Posted: Wed Feb 01, 2006 4:14 am Post subject: Xtra |
Hi all,
some movement at last.
Permission to test fly my Xtra, registered G-PLAD, came through this morning. There is some confusion over the MAUW but Kiwimick, who will complete the test flying is sorting this out.
The permission to test which Mick will do as designated pilot, is good until End of Feb. A restricted flying area for a specified time then follows and I hope to be able to complete that myself at my home field. Getting it home from Micks field, about 150 miles away, will entail a one off positioning flight for which permision should be forthcoming easily.
Micks field is completely fogged in today. Vis at my field is under VFR limits. Hey Ho !
Pat
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Wed Feb 01, 2006 4:39 am Post subject: Xtra |
Way cool Pat...
Keep us posted.
pat ladd <pj.ladd(at)btinternet.com> wrote:
Hi all,
Pat
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
biglar
Posted: Wed Feb 01, 2006 5:49 am Post subject: Xtra |
Man, I'll bet you're chomping at the bit, eh ?? Good Luck, Pat, I hope that
notorious British weather co-operates for you. Lar.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
