the real thing.
Harold
Posted: Sat Dec 23, 2006 5:33 pm Post subject: Some experiments fail |
Harold,
1. I think that is actually a water drain hole.
2. If someone did the engineering and flight testing required to use
a static source on a pitot tube, it would be specific to one exact
mounting location and mounting angle on only one type of aircraft.
It wouldn't be practical for Dynon to do the flight testing required
to define a mounting location for each type of aircraft that people
would want to mount this pitot on. Each aircraft type would probably
require at least a dozen hours of flight testing, with mod work
required to move the pitot tube around every two or three flights.
Huge job.
Kevin
Hi Kevin,
air, that way I suspect the engineering's already been done.
Harold
nuckollsr(at)cox.net Guest
Posted: Sun Dec 24, 2006 10:49 am Post subject: Some experiments fail |
At 09:28 PM 12/23/2006 -0400, you wrote:
Harold,
Huge job.
There are a number of probes that offer both static and pitot
pressure sensing. Obviously, the dynamic portion has an opening
on the end and the static portion is generally ported to the
external environment through a ring of holes just behind the
nose opening. Pitot-Static probes, as you already know, have two
fluid fittings instead of one. They are much more difficult to
build under the current ice-survival rules. See complex
maze of passages JUST to handle ice crystals and ingested
moisture for a pitot-only tube at:
http://www.aeroelectric.com/Pictures/Pitot_Tube/Pitot_Tube_Heater.jpg
It may now be impossible if not simply impractical to combine
both functions into a single device. But for non-aviation, precision
airflow measurements, combined pitot-static probes are quite
common. See:
http://www.unitedsensorcorp.com/pitot_frame.html
http://www.flowkinetics.com/measurement.htm
If I can put my hands on one of the older pitot-static probes
I've had laying around here, I'll post some photos.
But Kevin is right-on with his observations of the difficulty
for achieving acceptable pitot-static measurements in a
consumer environment (read repeatable from airplane to airplane
and known, stable boundaries on accuracy). You wouldn't believe
the hoops we've jumped through to meet the new RVSM (reduced
vertical separation minimums) that have effectively doubled the
number of over-water airways by stacking airplanes in at twice
the old vertical density.
Now, one of the really hot items on the pilot's pre-flight
inspection is to spit-polish the areas around the pitot static
system ports to make sure that no contamination has altered the
aircraft's ability to detect and hold an assigned altitude.
Even after all the fussing is over and the type-certificate is
awarded, few if any systems are perfect. This give rise to the
Calibrated Airspeed and Calibrated Altitude differential charts
found in many pilot's operating handbooks.
Good pitot static measurements become exponentially difficult
as your need for accuracy drops below 2 or 3 percent. The pitot
static systems installed on our flight test aircraft are big, heavy,
and would look really ugly installed on your RV.
The J-3 stuck a piece of copper tube out in the breeze ahead of
and below the wing. The performance was adequate for that class
of airplane and the way it was used. I used to show my renters how
to comfortably operate that airplane with the panel completely
covered. But as we move up in performance and our demands on
knowing the real numbers go up, it can be difficult and expensive
to get them all right under all conditions.
Posted: Sun Dec 24, 2006 12:00 pm Post subject: Some experiments fail |
At 08:07 PM 12/23/2006 -0500, you wrote:
| Quote: | After 4 hours of fiddling, I was able to drop the SWR to 7.3 by moving the
point where it attaches to the tube. I actually was able to get it to
drop to 1 at one point. I installed a T connector...the antennae on the
leg, the line coming off one side of the top and a 50 ohm termination on
Sounds like you're attempting to "gamma-match" the mast of
your pitot tube as a useful radiator.
http://www.vk1od.net/GammaMatch/gamma.htm
For this technique to begin to be successful, the overall
length of the mast must be close to 1/4 wavelength at the
frequency of interest. In the case of comm antennas, let us
assume a center frequency of 126 Mhz. So 300/126 yields
2.4 meters for full-wave or .6 meteres for 1/4-wave.
In the clumsy system currently favored by the intellectually
unwashed, this comes to 23.4 inches. This is the length
of pitot tube you need to start with.
Now, a Google search of "gamma match" on the 'net
will yield a wealth of data on the physics and techniques
of gamma matching. In a nutshell, your goal is to attach
a 50 ohm feedline to some point along the antenna's length
so as to achieve the best match . . . obviously, the antenna's
impedance at the base is damned-small-ohms and up in the
gazillion-ohms range at the top. SOMEWHERE between the base
and the top, we should find the utopian 50 ohm point. Problem
is that any conductor you use to run between end of the coax
and the physical attach point on the antenna has significant
INDUCTANCE at our frequency of interest. This is why all
the articles you'll find on gamma-matching will incorporate
two variables. Physical attach-point on the radiator and
an adjustable capacitance for "series-resonating" the
offending inductance and making it disappear.
You don't describe the details of your experiment but if
you have a better description and perhaps photos to share,
we can help you move this exercise forward. Just know that
the first essential elements are overall length (at least
1/4 wave), feed point location and inductive reactance
elimination by use of variable capacitor.
These features go ONLY to achievement of an acceptable
standing wave ratio. Once the antenna appears to be efficiently
accepting (or delivering) energy, then one can turn to issues
of radiation efficiency. Is the polarization optimized? Is
the radiation pattern acceptably devoid of performance killing
nulls? Is the radiation resistance a significant if not major
portion of the antenna total impedance. I've seen antennas with
1:1 swr having impedances of 50 ohms and radiation resistances
on the order of 1 ohm . . . the thing gets about 2% of applied
energy launched into the ether while the rest is a feeble and
inefficient attempt to de-ice the antenna.
For those of us who are interested in the simple-ideas that
support antenna performance, may I suggest a peek at:
http://www2.arrl.org/tis/info/whyantradiates.html
Antennas are really interesting pieces of technology and it
doesn't take a lot of equipment and even less "black art" to
fabricate useful designs. I would only caution that if the goal
is to achieve a 1/4 to 1/2-knot more speed by reducing antenna
drag on your OBAM aircraft, be aware that the return on investment
for the $time$ expended might be disappointingly small. If the
goal is to understand more about how these critters work, then
your return on investment can be considerably better.
ulflyer(at)verizon.net Guest
Posted: Mon Dec 25, 2006 8:02 pm Post subject: Some experiments fail |
By far I am not an antenna expert but what I've seen from the
pictures there are several major issues.
The length of the antenna element appears to be far shorter than it
should be for a 118-136 MHz spectrum.
The next thing I noticed is you go from coax to long simple single
connector wires to connect to the element and the ground plane.
You don't have much of a ground plane that I can see.
Last, looks like you have the antenna element and the pitot in very
close proximity to each other, if not at the proper spacing that has
to impact your SWR, added together even more so.
I use nothing more than a simple SS whip from Radio Shack bent into L
shape and sized to produce a good SWR across normal frequency
spectrum used in our area. I get out well and receive well.
Bob didn't comment on these items that I noticed so either he's
biting his fingers or what I noticed isn't a factor.
jerb
At 05:28 PM 12/22/2006, you wrote:
the pitot tube for an antennae. It's worth a shot, right? There's
even some documentation of the technique at
and
a sweep from 110 to 140 MHz. A few readings are:
MHz SWR R X
110 15.4 20 81
115 20.2 2 21
120 14.9 3 1
125 10.8 14 47
135 14.4 9 72
140 18.6 3 25
really high. But then I put the rubber ducky antennae from my
handheld scanner on the instrument. Everything in the aviation band
was ">25", ie out of the instruments range. It dropped into range
would an SWR of 10 to 20 work over here on the crowded eastern
seaboard for mostly day VFR operations?
Posted: Tue Dec 26, 2006 8:50 am Post subject: Some experiments fail |
At 09:58 PM 12/25/2006 -0600, you wrote:
By far I am not an antenna expert but what I've seen from the pictures
The length of the antenna element appears to be far shorter than it should
Last, looks like you have the antenna element and the pitot in very close
proximity to each other, if not at the proper spacing that has to impact
shape and sized to produce a good SWR across normal frequency spectrum
Bob didn't comment on these items that I noticed so either he's biting his
Didn't see the pictures until now Jerb but you're observations are spot
on.
Ernest. Your interest and willingness to explore antenna options
are commendable. The experiments are worthwhile learning tools.
But whether you're wanting to explore a new antenna configuration
or learn to make biscuits, the shortest path to success is to
study what has preceded your efforts.
Do some Google searches on antennas. There are thousands of
articles. Get copies of ANY editions of amateur radio antenna
handbooks. Those published by ARRL are noteworthy. Used book stores
on the 'net can provide a wealth of low cost, detailed data on how on
might approach the task of launching intelligence into the ether borne
on a stream of electromagnetic radiation. Your pictures
and words suggest that you've acquired some useful facts about
antennas but have yet to grasp the simple-ideas that support those
facts.
Get some books and study up on the relationship between operating
frequency and physical sizes of antennas. You'll need to have a rudimentary
grasp of transmission line theory and impedance at radio frequencies.
There's a chapter on antennas in the 'Connection that would provide
a beginning but what you're attempting to accomplish requires a study
into much more detail.
If you find something published for which you'd like more explanation
post a question about it here on the List. There are plenty of folks
here who would be willing to participate in some shared learning and
teaching experiences.
Now, if it's the 'short' answer you're looking for, I can tell you
that the current crop of pitot tubes offer little prospect for becoming
a useful antenna on an aircraft. But that doesn't mean we shouldn't
study and discuss why - both for your benefit and that of perhaps
1300 other folks who watch this list.
A quick note on other comments you offered:
| Quote: | >I didn't think I could get much below an SWR of 2.5 or so, and was
>SWR of 10 to 20 work over here on the crowded eastern seaboard for mostly
>day VFR operations?
Please understand that SWR has only a very loose connection
with antenna performance. SWR is a measure of the antenna system's
ability to accept power from the transmitter (or convey it to
a receiver). It says nothing about the antenna's ability to
efficiently radiate or intercept a signal.
A 50 ohm resistor has an SWR of 1:1 over the entire range of
interest but zero ability to function as an antenna. The MFJ-259
is of great value for improving power transfer by helping you
optimize a "match". But 1.5:1 SWR measured on a wet-string
does not insure that the wet-string will produce satisfactory
performance as an antenna.
Posted: Tue Dec 26, 2006 6:36 pm Post subject: Some experiments fail |
Robert L. Nuckolls, III wrote:
| Quote: | Ernest. Your interest and willingness to explore antenna options
facts.
Thank you, Bob, but I've believe I've bitten off way more than I can
chew. The problem with antennaes is what I've heard from both you and
Jim Weir. To paraphrase: A wet noodle in a cast iron swimming pool
will radiate, and it gets better from there. The implication is that
just about anything will work, for some qualified definition of 'work'.
This experiment was an exercise in placing a chunk of existing metal at
it's appropriate spot somewhere is the spectra of wet noodle to
'dedicated ham special'.
I don't have the resources, time or energy to remanufacture the tube,
and once I get past the basics of antennae theory I started to get
swimmy headed. The pitot tube has to remain unmodified so that it may
serve its intended purpose for one very profound reason. I've done paid
for it and it was EXPENSIVE 8*) I also think I know more about antennae
than I originally set out learn...which is a good thing, but for the
swimmy headiness. At this point, I know the radio will transmit well
enough to be recieved in the kitchen from the garage (put that unit in
your metric pipe and smoke it 8*), and I can only presume that it was
received clearly since it brought the family out to ask what I wanted
(another great measurment unit for the international community 8*).
The next step will be to see how well it does at the airport during the
taxi test. It shouldn't be very hard to pre-arrange for a few strategic
radio checks. If it is sufficient, it will get qualified in the
pattern. If it proves worthwhile, I'll extend the range until I know
how effective it is. If it is really bad, I'll try something a little
more conventional, though not as universally applicable. I could fish a
welding rod down into the foam core of my air intake, for instance.
All in all, I think this has been a worthwhile experiment for me, and
I'm especially pleased that my little splash has stirred the neurons of
a few that have many more to stir than I. Marc Beranger inspired me. I
inspire someone else. They develop something that exceeds, even by the
slightest of measures, what what done before. I LOVE this internets thing.
