brentbidus(at)juno.com Guest
Posted: Mon Jan 01, 2007 2:48 pm Post subject: Rotax 912 FWF relay question |
Can anyone confirm that part number 49028 (starter relay provided by
Rotax) is a Prestolite SAZ-4201N solenoid? I can't find anything with
49028 on the tag. Are a starter relay and solenoid the same thing? If
not, what does the solenoid hook up to? I looked up the prestolite part
number on the internet and it shows it as a solenoid. Probably a basic
question but I'm pretty electrically challenged. Thanks,
Brent Bidus
Colorado Springs
lcfitt(at)sbcglobal.net Guest
Posted: Mon Jan 01, 2007 5:18 pm Post subject: Rotax 912 FWF relay question |
Brent,
It is my understanding that the starter relay is different as it is
intermittent only and the Master solenoid is continuous duty. My starter
relay is unmarked, but the can has two tabs on the end for mounting while
the master relay as tabs spot welded to the side.
I did a check on this one and it seems to be an intermitent and likely
provided as the starter relay. see:
http://preview.ametek.com/content-manager/files/APL/SAZ-4201N1.pdf It shoes
a duty of Max 2 min.
Lowell
Float Flyr
Posted: Tue Jan 02, 2007 6:24 am Post subject: Rotax 912 FWF relay question |
A starter relay is a solenoid. It can handle a lot of current for
relatively short periods of time. There are other solenoids available that
are specifically designed for longer periods of energization.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
