Malcolmbru(at)AOL.COM Guest
Posted: Fri Dec 22, 2006 10:37 am Post subject: setting RPM |
Dee I have asked this question before but have never made any changes to prop or jetting I herd of egt,s around 1300 but fee that is high. Comfort levels are a very subjective. I wish I worried less and had moor fun flying. like the time you came to visit, I wanted you to fly my machine but when you said you had a migraine I got scared for you and my plain. mal [quote][b]
Fox5flyer Guest
Posted: Fri Dec 22, 2006 10:57 am Post subject: setting RPM |
1300 is a bit too high Mal. Increase pitch or rejet. Shoot for 1200.
Yeah, the headache was pretty bad that day. Could barely fly my own, let alone having to worry about yours.
Deke
I'm outta here for a few days. Merry Christmas everybody!
Aerobatics(at)aol.com Guest
Posted: Fri Dec 22, 2006 4:12 pm Post subject: setting RPM |
In a message dated 12/22/2006 12:38:30 P.M. Central Standard Time, Malcolmbru(at)aol.com writes:
| Quote: | | Dee I have asked this question before but have never made any changes to prop or jetting I herd of egt,s around 1300 but fee that is high. Comfort levels are a very subjective. I wish I worried less and had moor fun flying. like the time you came to visit, I wanted you to fly my machine but when you said you had a migraine I got scared for you and my plain. mal |
I believe Rotax wants 1,200F. I would like to add, indicated temp is like airspeed. The final word is the plugs. My Indicated Temps may or may not be accurate. I started off a bit cool (rich)... at 1150 F at cruise and the plugs showed cool... then went to factory settings and been there mostly since.
Remember there are big differences from WOT and cruise temps as much as 200F cooler at WOT and this is on purpose...
Ho ho ho
Dave
Malcolmbru(at)aol.com Guest
Posted: Fri Dec 22, 2006 8:00 pm Post subject: setting RPM |
If out side air temp is 40 degrees will the gage be reading 30 degrees hi or low?as 70 degrees is ambient.
If the egt reads 1200 at 40 outside air temp what is actual egt temp? and how will ajusting the prop change this? mal
