		pilotpat
  Joined: 23 Dec 2006 Posts: 14 Location: Williamsport, PA
				 Posted: Sat Jan 06, 2007 2:57 pm    Post subject: landing gear shock cord |
				Hi all,  been watching the postings for a month or so now and am new at this.  I have a classic iv kitfox (curently working on) and am doing the bungee cord landing gear.  The book says 6 wraps , but I can only get Five,  Is there some special tool or method or someone with special tips on how to do this in order to get six wraps?   Thanks in advance
 or does anyone have a Grove landing system , they want to get rid of and make it easy?
 pilotpat
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Tom Jones
  Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
				 Posted: Sat Jan 06, 2007 3:33 pm    Post subject: Re: landing gear shock cord |
				Pat
 Yes, six wraps are needed. The trick is to not loose any slack you gained on one wrap while making the next wrap.  There are several ways to do it and I suspect you will get some more replys soon.
 I wrapped up the jaws of my waterpump plires with electrical tape so as not to damage the cord.  I worked from under neath the plane and held each wrap tight in place with the pliers with one hand while I fed the cord around the truss and pulled the next wrap tight with the other hand.
 Tom Jones
 Classic 4
		Michel
				 Posted: Sat Jan 06, 2007 3:34 pm    Post subject: landing gear shock cord |
				On Jan 6, 2007, at 11:57 PM, pilotpat wrote:
  	  | Quote: | 	 		   The book says 6 wraps , but I can only get Five
 Hello Pilotpat,
 You will certainly get many advice from this list, as some of us has
 managed to do it properly and apparently without too much effort.
 Others, like me, had a hell of a time working this, as I replaced mine
 last summer. That made me wonder: Are we all working with bungees of
 the same length? My new ones were quite shorter than the ones I removed
 after 13 years of good service. I attributed that to natural
 stretching. But ... was it really?
 Anyway, it's certainly a two man's job, a lot of sweat, and a vise
 wrench to hold the bungee as you take a new turn. How are your end
 fitting? Loops or hooks? When I pulled hard the last turn of the latter
 (cone spring hook), it came loose. So I went for the loop type.
 Cheers,
 Michel
		Float Flyr
				 Posted: Sat Jan 06, 2007 4:08 pm    Post subject: landing gear shock cord |
				Install floats... Save yourself scraped knuckles and a lot of choice four
 letter words. There have been some good ideas posted here over the last
 year.  Some include lubricating the posts you wrap the bungee around with
 baby oil...I think some one else suggested talcum powder on the bungee
 itself.
  The last two years I put mine on wheels and never got the chance to fly so
 this year it's going to over winter on the pontoons.
 Still not a sign of ice on the bay.  Five years ago there would have been
 Ski-Doos everywhere...Thirty years ago there would have been few Ski-Doos
 but there would have been a lot of Land Rovers every where.
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		dave
				 Posted: Sat Jan 06, 2007 5:42 pm    Post subject: landing gear shock cord |
				When I took off my floats this year and put tube gear back on, I used 5
 wraps only. It sits a little low on one side now but it flys fine. If I
 recall one bungee was 60 inches and the other 64 inches.  They are Mil spec
 bungees and seem ok here.   All these Kitfox movies were shot with the 5
 wraps only   http://www.cfisher.com   3 rd link on left side.
 I have used 6 before and they are stiffer but the 5 does seem to work. I
 have flown with me  210 lbs and another 210 pounder and full fuel and never
 noticed the bungees to be much different other than a softer ride but
 certainly not mushy. I have no idea what the proper length of the bungees is
 supposed to be and maybe mine are too short ?
 Good Luck and get a buddy to help it will make it allot easier.
 Dave
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		mike(at)mikegibbard.com Guest
				 Posted: Sat Jan 06, 2007 7:02 pm    Post subject: landing gear shock cord |
				If  you use tie wraps to hold each wrap and cut them when you have all six wraps.  I was in the plane and a friend was below .  The person below would hold the tension and I would tie the tie wrap and then repeat process.  Takes less than a 1/2 hour to do both.  Good luck.  Mike
 On Sat,  6 Jan 2007 14:57:10 -0800, pilotpat wrote > --> Kitfox-List message posted by: "pilotpat" <pkelly20(at)comcast.net>  >  > Hi all,  been watching the postings for a month or so now and am new at this.  I have a classic iv kitfox (curently working on) and am doing the bungee cord landing gear.  The book says 6 wraps , but I can only get Five,  Is there some special tool or method or someone with special tips on how to do this in order to get six wraps?   Thanks in advance  >  > or does anyone have a Grove landing system , they want to get rid of and make it easy?  >  > pilotpat  >  > Read this topic online here:  >  > http://forums.matronics.com/viewtopic.php?p=85913#85913  >  ===============  itfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List  ===============    ="_blank">http://forums.matronics.com  ===============    Mike Gibbard  REO Bellaire  7953  W old State Rd Central Lake  231-544-5241 Home Office  231-676-3788 Cell Phone  231-544-5015 or 231-533-6114  mike(at)mikegibbard.com  http://www.mikegibbard.com         [quote][b]
		roncarolnikko(at)hotmail. Guest
				 Posted: Sat Jan 06, 2007 8:05 pm    Post subject: landing gear shock cord |
				Jeez my book says seven!  It's hard as a rock and a pain to do.  One wrap
 then wedge, next wrap then move wedge, next wrap move wedge, etc...  Ron NB
 Ore
 [quote]From: "dave" <dave(at)cfisher.com>
 Subject: Re: landing gear shock cord
 Date: Sat, 6 Jan 2007 20:41:37 -0500
 is supposed to be and maybe mine are too short ?
 Dave
		pilotpat
				 Posted: Sun Jan 07, 2007 4:29 am    Post subject: Re: landing gear shock cord |
				Thanks for all the quick replys.   Soon as my strength regains, will give it another try.   I had to agree with you Michael, that I wondered if they were the correct length (I have the loops) ,  But I got so "wrapped up" in my work with these , that I never did measure them, (wish i had) but I guess the next time, when I try to redo for the six. (Is there a certain length?)  Again thanks to you all for the recommendations and tips.   This is a great site  and I wish you all a Happy belated New Year and Great Flying!  Also be patient with me , if I screw up the rules for this site as trying to learn that too......This is my first ever using any forum type thing on the internet , so it is ok to yell at me if I do it wrong, as i want to fly straight
 Later
 Pilotpat
 Williamsport, Pennsylvania
  _________________ Pilotpat
Kitfox Classic IV
Jabiru 2200
Williamsport , PA |
		Michel
				 Posted: Sun Jan 07, 2007 6:07 am    Post subject: landing gear shock cord |
				On Jan 7, 2007, at 1:29 PM, pilotpat wrote:
  	  | Quote: | 	 		   Also be patient with me , if I screw up the rules for this site as
 So far, we have nothing but to learn from your elegant and polite
 style, Pat (if that is your name). I have been for many years on many
 lists and forum, on the internet, and the rule is simple: Write as you
 would to a good friend.
 The general "netiquette" is: In you reply, cut what is not relevant to
 the understanding. Change the title when the topic changes and add
 "Off-topic" in the title when talking about other things than Kitfox
 building or flying.
 In addition, this list like to see the words "do not archive" at the
 end of an email if the subject is personal and not of interest for
 those who are browsing via the search engine, for relevant general
 information.
 To get back to the subject, I think the success of the installation of
 the shock absorbing bungee is in the technique of not loosing tension
 as you make the next turn. Wood wedges, pliers, tie wraps - everything
 helps. Find your own technique and let us know how it went. Good luck.
 Cheers,
 Michel
		Guy Buchanan
				 Posted: Sun Jan 07, 2007 7:45 am    Post subject: landing gear shock cord |
				At 06:04 AM 1/7/2007, you wrote:
  	  | Quote: | 	 		  To get back to the subject, I think the success of the installation of
 I found a different tack that worked solo. I tied the wheels together to
 support the aircraft and to make sure they were all the way "up". I then
 removed the old shock cord and installed the new at both ends getting as
 many wraps as I could easily do. (I think it was four.) I then pulled all
 the slack toward one end using fairly smooth pliers pulling on the shock
 cord cover as gently as possible. Once I'd worked down the slack I removed
 the slack end and pulled another wrap. I did this all the way to six wraps
 and it was fairly easy. Though I worried about damaging the cover and core
 with the pliers I found the detriment no worse than the various methods I'd
 tried to hold full tension on each wrap while taking the next.
 Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
		alnanarthur(at)sbcglobal. Guest
				 Posted: Sun Jan 07, 2007 8:10 am    Post subject: landing gear shock cord |
				Hi Pilotpat,
 I can change the bungie cords on my Series 5 by myself in about 30
 min. each.  I don't even break a sweat.
 I use zip ties and a cargo tie-down strap (the kind that when you
 pull it tight, the spring loaded friction lever holds it tight).
 First, mark the old bungie across the top with a marking pen and
 remove it.   Lay out the old beside the new and transfer the
   marks to the new one, marking all the way around the new cord.  Or,
 if this is a first time installation, mark the new bungie cord
   cord at the approximate locations for the required number of loops
 needed.
 Now with the new bungie cord,
 2. now make a loop around the gear and
 3. about a foot up after the gear loop on the free end form about a 3
 inch temporary "free end loop" and secure it with a zip tie.
 4. Take the cargo tie-down over the forward fuselage carry-through
 tube and thru the friction lever and hook it to the "free end loop" .
 5  With the cargo tie down, pull up on the "free end loop" till the
 first mark on the new bungie is on top,(the friction lever
      will hold it, now you hands are free) then secure  the gear loop
 tightly with one or two zip ties.
 6. Release the  friction lever and unhook the cargo tie down and cut
 the zip tie on the "free end loop"  and
 7. Repeat 2 thru 6 till all gear loops are on then secure the final
 end loop of the new bungie to the post.
 8. "Carefully" cut all the zip ties holding the individual gear loops.
 Hope this makes sense.
 Allan Arthur
 Kitfox 5, N40AA
 Rotax 912s, Warpdrive 3 blade
 Byron Airport, CA  (C83)  Hanger C8
 On Jan 6, 2007, at 2:57 PM, pilotpat wrote:
  pilotpat
