Michel
Posted: Sun Jan 07, 2007 4:25 am Post subject: Jabiru vs. Rotax. WAS: Rear spar attach reinforcement |
On Jan 7, 2007, at 12:22 PM, Lynn Matteson wrote:
| Quote: | Michel from Norway, of this group, once posted some documentation
about a fly-off between a Rotax-powered and a Jabiru-powered
plane...Michel?
Yes, there is, somewhere, a comparison made between two identical Rans
S6, one with a Rotax 912 and one with a Jabiru 2200. The test was made
in England but, unfortunately, I don't have anymore the URL. I tried to
Google a bit but couldn't find it again.
Anyway, the result of the test was that both engines were quite
excellent and giving pretty much the same performance. Maybe the Rotax
had a slight advantage at climb-out, but it was less that I thought it
would be. The thing is: The engine is only one-half of a powerplant;
the propeller is the other. A good match between those is what we want.
Cheers,
Michel
kentk
Joined: 03 Jan 2007 Posts: 25 Location: College Station
Posted: Sun Jan 07, 2007 6:42 am Post subject: Re: Jabiru vs. Rotax. WAS: Rear spar attach reinforcement |
Could this be the link?
http://www.sportair.co.uk/cgi-bin/Page87L2.htm
Kent
_________________ Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done |
wingnut
Posted: Sun Jan 07, 2007 7:07 am Post subject: Re: Jabiru vs. Rotax. WAS: Rear spar attach reinforcement |
I've been trying to track down a small coolant leak for the past couple of weeks that has me wishing for a Jabiru. I pull the cowling off as soon as I get in the hangar but can't see anything. I come back the next morning and there's a small puddle. Driving me nuts. I'm going to have to sleep under the darn thing to find this leak.
-Luis
-824KF
lcfitt(at)sbcglobal.net Guest
Posted: Sun Jan 07, 2007 8:18 am Post subject: Jabiru vs. Rotax. WAS: Rear spar attach reinforcement |
Luis,
I had a coolant leak several years ago and as I don't recall where, but it
was from the rear of the engine near the water pump. I called Rotax and
they recommended BarsLeak. No problem since and it's been several years.
Lowell
Jim Shumaker
Posted: Mon Jan 08, 2007 8:04 pm Post subject: Jabiru vs. Rotax. WAS: Rear spar attach reinforcement |
I've been tracking the same thing. Finally found hose that is leaking under the ends. It does not leak until left overnight and then gets worse and worse.
Jim Shumaker
_________________ Jim Shumaker |
