gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Fri Jan 26, 2007 7:42 am Post subject: Anybody using a flux gate compass instead of a DG? |
I would like to replace my ailing DG with an in-dash flux gate compass.
My compass is so tiny and hard to read I never look at it other than to
set the DG. I don't see any point of having a DG if it could be replaced
by a large readable in-dash compass. The only flux gate compasses I
can find are those made for boating. Here is one possibility:
http://www.nasamarine.com/Instruments/clippercompass.html
It even has a handy steer to course function. This unit is 110 mm sq
so is a little large but sure looks easy to read!
Glenn
Turn searches into helpful donations. Make your search count.
pete(at)lawless.info Guest
Posted: Fri Jan 26, 2007 8:45 am Post subject: Anybody using a flux gate compass instead of a DG? |
Hi Glenn
A pal of mine has just fitted a Dynon EFIS in his RV, this includes a
fluxgate compass and electronic AH, amongst a host of other features. It
saved 8 pounds getting rid of the vacuum instruments. Its early days but so
far both pilots who fly the aeroplane love the display. I had a look at it
yesterday and it is certainly very easy to read.
Pete
gcrowder2
Posted: Fri Jan 26, 2007 9:09 am Post subject: Anybody using a flux gate compass instead of a DG? |
Hi Pete - Thanks for the steer. I am aware of the Dynon for sure and will
be doing
something like that before too long. I was just looking for something kind
of inexpensive
for now. Also, my hangar is not too secure. Does the Dynon have a quick
removal
feature so one could take it home after flying?
Glenn
[quote]From: "Pete Lawless" <pete(at)lawless.info>
Reply-To: europa-list(at)matronics.com
Subject: RE: Anybody using a flux gate compass instead of a
DG?
Date: Fri, 26 Jan 2007 16:44:08 -0000
Hi Glenn
so
Pete
DuaneFamly(at)aol.com Guest
Posted: Fri Jan 26, 2007 9:26 am Post subject: Anybody using a flux gate compass instead of a DG? |
Glenn,
I am also installing the Dynon in my XS and yes, you can remove it quickly by means of an Allen wrench through the lower left portion of the faceplate. But you must not us the extra screw fitting that they provide in the lower right portion that accesses only from the rear of the unit to lock the display in place.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
gcrowder2
Posted: Fri Jan 26, 2007 10:15 am Post subject: Anybody using a flux gate compass instead of a DG? |
Hi Duane - Thats encouraging - you must have a quick disconnect plug behind
it then. Did that come with the unit?
Glenn
| Quote: | From: DuaneFamly(at)aol.com
Subject: Re: Anybody using a flux gate compass instead of a
DG?
Date: Fri, 26 Jan 2007 12:25:13 EST
Glenn,
by
But
right
place.
Mike Duane A207A
Redding, California
Jabiru 3300
Sensenich R64Z N
| Quote: | From predictions to trailers, check out the MSN Entertainment Guide to the
Academy Awards®
http://movies.msn.com/movies/oscars2007/?icid=ncoscartagline1
Posted: Fri Jan 26, 2007 10:17 am Post subject: Anybody using a flux gate compass instead of a DG? |
Glenn
Not as far as I could see, it looked like a panel mount job bolted in. I
will ask and let you know.
Pete
Posted: Fri Jan 26, 2007 12:27 pm Post subject: Anybody using a flux gate compass instead of a DG? |
Glenn,
The unit comes with a mounting shell that you attach to the panel. It has plugs mounted in the rear and the unit simply slides in and you just use the allen wrench to snug it down.
Would you like some pix?
Mike
Posted: Fri Jan 26, 2007 12:49 pm Post subject: Anybody using a flux gate compass instead of a DG? |
Glenn
A reply from the Dynon user.
"You just undo a jackscrew at the bottom LH corner, which pushes it out an
inch or so, and pull it the rest of the way out of its rack. You then unplug
the D-sub and then the tricky bit: it has a pitot and static connection to
it (we are not using the AoA facility so just the two). In our case you
could pull the neoprene hoses off but I guess that if you wanted to do
frequent removal / replacement it would be best to make some sort of
(reliable) screwed connections, perhaps using AN fittings."
Pete
ami(at)mcfadyean.freeserv Guest
Posted: Fri Jan 26, 2007 2:31 pm Post subject: Anybody using a flux gate compass instead of a DG? |
I have a marine digital compass in addition to the normal standby compass.
It is well damped and sure that it thinks it is accurate. But it isn't.
The self compensating feature doesn't seem to do much either.
It would probably benefit greatly from a remote sensor.
Duncan McF.
