roncarolnikko(at)hotmail. Guest
Posted: Tue Jan 02, 2007 7:23 pm Post subject: Rotax VS Volks wagon/Ice |
I have an updraft carb with a heat shield to keep it cool. In front of that
is an air cleaner that has an in and out. A butterfly in front of that
makes sure all intake air is just downstream from the cylinders. When open
it allows ram air from the front. No ice yet. Ron NB Ore
[quote]From: "dave" <dave(at)cfisher.com>
Subject: Re: Rotax VS Volks wagon
Date: Tue, 2 Jan 2007 06:47:46 -0500
Jan, Good memory but Ron has a speedster and is over 100 lbs heavier that
me to start with.
If I recall correctly Ron has a redrive on the VW . Should be a decent
combination when all the tweaking done.
Ron, Any troubles with Carb ice on the VW ?
Dave
