Possible overheating and EGT question
Goto page 1, 2  Next
wingnut
PostPosted: Thu Dec 28, 2006 3:18 pm    Post subject: Possible overheating and EGT question Reply with quote
I discovered a small puddle of coolant under my airplane this morning. I had spent the previous day practicing in the pattern for almost two hours and I’m wondering if the constant "touch & go" with all that time at full throttle caused it to overheat. I'm ashamed to say that I did not notice if any of the gauges where indicating anything out of the ordinary.
I ran her up on the ground for a while and could not reproduce the leak so I tried a few turns around the pattern keeping a close eye on the gauges. As usual the EGT runs near the upper range of the gauge during takeoff at 1600F. I didn't used to worry about that because it's still just shy of max and it always cools off once I level out for cruise. Today though, I noticed that it stayed up at 1600 on the downwind leg coming down only when I pulled back to idle before the base turn.
Is this normal behavior for EGT? Should I bump the mixture a bit? If I do adjust the mixture, how do I keep the two carbs in sync?
eskflyer(at)lvcisp.com
PostPosted: Thu Dec 28, 2006 4:53 pm    Post subject: Possible overheating and EGT question Reply with quote
UHHHH Wing nut what engine are you running .
If you are running the 582 you most likely have a fried engine MAX EGT is
1200 .
If 912 normal is 1472 max is 1652
Good luck and hope you find the trouble
John Perry
DO NOT ARCHIVE
wingnut
PostPosted: Thu Dec 28, 2006 5:47 pm    Post subject: Re: Possible overheating and EGT question Reply with quote
Duh. Sorry 912UL.
Is it typical for EGT to hit max at full throttle? Water and oil temps are nominal as is oil pressure. Another thing worries me is that this Westach combo gauge only goes up to 1600F. It looks like the needle is free to move beyond 1600 but there's no way to be sure.
Float Flyr
PostPosted: Thu Dec 28, 2006 6:35 pm    Post subject: Possible overheating and EGT question Reply with quote
Sounds like you might be a bit lean. Also the cool dense air is making your
engine run even leaner.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
torgemor(at)online.no
PostPosted: Thu Dec 28, 2006 6:55 pm    Post subject: Possible overheating and EGT question Reply with quote
Hi Luis, (not sure about your name)
Funny this thing, as I thought I'll write some- about the EGT system
before the New Year. Hmmm...
The thing is that, the EGT system is measuring differential temperature.
Ok., the system that is used for measuring the exhaust gas temperature is
measuring temperature difference, NOT absolute temperature!!
Well, it is measuring the temperature difference between the
cockpit(inside cockpit temperature -NOT the OAT!) and the EGT probe
temperature.
But you'll know, the temperature in the cockpit may change -then your EGT
reading change too!!!
To know your correct EGT temperature (at the probe) it important to know
the cockpit temperature.
So now, I'm wondering Smile how many of you are using a true cockpit
thermometer?
Some of you might have the double temperature meter, that measure the
inside and outside temperature (with ice warning) for cars?
This is indeed a good idea (if you checked that the readings are correct)
as this can be used to calculate your "true" EGT.
The ting is that, your EGT system is calibrated at a known temperature!
Do you know this temperature for your instrument???
Now, think about this "calibration temperature" as a line across a
standard mercury meter scale, if your cockpit temperature is above this
line -your meter is reading to low!
This is because the meter (and the calibration point) is moving towards
the EGT probe temperature, see less difference I.E. reading to low.
The other way around, no cockpit heater (or a poor heater), I'm trying to
say that the cockpit temperature is below the "calibration value". In
this case, the indicated value will show to high, so we think that we are
boosting the red line. But indeed we should subtract the "absolute" value
of the reading BELOW the "calibration value" line.
In this latter case, our reading will be to high.
Ok., to summarize; in the winter time our reading will be to high, -and in
the summer time our reading will be to low, IF OUR COCKPIT TEMPERATURE
DIFFER/VARY WITH SEASONS FROM THE INSTRUMENTS CALIBRATION TEMPERATURE.
If you have a temperature controlled “de luxe” heater that can maintain,
say 23 deg. Celsius in the cockpit -everything become so much more
simple. Smile Smile
(I'll add a little bit more about this later.)
Now to your engine:
Doing touch and go is without doubt a real hard work for your engine, esp.
in the winter time.
As the temperature is going a lot down, and maybe it's CAVOK(a high
pressure), in this situ. your engine got lot's of more O2 -meaning better
combustion and higher temperature. Yes, we've to enrich to keep the
temperature in the green (one notch up and..). So this is why we have
more power during the winter season. (Sure that's more to say here..).
Also, as the air molecules is closer together we would have a better lift
as well. (Hey, winter flying is more fun!!)
In the winter time, cooling is also allot better, so this will normally
not occur, unless there is another problem. (If not, check your
thermostat.)
A last word, after such a hard work for your engine it is a good practice
to let the engine idle for some time to take the heath out. If not, we
often see that the engine start boiling after shut down. (Hint; this is
always a must for a turbo engine).
Torgeir.
On Fri, 29 Dec 2006 00:18:55 +0100, wingnut <wingnut(at)spamarrest.com> wrote:
ordinary.
http://forums.matronics.com/viewtopic.php?p=84061#84061
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
PostPosted: Thu Dec 28, 2006 9:02 pm    Post subject: Possible overheating and EGT question Reply with quote
Hi again,
Just a little important note.
When I said one notch up, I meant one notch to bring the needle up having
more rich mixture.
To actually do this, the locking ring has to go one notch down on the
needle itself...
Sorry, but do not want any confusion here.
Torgeir.
On Fri, 29 Dec 2006 03:55:29 +0100, Torgeir Mortensen <torgemor(at)online.no>
is measuring temperature difference, NOT absolute temperature!!
temperature.
EGT reading change too!!!
thermometer?
correct) as this can be used to calculate your "true" EGT.
to say that the cockpit temperature is below the "calibration value".
In this case, the indicated value will show to high, so we think that we
are boosting the red line. But indeed we should subtract the "absolute"
value of the reading BELOW the "calibration value" line.
in the summer time our reading will be to low, IF OUR COCKPIT
TEMPERATURE DIFFER/VARY WITH SEASONS FROM THE INSTRUMENTS CALIBRATION
TEMPERATURE.
simple. Smile Smile
Now to your engine:
esp. in the winter time.
better combustion and higher temperature. Yes, we've to enrich to keep
the temperature in the green (one notch up and..). So this is why we
have more power during the winter season. (Sure that's more to say
here..).
lift as well. (Hey, winter flying is more fun!!)
thermostat.)
practice to let the engine idle for some time to take the heath out. If
not, we often see that the engine start boiling after shut down. (Hint;
this is always a must for a turbo engine).
Torgeir.
> the ordinary.
wingnut
PostPosted: Thu Dec 28, 2006 9:10 pm    Post subject: Re: Possible overheating and EGT question Reply with quote
more rich mixture.
needle itself...
OK. Now I'm really confused. You wouldn't happen to know where I can find an illustration of what you are talking about? Also, when adjusting the mixture at the carb, how does one ensure that the two carbs stay in sync?
-Luis
-824KF
runwayrex(at)juno.com
PostPosted: Thu Dec 28, 2006 9:40 pm    Post subject: Possible overheating and EGT question Reply with quote
OK. Now I'm really confused. Youwouldn't happen to know where I canfind an illustration of what you aretalking about? Also, when adjusting themixture at the carb, how does one ensure that the two carbs stay in sync?
Luis,
Did you get my earlier response (off line)?
Changing the needle positions on the carbs does not have any affect on the carb syncronization. Check out either the Rotax parts catalog or the overhaul manual. Both show the needle and clip relationship in diagrams.
Rex in Michigan
-Luis
-824KF
http://forums.matronics.com================================================ - The Kitfox-List Email Foruist utilities such as the Subscriptions pa================================================sp; - NEW MATRONICS WEB&nbsp=======================================================
Float Flyr
PostPosted: Fri Dec 29, 2006 5:58 am    Post subject: Possible overheating and EGT question Reply with quote
All you will ever want to know about Rotax engines
http://www.ultralightnews.ca/
There is a diagram on the left side of this page half way down Bing 54
http://www.ultralightnews.com/enginemaintenance/bingjet.html
Or
http://www.ultralightnews.ca/bing/index.html
And To sync the 912 carbs.
http://www.ultralightnews.ca/bing/912carbsync.html
Hope this helps.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
lcfitt(at)sbcglobal.net
PostPosted: Fri Dec 29, 2006 7:30 am    Post subject: Possible overheating and EGT question Reply with quote
Torgeir,
I have understood, as you say, that the the EGT probe is measuring a
differential temperature between the probe and the end of the metal shielded
lead. My lead does not terminate in the cockpit, although there is
sufficient length to do so. The leads on the Lancair IV I am helping with
are too short to enter the cockpit We coiled the leads aft of the first two
cylinders so the leads terminate in the same relative location, but they are
in the engine compartment. These airplanes are built to fly in the flight
levels so positioning the terminals above the baffling would give the
reference temps a great fluctuation. They are positioned below the baffles
of necessity due to their length.
Your thoughts.
Lowell
Lynn Matteson
PostPosted: Fri Dec 29, 2006 7:55 am    Post subject: Possible overheating and EGT question Reply with quote
Lowell-
I think what Torgeir said was that the EGT reading is a differential
between the probe and the cockpit temp. My understanding of my EIS is
that it references the unit temperature...that is, the temp of the
EIS "unit" itself, and any other temp that you are monitoring. If
Torgeir was not talking about the EIS unit, this comment may not apply.
Lynn
On Dec 29, 2006, at 10:29 AM, Lowell Fitt wrote:
<lcfitt(at)sbcglobal.net>
Torgeir,
a differential temperature between the probe and the end of the
metal shielded lead. My lead does not terminate in the cockpit,
although there is sufficient length to do so. The leads on the
Lancair IV I am helping with are too short to enter the cockpit We
coiled the leads aft of the first two cylinders so the leads
terminate in the same relative location, but they are in the engine
compartment. These airplanes are built to fly in the flight levels
baffles of necessity due to their length.
Your thoughts.
Lowell
Lynn
Kitfox IV-Jabiru 2200
N369LM
propellerdesign(at)tele2.
PostPosted: Fri Dec 29, 2006 9:28 am    Post subject: Possible overheating and EGT question Reply with quote
What I understand is that the reading is between the probe inside the exhaust tube, and the part of the wire closest to the probe, that's why it work better if it get cold air flow over the wires.
Jan
PostPosted: Fri Dec 29, 2006 11:17 am    Post subject: Possible overheating and EGT question Reply with quote
I was afraid about that you'll become confused.
Sorry for this.
Well, you was talking about over temp. due to the fact that some of the
coolant escaped through the overflow, right.
You did not state engine type, but I'll guess it's a 912?
An unsynchronized carb. most often create vibration and rough running
engine, due to different mixture between the two sides of the boxer engine.
This can sometimes be seen as a "big" difference in EGT reading between
the cylinder pairs (L/R side pairs differing to much).
Your problem is prob. due to winter operation -but, and your engine might
run lean, this increase the water temperature.
Or ?, this might be related to the cooling system itself, water pockets,
water pump or sometimes just a little lo on the water level ??
Well, you've already got "manual" references, so wishing you good luck.
Torgeir.
On Fri, 29 Dec 2006 06:10:29 +0100, wingnut <wingnut(at)spamarrest.com> wrote:
> having
> more rich mixture.
> needle itself...
sync?
-Luis
-824KF
http://forums.matronics.com/viewtopic.php?p=84145#84145
You're correct Lowell, the cold junction is at the connection point of the
thermocouple harness. This is the "harness" that's connected directly to
the probe.
Normally, this two wires "Chromel and Alumel" is connected directly to the
indicator, this is why "the cold junction point" normally is referred to
the indicator location.
However, now an then wires need to be changed or modified for various
reasons. In your case, the thermocouple harness is to short. Normally we
would order an extended thermocouple. Often we find them in three
different lengths, but all of them has the same resistance, if you measure
them with the EGT probe immersed into a mixture of ice and water. If this
mixture is stirred, it's the lab. definition of zero degrees Celsius, the
freezing point. In fact folk, we're using this method to really calibrate
accurate those big jet engines EGT systems, and here we're talking about a
different of one tent of a degree!!
The connection method Westberg (or nowadays Westach) use is the so called
"uncertain method", which is good enough for the kind of use they mention!
I've attached a little picture from their web site, that's show this
method very well. Anyway, the cold junction temperature Westach use is 70
Deg. F., or 21.11 Deg Celsius. This is their way of philosophy, cause most
operation take place in this temperature area, so the end result "might"
not be to far away if the cold junction is ignored.
The other calibration point they are using is the zero degrees Celsius
reference, this is in fact the standard cold junction reference point, did
you know that the "Chromel/Alumel" give 0 VDC at this temperature??
Handy, isn’t?
Now back to your problem, the short thermocouple harness. Do you know the
actual resistance for his cable(this value is often stamped on the
instrument side)?
If those two wires is to be extended, you'll have to make sure that the
total resistance do not increase to much, as this will create an
additional error and the indicator will give to low reading when temp is
high.
The standard cable (thermocouple) Westach are using is 2.4 Ohm. This total
value is not to be altered as this will ruin the system accuracy. There is
several solutions to this, the first and simplest is to use another probe
option with extended leads.
There's two more method’s, "the preferred" Chromel/Alumel connection
method -and a simple extension using "the preferred" connection.
Then to the link, Westach is here:
http://www.westach.com/
On the left side under INFORMATION, select Hardcopy Catalog then roll down
and select page 53; Then you'll see (the original picture)"THE PRINCIPLE
OF A THERMOCOUPLE"
So if you got one of those indicators, you'll find all the information
needed here for all of their instruments -also connection sheets etc.
The important thing is the resistance in the "added wires" -and that the
two spliced wires is in the same "temperature environment" that you can
measure all the time!
Remember, the temperature here (at the cold junction point) decide your
corrected reading -your true EGT temp.
Later on I'll make a few drawings how we use to connect the cold junction
by using the "preferred method". Maybe also a little about how we can
manipulate the system and still have a correct reading.
Torgeir.
On Fri, 29 Dec 2006 16:29:49 +0100, Lowell Fitt <lcfitt(at)sbcglobal.net>
wrote:
Torgeir,
shielded lead. My lead does not terminate in the cockpit, although
there is sufficient length to do so. The leads on the Lancair IV I am
helping with are too short to enter the cockpit We coiled the leads aft
of the first two cylinders so the leads terminate in the same relative
location, but they are in the engine compartment. These airplanes are
built to fly in the flight levels so positioning the terminals above the
baffling would give the reference temps a great fluctuation. They are
positioned below the baffles of necessity due to their length.
Your thoughts.
Lowell
 Filesize:  64.97 KB
 Viewed:  551 Time(s)
PostPosted: Fri Dec 29, 2006 12:23 pm    Post subject: Possible overheating and EGT question Reply with quote
Hi Lynn,
Yes, you're right by now you've probably been reading my post to Lowell
about this.
Funny that you mention the EIS, I'm a little curious about this system,
cause such a modern design should have an automatic cold junction
compensation system built in, I.E. the system measure the actual
instrument temperature and then correct the reading so you'll always be
reading the true EGT (well, -the temp at the probe).
If you are using this system, it could be interesting to know their cold
junction reference.
Yes, the principle is just the same, except that they're using an
amplifier and an analog to digital converter -vola..
Torgeir
On Fri, 29 Dec 2006 16:56:27 +0100, Lynn Matteson <lynnmatt(at)jps.net> wrote:
Lowell-
that it references the unit temperature...that is, the temp of the EIS
"unit" itself, and any other temp that you are monitoring. If Torgeir
Lynn
> Torgeir,
> aft of the first two cylinders so the leads terminate in the same
> relative location, but they are in the engine compartment. These
> airplanes are built to fly in the flight levels so positioning the
> terminals above the baffling would give the reference temps a great
> fluctuation. They are positioned below the baffles of necessity due to
> their length.
> Your thoughts.
> Lowell
Lynn Matteson
PostPosted: Fri Dec 29, 2006 6:25 pm    Post subject: Possible overheating and EGT question Reply with quote
I just looked for my manual for the EIS, but it's at the hangar. I
know they mention the cold junction, and say that it should be kept
as far from heat sources as possible, so they must be worried that
this junction will get hot and foul up the reading. But elsewhere I
recall reading that the unit temperature is what is used to compare
all other temp readings to, so I'm at a loss to say anything,
really...and I'm certainly no electronics person.
Lynn
Hi Lynn,
Lowell about this.
system, cause such a modern design should have an automatic cold
junction compensation system built in, I.E. the system measure the
actual instrument temperature and then correct the reading so
you'll always be reading the true EGT (well, -the temp at the probe).
cold junction reference.
Torgeir
> Lowell-
> differential between the probe and the cockpit temp. My
> understanding of my EIS is that it references the unit
> temperature...that is, the temp of the EIS "unit" itself, and any
> other temp that you are monitoring. If Torgeir was not talking
> Lynn
>> Torgeir,
>> measuring a differential temperature between the probe and the
>> end of the metal shielded lead. My lead does not terminate in
>> the cockpit, although there is sufficient length to do so. The
>> leads on the Lancair IV I am helping with are too short to enter
>> the cockpit We coiled the leads aft of the first two cylinders
>> are in the engine compartment. These airplanes are built to fly
>> They are positioned below the baffles of necessity due to their
>> length.
>> Your thoughts.
>> Lowell
Lynn
N369LM
Float Flyr
PostPosted: Sat Dec 30, 2006 6:01 am    Post subject: Possible overheating and EGT question Reply with quote
Enough to say Lynn your EIS is probably a darn sight more accurate than my
EGT. As long as you didn't cut any wires or use speaker zip wire in your
installation.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Sat Dec 30, 2006 6:48 am    Post subject: Possible overheating and EGT question Reply with quote
Right on Noel, re the speaker wire...not even Monster wire would work
here. : ) Actually though, the instructions say that you CAN cut the
wires shorter:
"NOTE: The length of wire on the EGT & CHT probes, or the extension
wire may be shortened as desired for your installation."
A personal note on their NOTE....I'm almost certain that I recall
speaking to Sandy at Grand Rapids Technologies (EIS) about shortening
the wires, and she said that you can shorten the wires coming from
the unit...actually the connector... but NOT the probe wires.
Torgeir-
I just read the manual re the "unit temperature"...to quote:
"This function is displayed on the hourmeter page, and shows the
internal temperature of the instrument. It is used by the instrument
for cold-junction compensation of the EGTs and CHTs. It is also
useful for estimating the cabin temperature, as it tends to stabilize
at about 30-35 degrees F above the ambient temperature."
It goes on to mention that it (the unit temperature) can be used to
check for excessive instrument (the EIS itself) heat, but that's not
pertinent to this discussion.
Lynn
than my
in your
installation.
Noel
Lynn
N369LM
Float Flyr
PostPosted: Sat Dec 30, 2006 7:51 am    Post subject: Possible overheating and EGT question Reply with quote
The probe wires is what I was referring to not being cut. The probes are
usually available with several different length harnesses. All of which
will have identical internal resistances.
As you wrote, your EIS has a second probe built in, physically close to the
cold junction that monitors the temp of that junction and automatically
makes your compensation corrections for you. That's the best. Except of
course if you loose your EIS at which time you will have more worries than
an EGT a couple of degrees too high.
Some other instruments will have a little bi-metallic spring, similar to
what is found in a thermostat, in the meter that will make adjustments for
the temperature of the cold junction. Sort of second best. In the event of
a power out you won't lose your EGT but the bi-metallic spring can after a
time lose its calibration.
My EGT doesn't have any compensation built in but the documentation says it
is calibrated for 20C (68F) Since my cockpit temps seldom if ever get above
68F the instrument is usable. Even if the cockpit temps went up to 80F the
accuracy of reading the meter because of parallax etc is probably close to
the 12F the meter will be reading too low.
In flight my EGTs show an almost even 1100F my plugs say they are getting
good mixture so I can now depend ( to an extent ) on my EGT gauge. I will
probably continue to check my plugs every 5-10 hr.
I got into a discussion with a gentleman on another group last year about
the use of extending probe harness with copper speaker wire. He said the
two extra junctions that were created would balance each other out and the
instrument would still be accurate. Actually there would be four junctions
created as the connectors actually on the instrument are chromel and alumel.
He considered a few feet of copper wire to have a resistance of 0 so it
wouldn't throw off his EGT. In fact the way he uses his EGTs just to follow
temperature trends it probably works for him.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Clem Nichols
PostPosted: Sat Dec 30, 2006 9:09 am    Post subject: Possible overheating and EGT question Reply with quote
For whatever it's worth, there's an article on page 48 or the January 2007
issue of "Light Sport and Ultralight Flying" which covers this very
subject. It's written by Arnold C. Anderson who is now retired after
spending " I37 years in the engine and aerospace industry as a mechanical
engineer, designing electro-mechanical equipment and solving reliability
problems in equipment for unmanned deep space missions". I would think that
this issue could probably be purchased by going to www.ultralightflying.com.
Clem Nichols
Goto page 1, 2  Next
Page 1 of 2
