RotaxEngines-List:
Johann G. Johannsson
PostPosted: Tue Jan 31, 2006 12:25 am    Post subject: RotaxEngines-List: Reply with quote
Hello Craig.
You could be draining the battery if you have the C connection from the
regulator grounded through the battery selenoid.
When you turn the battery master off, the selenoid is grounded and if
the C wire is connected to ground when battery master is off, you will
drain the battery slowly.
Just make sure that the battery does not get grounded through the
battery selenoid or the C wire.
Do not ask how I know this.
Hope this will help.
Johann G.
Zenith 701
c w wrote:
The Stemme Sv10 motor glider uses one you might try
them.
I am wondering if any 914 users has starting problems,
I cant start mine without a jump from another battery,
i replaced the
battery, the starting solenoid and the wires and still
have this
problem, the only thing i havent replaced is the
starter but it seems fine when i start it with a
jumper battery attached and restarts fine in flight
and once in awhile it will start with a battery
charger connected all night, im thinking that maybe
the starter solenoid is taking to much juice to
activate it all.
Craig
--- "Ing. Gottfried Komaier"
<gottfried.komaier(at)gmx.net> wrote:
> To all,
>first of all it was an good idea to create this
>Rotax-list.
>Let's start the discussion with one of the an
>unanswered question from
>Rotax.
>I have a 914 now ready for installation in my
>aircraft and searching for an
>Intercooler. I am looking since a while for an
>manufacturer of an IC, but
>until now I've got no answer from the companies who
>are recommended to me
>from other 914-owners. Does one of you have an idea
>where I can get one, and
>how are your experience with the engine-performance
>after installing an IC.
>Installation-pictures would be fine as well.
>Thank you in advance,
>Gottfried Komaier
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Johann G.
Iceland.
Flying Zenith 701.
mike.sinclair(at)att.net
PostPosted: Tue Jan 31, 2006 7:22 am    Post subject: RotaxEngines-List: Reply with quote
Craig
For what it's worth, when I first was attempting to start my 912 it seemed
that the battery didn't have enough juice to get it to turn over very well.
Turned out that I didn't have the engine grounded good enough. Once I added a
ground strap from the engine to the airframe it cranked right up.
Mike Sinclair
Zenith 701
"Johann G." wrote:
Hello Craig.
Johann G.
Zenith 701
>them.
>i replaced the
>have this
>activate it all.
>Craig
>> To all,
>>Rotax-list.
>>Rotax.
>>Gottfried Komaier
>__________________________________________________
>Do You Yahoo!?
