Seperating cage from boom tube
cedavis
PostPosted: Sun Jan 07, 2007 1:08 pm    Post subject: Seperating cage from boom tube Reply with quote
I'm in the midst of a major rebuild of my Firefly, and have hit a
snag. In order to repair some cage damage, I need to separate the
cage from the boom tube. After stripping the cage completely, it was
time to pull the large bolt out of the "H frame". However, it doesn't
want to come out. Smile
I've been reluctant to use much force, since it's such a structurally
critical part of the plane. Any suggestions?
Chuck
Malvern, PA
ul15rhb(at)juno.com
PostPosted: Sun Jan 07, 2007 4:43 pm    Post subject: Seperating cage from boom tube Reply with quote
Chuck, take another 3/8" bolt and pound it out. It will come out.
Ralph
Chuck
Malvern, PA
________________________________________________________________________
FREE Reminder Service - NEW from AmericanGreetings.com
Click HERE and never forget a Birthday or Anniversary again!
http://track.juno.com/s/lc?s=197335&u=http://www.americangreetings.com/products/online_calendar.pd
APilot(at)webtv.net
PostPosted: Sun Jan 07, 2007 9:11 pm    Post subject: Seperating cage from boom tube Reply with quote
When parts do not come apart easily, such as aluminum gear legs which
have galvanic corrosion with the steel housings, I use liquid wrench and
let it sit. If there is no flameable stuff near, I will hit the stuck
area with some heat and immediately after add more liquid wrench.
Sometimes, it does not work, but ususally it does.
jeepacro(at)cox.net
PostPosted: Sun Jan 07, 2007 9:18 pm    Post subject: Seperating cage from boom tube Reply with quote
What does the rest of the plane look like? Are you flying it?
Rob.
icrashrc
PostPosted: Mon Jan 08, 2007 2:36 am    Post subject: Re: Seperating cage from boom tube Reply with quote
Soak both ends of the bolt with a good penetrating oil. Do that a few times over at least a 24 hour period. Then turn the bolt while a friend taps the other end with a drift and hammer. Turn and tap at the same time and it should walk right out. If it gives you any trouble you may want to drill a hole in the end of the bolt slightly larger than the end of the drift. That will keep the end of the bolt from mushrooming so easy.
Scott
www.ill-EagleAviation.com
cedavis
PostPosted: Mon Jan 08, 2007 3:37 am    Post subject: Seperating cage from boom tube Reply with quote
Rob - the wings, tail feathers are off. The cage is completely
stripped except for sitting on the landing gear. i.e; no seat,
covering, fuel tank, engine, nose cone or fabric...
Needless to say, it's not flying. Sad
The consensus seems to be just push it out with a punch or another bolt.
Now, if everyone on the list would send me $1000 to help out with the plane...
Chuck
jeepacro(at)cox.net>
Subject: Re: Seperating cage from boom tube
Rob.
e.bayliss(at)blueyonder.c
PostPosted: Mon Jan 08, 2007 10:46 am    Post subject: Seperating cage from boom tube Reply with quote
Hi all
I have often come across motorcycle engine mounting bolts ( where they go
right through the crankcases) stuck / corroded into place and believe it
or not a good soaking overnight in coke (coca cola the drink not the
other type) will often free it up. I believe it is something to do with
the mildy acidic properties (or something like that) in the coke.Its worth
trying if nothing else moves it
Eddie Bayliss
(uk)
robbie.robertson(at)mail.
PostPosted: Mon Jan 08, 2007 11:10 am    Post subject: Seperating cage from boom tube Reply with quote
Happy New Year!
Hope all is well with you (a part from this bloddy awful weather that is)...
Back from Tenerife and missing the warm sun already.
Haven't been to Houghton yet, but I bet it's still as wet as when I left (if not worse). Itching to try out the new prop Surprised(
Are you not on MSN messenger any more?
Regards, Robbie
jindoguy(at)gmail.com
PostPosted: Mon Jan 08, 2007 12:01 pm    Post subject: Seperating cage from boom tube Reply with quote
It won't help you get the bolt out, but I have a similar problem with the rocker box studs on my Troublehead Vibraglide.Water seeps and in causes dissimilar metal corrosion. I slobber the studs up with anti sieze compound and the rocker boxes slide right off when required.
Rick
On 1/8/07, e.bayliss <e.bayliss(at)blueyonder.co.uk (e.bayliss(at)blueyonder.co.uk)> wrote:[quote] --> Kolb-List message posted by: "e.bayliss" <e.bayliss(at)blueyonder.co.uk (e.bayliss(at)blueyonder.co.uk)>
Hi all
Eddie Bayliss
(uk)
WhiskeyVictor36(at)aol.co
PostPosted: Wed Jan 10, 2007 7:04 am    Post subject: Seperating cage from boom tube Reply with quote
In a message dated 1/7/2007 4:09:10 P.M. Eastern Standard Time, ceddavis(at)gmail.com writes:
some cage damage
HEY CHUCK,
You didn't say what caused the damage! : >(
Bill Varnes
Original Kolb FireStar
Audubon NJ
