nuckollsr(at)cox.net Guest
Posted: Sun Jan 07, 2007 9:31 pm Post subject: Three Fat Wires on Starter Contactor Bolt: How? |
At 10:37 PM 1/7/2007 -0600, you wrote:
| Quote: | Folks,
I'm building a GlaStar with the battery behind the baggage
compartment. I've run (2) 2 AWG cables from the firewall to the battery
area. I intend to terminate the (8 AWG) "B" alternator lead on the
battery side of the starter contactor as it is shown on Z-11. I also want
to run another 8 AWG from the same starter contactor bolt to the fuse
panel to avoid running another fat wire all the way to the back.
But the starter contactor bolt isn't long enough to capture three lugs
with lock washer and nut. I could gain some room by putting a thinner nut
next to the contactor body but I'm afraid to start wrenching on that nut
for fear of screwing up the contactor internals. I have two possible
approaches and am looking for comments or alternatives.
First, crimp the two 8 AWG wires into a single lug (I have a good crimper
for big lugs and will fill the cavity with solder). The space on the
contactor bolt will be tight but should be feasible. I could gain even
more room by using a metal stop nut and eliminating the lock
washer. Second, fabricate a short buss bar out of heavy gauge brass and
attach that to the contactor bolt and fasten the three lugs to the buss
bar. My concern here is properly insulating and securing the buss
bar. Any shorts here and I'd have a flying arc welder under my
cowling. Would that dippable plastic coating material (Plasti-Kote?)
work? How about the fuseable silicon tape?
(I've already used an uninsulated piece of brass to tie my ammeter shunt
into the negative side. The brass bolt through the "forest-of-tabs" also
captures the ground strap to the engine crankcase and one end of the brass
bar. The ammeter shunt is attached to the other end of the brass bar and
my 2 AWG negative return cable is attached to the other end of the ammeter
shunt.)
Unrelated question: Is Ultra Tef-Gel conductive? I've been using it on
some electrical connections on the assumption that it is conductive. If
it isn't, I've got some rework to do.
Best regards,
Bob
<http://www.matronics.com/Navigator?AeroElectric-List>http://www.matronics.com/Navigator?AeroElectric-List
-- incoming mail is certified Virus Free.
Checked by AVG.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Sun Jan 07, 2007 9:37 pm Post subject: Three Fat Wires on Starter Contactor Bolt: How? |
| Quote: | Folks,
that will work.
| Quote: | The space on the contactor bolt will be tight but should be feasible. I
could gain even more room by using a metal stop nut and eliminating the
lock washer. Second, fabricate a short buss bar out of heavy gauge brass
and attach that to the contactor bolt and fasten the three lugs to the
buss bar.
that probably works better.
| Quote: | My concern here is properly insulating and securing the buss bar. Any
shorts here and I'd have a flying arc welder under my cowling. Would
that dippable plastic coating material (Plasti-Kote?) work? How about
See pictures at:
http://www.aeroelectric.com/Pictures/Wiring_Technique/Firewall_Ckt_Protection.jpg
http://www.aeroelectric.com/Pictures/Wiring_Technique/Contactor_Interconnect/Contactor_Strap_3.jpg
This is the engine side of firewall on Model 36 Bonanza. LOTS
of exposed, high current conductors. What's going go get into them?
You've got a propeller spinning up front that will make hamburger out
of you in a heartbeat . . . but we don't put wire cages around them.
It's perfectly okay to have "open hazards" as long as you've
done the necessary homework to keep things from falling into them.
shunt.)
No, it's an anti-seize compound and not conductive. However, in
a properly bolted or crimped joint, compression forces in the
metal-to-metal joints would extrude any Tef-Gel out of the joint.
Don't worry about it.
