nuckollsr(at)cox.net Guest
Posted: Fri Jan 05, 2007 12:12 pm Post subject: Another 60A alternator, internally regulated voltage regul |
At 07:19 PM 1/5/2007 +0000, you wrote:
| Quote: | Add me to the list of folks how had this happen to them. I have about 75
hours on this alternator. Scott at Van's said he's heard of this
happening before but not often. He suggested to just take the alternator
to a repair shop and for $20 bucks get it fixed. Well, I found no such
place around here so far that can do that....but that's not why I'm writing.
I want to learn if I can read this problem in advance in the future.
I did recently have a battery that got weak.
What kind and how old was the battery? Did it
get any kind of testing done since new to track
its condition?
| Quote: | It put out about 11.2 volts one day out of the blue no matter how long I
charged it with my Battery Tender. I replaced it and flew a couple of
hours on the new battery before the voltage regulator went belly up.
Now the alternator puts out about 18 to 19 volts. If I turn on all
the lights I can get the voltage to drop to about 13 - 14 at idle.
It may have been a regulation problem since day-one. Do you
monitor voltage in the cockpit? Are you sure that an over-zealous
IR alternator didn't cook the battery?
Why would the battery probem eventually lead to the regulator
problem (I've heard it could) and can it be pretty much guaranteed
to do so under certain conditions?
I'm aware of no combination in the physics that suggests
a battery can damage a regulator. Most likely, it's the
other way around.
The symptoms you describe mimic a shorted regulator
the causes the alternator to run flat-out. The only reason
the bus voltage is not climbing quickly to 100 volts or
more is that your new battery is doing its level best
to use up the alternator's output. Fortunately, the
alternator is current limited and the new battery fairly
robust . . . but the alternator will eventually win.
The regulator is not difficult to replace but you need to
know the make and model of your alternator to acquire the
right replacement part.
luckymacy(at)comcast.net Guest
Posted: Fri Jan 05, 2007 1:04 pm Post subject: Another 60A alternator, internally regulated voltage regul |
It was an Odyssey pc680 and it's van's 60 amp alternator with the internal voltage regulator. I don't know for sure the make but many say it's a nippondenso (ND). I didn't take it off yet.
Yes, the voltage is monitored all the time by my EIS & EFIS and there's a pretty tight voltage range which would trigger an "alarm" if it went out of range. It never did prior to just oughtright dropping a couple of volts permanently. But it was my original battery which I abused throughout the build process and I'm not the least bit surprised. I got my 4 years money's worth as far as the battery goes....
No, I didn't actively track the battery's voltage becuase I ALWAYS left it on a trickle charger while hangared at the home airport and it never gave me any grief during long trips like to Oshkosh plus the alarm range was pretty tight on the EFIS (I guess you could say that's gross tracking to some extent). My bus voltage once the engine is running has always been about 14.2 volts plus or minus .1
I had heard that a "weak" battery can damage the alternator/regulator so this seamed to have validated that statement. For sure though, from my observations, the battery appeared to go bad first then 2 hours later after a new battery was installed the regulator seems to have failed. My current battery voltage is really good, even after the voltage regulator failure stress on the battery.
lucky
[quote]-------------- Original message --------------
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
[quote] --> AeroElectric-List message posted by: "Robert L. Nuckolls, III"
What kind and how ol d was the battery? Did it
its condition?
I'm aware of no combination in th e phys e many [quote][b]
