rngurley(at)mindspring.co Guest
Posted: Sun Dec 31, 2006 6:09 pm Post subject: Newbie question about scratches |
I am currently working on my horizontal stabilizer forward spar. When I pulled the blue plastic off of the spar, I found some handling damage scratches from ½ to 3 thousands (.003) deep. They run both with and across the gain. What is the best way to polish these out?
Dick Gurley
Empanage
Posted: Sun Dec 31, 2006 6:44 pm Post subject: Newbie question about scratches |
Unless you're planning on polishing the whole airplane ...... I'd give the scratches attention when I was prepping to paint. By the time you're done, there will be a lot more than just these scratches!!!
Linn
Dick Gurley
Empanage
jdalton77(at)comcast.net Guest
Posted: Sun Dec 31, 2006 7:04 pm Post subject: Newbie question about scratches |
Dick,
I would wait. If they're really bad you may want to smooth and prime, but for the most part you'll have so many scratches by the time you're done that you'll have to scothbrite and prime anyway.
Jeff
fehdxl(at)gmail.com Guest
Posted: Sun Dec 31, 2006 7:52 pm Post subject: Newbie question about scratches |
Dick,
If you don't already have a 6" Scotch-brite deburring wheel mounted on a bench-grinder, then you really should. It would smooth out those tooling marks in no time at all. Don't be shocked at the $55 sticker price -- it's worth every penny!
Here's a link to what I'm talking about. http://tinyurl.com/y9z62w
Also, the 1" x 1" abrasives mounted to a die-grinder is, IMNSHO, the only way to de-bur inside edges such as lightening holes. Just go the the next page from the link above.
In the mean time, some 400 (or higher) grit wet/dry sandpaper will smoothing it out fine.
-Jim
P.S. I think the other guys thought you were talking about scratches on the outside of a skin...yeah, there will be lots of those. Don't wory about them until painting.
On 12/31/06, Dick Gurley <rngurley(at)mindspring.com (rngurley(at)mindspring.com)> wrote: | Quote: |
Dick Gurley
Empanage
o=\o [quote][b]
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Mon Jan 08, 2007 7:39 pm Post subject: Newbie question about scratches |
I treat any scratches at the same time as I am deburring and preparing the part for priming. I use the same silicon carbide sandpaper I use for some of the deburring to blend any scratches deep enough to be concerned with.
Kevin
40494
tail/empennage
_________________ Kevin
40494
do not archive |
