bobf(at)feldtman.com Guest
Posted: Tue Jan 02, 2007 3:52 am Post subject: supercharger tensioner |
My supercharger is staying "ON" when control is turned "OFF"... tensioner belt
needs adjusting - should I turn it left to loosen the belt or right to
tighten the belt to allow MP to be 29.9 inches when "OFF"? Four or five
turns?
bobf
| - The Matronics Lom-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lom-List |
Jeayers1(at)aol.com Guest
Posted: Fri Jan 05, 2007 8:03 am Post subject: supercharger tensioner |
The supercharger tension needs to be loosen.
I tried adjusting the supercharger tension when the starter didn't seem to stay engaged. I have the 30mm starter solenoid. Apparently I need the 34mm starter solenoid. I have a 12 volt system.
Jim Ayers
In a message dated 01/02/2007 3:53:08 AM Pacific Standard Time, bobf(at)feldtman.com writes:
Quote: | --> Lom-List message posted by: Robert Feldtman <bobf(at)feldtman.com>
turns?
bobf
Posted: Fri Jan 05, 2007 6:11 pm Post subject: supercharger tensioner |
On Friday 05 January 2007 10:02, Jeayers1(at)aol.com wrote:
I did loosen it - and it strted fine - two props! now, I need to adjust it
because the supercharge stays "ON" delivering 37 inches MP even when the
supercharger control is put in the "OFF" position. I know I can just leave
the SC ON and drop the MP back with the throttle, but I want to be able to
turn it off properly. The glastar cowling is not too bad to take off, but it
is requiring some on and offs -- cause to check the full throttle manifold
pressure, I cannot hold the plane still - it skids on the brakes! The only
way is to taxi out and do a takeoff with full throttle....
I'll let you know when I get it figured out. I am also tying to get hold of
Joe Krybus at Santa Paula Airport - he apparently is a LOM expert and see if
he has any hints.
thanks!
bobf
Jim Ayers
belt
turns?
bobf
