robin1(at)mrmoisture.com Guest
Posted: Mon Jan 01, 2007 5:20 pm Post subject: GPS Antenna Under Cowl |
I have seen a photo of several GPS antennas mounted on a plate under the cowl of an RV (sweet installation). I researched the archives but can’t seem to find it. Can anyone direct me to that image or builders log?
I am replacing my 296 for a 396 and wish to do a similar installation. My biggest concern is the Garmin GXM 30A antenna under the cowl with the heat. Garmin list price for replacing that antenna... $495.00 Sure hate to BBQ that unit. Comments/Suggestions?
Robin
RV-6A 325 hours. Fresh Annual, Adding 396
walter(at)tondu.com Guest
Posted: Mon Jan 01, 2007 6:34 pm Post subject: GPS Antenna Under Cowl |
> cowl of an RV (sweet installation). I researched the archives but can't
I copied mine from Dan.
See entry dated 10/19/04 on this page for the tray and entry
10/21/04 on the same page.
http://www.rv7-a.com/avionics_panel_3.htm
Walter Tondu
http://www.rv7-a.com - Flying!
http://www.evorocket.com - Building
ronlee(at)pcisys.net Guest
Posted: Tue Jan 02, 2007 7:21 am Post subject: GPS Antenna Under Cowl |
Don't mount it on the right (passenger) side of the firewall. It will
interfere with putting the hinge pins in.
Ron Lee
LessDragProd(at)aol.com Guest
Posted: Tue Jan 02, 2007 9:51 am Post subject: GPS Antenna Under Cowl |
Tracy Saylor said he measured the highest temperature at the upper rear corner of his RV-6 cowl at 35 degrees F over ambient at the worst case. He checked this before he installed his GPS antenna in that location.
Jim Ayers
In a message dated 01/01/2007 5:23:49 PM Pacific Standard Time, robin1(at)mrmoisture.com writes:
Robin
sportav8r(at)gmail.com Guest
Posted: Tue Jan 02, 2007 1:53 pm Post subject: GPS Antenna Under Cowl |
I wonder if that measurement excercise included the heat soak after
shut-down? My -6A cowl can get too hot to touch over the cylinders
after a few minutes on the ground post-flight, but I guess the cowl
aft of the rear baffles is much cooler than that, even then.
-Stormy
On 1/2/07, LessDragProd(at)aol.com <LessDragProd(at)aol.com> wrote:
Jim Ayers
cowl of an RV (sweet installation). I researched the archives but can't seem
Robin
Posted: Tue Jan 02, 2007 4:42 pm Post subject: GPS Antenna Under Cowl |
As sweet as the cowl install was going to be I opted for placing the antenna in the baggage area after considering the potential of having to replace a $500 antenna plus the time to re-rout to a new location. I spoke with Garmin this morning and their operating range for GXM 30A antenna is -40 to +185 F. It seems like we can get close to +185F under the cowl or in a closed Tip Up in Texas/Arizona. Heck, sometimes it feels like 185 F in the shade in Texas.
I have a feeling that the standard tear drop Garmin GPS antenna may be more heat resistant than the GXM 30A.
Thanks for the suggestions & photos.
Robin [quote][b]
ceengland(at)bellsouth.ne Guest
Posted: Tue Jan 02, 2007 5:00 pm Post subject: GPS Antenna Under Cowl |
Robin Marks wrote:
| Quote: | As sweet as the cowl install was going to be I opted for placing the
Robin
Just out of curiosity, what color is the antenna? If it's black (or any
dark color) & under a closed canopy, it could easily approach 200
degrees on a sunny day...
Posted: Tue Jan 02, 2007 5:02 pm Post subject: GPS Antenna Under Cowl |
At 05:41 PM 1/2/2007, you wrote:
| Quote: | As sweet as the cowl install was going to be I opted for placing the antenna in the baggage area after considering the potential of having to replace a $500 antenna plus the time to re-rout to a new location. I spoke with Garmin this morning and their operating range for GXM 30A antenna is -40 to +185 F. It seems like we can get close to +185F under the cowl or in a closed Tip Up in Texas/Arizona. Heck, sometimes it feels like 185 F in the shade in Texas.
Just remember that GPS satellites are moving and are all over the sky. Any metal
will block signals.
Ron Lee
garrys(at)tampabay.rr.com Guest
Posted: Tue Jan 02, 2007 5:06 pm Post subject: GPS Antenna Under Cowl |
How do you get a clear view of the satellites if your antenna is in the baggage bay under a metal skin?
Garry Stout
dan(at)rvproject.com Guest
Posted: Tue Jan 02, 2007 5:36 pm Post subject: GPS Antenna Under Cowl |
With a tip-up canopy, you could mount the GPS antenna on a little shelf sticking out beside the cabin frame support channel.
Or, if you're slick, you could cut a little "window" in the top of the support channel and install the antenna IN the channel.
All that said, my main GPS antenna is under the cowl.
)_( Dan
RV-7 N714D (1166 hours)
www.rvproject.com / www.weathermeister.com
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Tue Jan 02, 2007 6:58 pm Post subject: GPS Antenna Under Cowl |
In a message dated 01/02/2007 7:38:42 PM Central Standard Time, dan(at)rvproject.com writes:
| Quote: | | Or, if you're slick, you could cut a little "window" in the top of the support channel and install the antenna IN the channel. |
Or if you're REALLY slick, stick it on top of the support:
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5419
Mark
_________________ From The PossumWorks... |
wdleonard(at)gmail.com Guest
Posted: Tue Jan 02, 2007 7:55 pm Post subject: GPS Antenna Under Cowl |
Dan, I thought your GPS antennas were under the fore-deck under fiberglass. I liked the idea so much I also cut a hole in my for-deck, and covered it with fiberglass. I plan to mount all my satellite antennas under there.
Dave Leonard
Turbo Rotary RV-6 N4VY
My websites at:
http://members.aol.com/_ht_a/rotaryroster/index.html
http://members.aol.com/_ht_a/vp4skydoc/index.html
http://leonardiniraq.blogspot.com
On 1/2/07, Dan Checkoway <dan(at)rvproject.com (dan(at)rvproject.com)> wrote: [quote] With a tip-up canopy, you could mount the GPS antenna on a little shelf sticking out beside the cabin frame support channel.
)_( Dan
Posted: Tue Jan 02, 2007 8:29 pm Post subject: GPS Antenna Under Cowl |
I do have GPS and XM antennas under there (under the access panels). It's just my primary panel mounted GPS antenna that's under the cowl. The other antennas "seemed" more fragile in terms of temperature tolerance, and I didn't want yet a few more firewall penetrations.
Under cowl temps can get quite hot when the plane is sitting after a flight in the summertime. I don't buy the 35F over ambient thing...
)_( Dan
Posted: Tue Jan 02, 2007 8:44 pm Post subject: GPS Antenna Under Cowl |
Hi Dan,
The next time you see Tracy Saylor, you might mention that to him.
Jim
In a message dated 01/02/2007 8:32:08 PM Pacific Standard Time, dan(at)rvproject.com writes:
| Quote: | I do have GPS and XM antennas under there (under the access panels). It's just my primary panel mounted GPS antenna that's under the cowl. The other antennas "seemed" more fragile in terms of temperature tolerance, and I didn't want yet a few more firewall penetrations.
)_( Dan
rv8(at)lazy8.net Guest
Posted: Wed Jan 03, 2007 6:20 am Post subject: GPS Antenna Under Cowl |
Dan Checkoway wrote: | Quote: | I don't buy the 35F over ambient thing...
)_( Dan
Before you say something like that Dan, you should try actually measuring it. I have, and got similar results to Tracy's.
John
[quote] | Quote: | ----- Original Message -----
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Sent: Tuesday, January 02, 2007 7:53 PM
Subject: Re: GPS Antenna Under Cowl
Dave Leonard
My websites at:
On 1/2/07, Dan Checkoway <dan(at)rvproject.com (dan(at)rvproject.com)> wrote: | Quote: | With a tip-up canopy, you could mount the GPS antenna on a little shelf sticking out beside the cabin frame support channel.
)_( Dan
Sent: Tuesday, January 02, 2007 5:06 PM
Garry Stout
Sent: Tuesday, January 02, 2007 7:41 PM
Subject: RE: GPS Antenna Under Cowl
Robin
href="http://www.matronics.com/Navigator?RV-List">
href="http://forums.matronics.com">
| [b]
Hopperdhh(at)aol.com Guest
Posted: Wed Jan 03, 2007 6:55 am Post subject: GPS Antenna Under Cowl |
Dan,
If you are saying that it gets hotter than that, I agree. There is quite a bit of engine heat that accumulates behind the baffle from the exhaust and oil sump. I also believe the curves -- without engine heat.
I have a very simple GPS antenna installation. The Garmin 295 is mounted in the panel. A 6 inch length of RG-400 goes to a BNC bulkhead connector on the glareshield (sliding canopy). The portable antenna from the 295 then sits on the topside of the connector. It has always gotten good reception.
Dan Hopper
RV-7A
In a message dated 1/2/2007 11:32:06 PM Eastern Standard Time, dan(at)rvproject.com writes:
)_( Dan
Posted: Wed Jan 03, 2007 7:36 am Post subject: GPS Antenna Under Cowl |
Interesting. Still call me a skeptic, but I agree about measuring it. I'll get some nonreversible temperature strips from McMaster and see what it hits.
http://www.mcmaster.com/nav/enter.asp?pagenum=519 (middle of that page)
)_( Dan
phil(at)petrasoft.net Guest
Posted: Wed Jan 03, 2007 8:47 am Post subject: GPS Antenna Under Cowl |
I have two GPS antennas mounted on my glare shield (slider canopy). They both get great reception. At first I thought they might be a distraction, but that fear was unfounded. I never notice them while flying.
Godspeed,
Phil Birkelbach
RV-7 - 727WB
www.myrv7.com
On Jan 3, 2007, at 8:53 AM, Hopperdhh(at)aol.com (Hopperdhh(at)aol.com) wrote:
Dan,
Dan Hopper
RV-7A
In a message dated 1/2/2007 11:32:06 PM Eastern Standard Time, dan(at)rvproject.com (dan(at)rvproject.com) writes:
)_( Dan
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Posted: Wed Jan 03, 2007 9:30 am Post subject: GPS Antenna Under Cowl |
Dan and Phil,
Same here, Phil. I have a compass up there anyway, so I can't even see the GPS antenna.
Dan, I was referring to the heat after engine shutdown. As I reread my post I see that that could be interpreted as meaning while flying. I didn't mean that.
do not archive.
Dan H
In a message dated 1/3/2007 11:49:47 AM Eastern Standard Time, phil(at)petrasoft.net writes:
| Quote: | I have two GPS antennas mounted on my glare shield (slider canopy). They both get great reception. At first I thought they might be a distraction, but that fear was unfounded. I never notice them while flying.
Godspeed,
Phil Birkelbach
RV-7 - 727WB
www.myrv7.com
Dan,
Dan Hopper
RV-7A
)_( Dan
.matronics.com/">http://forums.matronics.com/
Rick Galati
Joined: 10 Jan 2006 Posts: 90 Location: Lake St. Louis MO.
Posted: Wed Jan 03, 2007 10:19 am Post subject: Re: GPS Antenna Under Cowl |
| robin1(at)mrmoisture.com wrote: | | I have seen a photo of several GPS antennas mounted on a plate under the cowl of an RV (sweet installation). I researched the archives but can’t seem to find it. Can anyone direct me to that image....My biggest concern is the Garmin GXM 30A antenna under the cowl with the heat. Garmin list price for replacing that antenna... $495.00 Sure hate to BBQ that unit. Comments/Suggestions? ..... |
When I planned my GPS antenna installation, I contacted Garmin about those concerns and was assured heat is not an issue. The major caution they advised was simply avoiding the application of metallic paint on the cowl directly above the antenna. If using a metallic paint, they suggested leaving a flat black or other non-metallic coating directly above and around the antenna's light of sight. With 200 operational hours, my installation has proved to be trouble free. Signal acquision is within moments of firing up. I have never lost a signal in flight or even on the ground for that matter.
I have found it is usually best to simply contact the manufacturer with my technical concerns as opposed to wading through a lot of opinion on open forums. Do yourself a favor and contact Garmin for your own peace of mind. Enclosed is an attachment of the under-the-cowl shelf I fabricated from .032 stock for my GPS antenna. I played around with cardboard patterns until I had the design I wanted.
http://img510.imageshack.us/img510/4637/gps220bk2.jpg
Rick Galati RV-6A "Darla"
