david555(at)cox.net Guest
Posted: Sun Jan 07, 2007 7:47 am Post subject: Fuel Filter Modifications |
My partner in crime, Richard Reynolds came up with a modification to address my concerns about the accessibility of the fuel filter in the tunnel "We" purchased two filters (approx $65 each) and installed one for each tank under the pilot and co-pilot seats. We also installed valves that can shut fuel off to the tanks so the tanks will not have to be drained in order to clean the filters. I used to be the quality manager of Holley Carb. and have seen significant automotive fuel contamination and suspect that the some of the same contamination issues apply to Avgas. Also the Left and Right filters add a little safety to the equation. If anyone is interested Richard can post some pictures in a couple weeks. 40138 David Boone and Richard Reynolds
roy.debbie(at)cox.net Guest
Posted: Sun Jan 07, 2007 6:22 pm Post subject: Fuel Filter Modifications |
I'm interested in the pictures and part numbers.
rvbuilder(at)sausen.net Guest
Posted: Sun Jan 07, 2007 6:45 pm Post subject: Fuel Filter Modifications |
As would I and I’m guessing at least a few others. Drop the pictures and info to the list when you have it.
Michael Sausen
-10 #352 Limbo
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roy & Debbie
Sent: Sunday, January 07, 2007 8:20 PM
Subject: Re: Fuel Filter Modifications
Deems Davis
Posted: Sun Jan 07, 2007 6:53 pm Post subject: Fuel Filter Modifications |
Me too. sounds like an excellent idea
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Roy & Debbie wrote:
[quote] I'm interested in the pictures and part numbers.
dlm46007(at)cox.net Guest
Posted: Sun Jan 07, 2007 7:17 pm Post subject: Fuel Filter Modifications |
wcurtis(at)core.com Guest
Posted: Mon Jan 08, 2007 9:31 am Post subject: Fuel Filter Modifications |
[quote] My partner in crime, Richard Reynolds came up with a modification to >address my concerns about the accessibility of the fuel filter in the >tunnel "We" purchased two filters (approx $65 each) and installed one >for each tank under the pilot and co-pilot seats. Make sure when addressing one concern, you do not create others. In addition to what David said, have you plumbed a bypass valve into these under-seat filters? The stock Van’s setup includes a bypass valve should the filter become clogged. This is unlikely in your dual setup, but should be considered. William Curtis - 40237 - SB fuse/finish http://wcurtis.nerv10.com/ [quote][b]
