Larry Bowen
Posted: Thu Jan 04, 2007 3:24 pm Post subject: avionics air |
Not that I've seen, but it seems doable. You could make a small T off the
main line out of thin PVC oe something. Make the initial run up-hill in
case rain gets in there.
What indications do you have that your radios are too hot?
Larry Bowen, RV-8, RV-7, 'cause I don't know any better...
Larry(at)BowenAero.com
http://BowenAero.com
Randy Pinkston wrote:
<pinkston(at)carolina.rr.com>
has anyone used air from air vent on side of the rv to cool avonics
?don't
want to use fan if i can get by without it. randy pinkston flying rv7a
YES A..... I just dont like draging my tail
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
pinkston(at)carolina.rr.c Guest
Posted: Thu Jan 04, 2007 3:47 pm Post subject: avionics air |
just putting my hands on them plus i was told by a shop all radio stacks
need it ....thanks randy pinkston
David Lee
Posted: Thu Jan 04, 2007 5:40 pm Post subject: Re: avionics air |
Outside air will contain a lot of moisture during our summers and the heat will build on the ground. Be careful. A fan may be the cheapest solution in the long run. Some avionics have a self contained fan (Garmin 430/530). Might want to check.
David Lee
