Trottle cables 912ULS
rap(at)isp.com
PostPosted: Tue Jan 09, 2007 6:56 pm    Post subject: Trottle cables 912ULS Reply with quote
I'm haveing trouble with my trottle cable wanting to buckle instead of go back to idle. You are fighting the springs that want to go full trottle on the carbs and the drag in the cable system. The 1/16" cable that comes stock with the plane wants bend right at the swivel on the trottle. My buddy with the Highlander went & spent $150 for a heavy duty 1/8" cable to solve his problem. He also disconected the springs on the carbs. How has other people with Kolbs flying the 912's solved this problem? Rick Pearce Kolb MK3C
PostPosted: Tue Jan 09, 2007 7:09 pm    Post subject: Trottle cables 912ULS Reply with quote
go back to idle. Rick Pearce Kolb MK3C
Been flying 912 and the S on my mkIII since 1994. Never had a
problem. I use one short cable from throttle to splitter under the
left seat. The two long cables, one to each carb. Try to keep my
curves as large as possible. Grease the cables before I put the
system together.
jindoguy(at)gmail.com
PostPosted: Wed Jan 10, 2007 4:36 am    Post subject: Trottle cables 912ULS Reply with quote
Rick, Are your cables of 1 X 19 construction? Much stiffer when pushing a control than cable of finer wire.
Rick
On 1/9/07, Rick Pearce < rap(at)isp.com (rap(at)isp.com)> wrote:[quote] I'm haveing trouble with my trottle cable wanting to buckle instead of go back to idle. You are fighting the springs that want to go full trottle on the carbs and the drag in the cable system. The 1/16" cable that comes stock with the plane wants bend right at the swivel on the trottle. My buddy with the Highlander went & spent $150 for a heavy duty 1/8" cable to solve his problem. He also disconected the springs on the carbs. How has other people with Kolbs flying the 912's solved this problem? Rick Pearce Kolb MK3C
[b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
Steven Green
PostPosted: Wed Jan 10, 2007 5:31 pm    Post subject: Trottle cables 912ULS Reply with quote
Rick,
The cable should be in tension when going to idle, not pushing.
Steven Green
Steven Green
rap(at)isp.com
PostPosted: Thu Jan 11, 2007 4:35 am    Post subject: Trottle cables 912ULS Reply with quote
Steve: Kind Of hard to do on the 912 since the carbs are spring load for
full trottle.
Rick,
Steven Green
MKIIIX040
PostPosted: Thu Jan 11, 2007 8:05 am    Post subject: Trottle cables 912ULS Reply with quote
> " I'm haveing trouble with my trottle cable wanting to buckle instead of
trottle on the carbs and the drag in the cable system"
The throtle cable is in tension whether or not the carb lever is spring loaded to idle or full.
Do like John said- grease it baby, lightly.
While you have it out check to see if one cable strand ( very hard to see) is bent back after rethreading at one time or another.
It happened to me!
Keep your loops large before and after splitter.
My cable pull force was high so I greased everything one part at a time to see why. Everything worked great until I threaded the last end where that one strand fetched up!
Vic
912 Exrta
Maine
MKIIIX040
912UL
Steven Green
PostPosted: Thu Jan 11, 2007 2:28 pm    Post subject: Trottle cables 912ULS Reply with quote
Rick,
My throttle cable pulls the throttle to idle. The springs on the carbs.
take it to full throttle when tension is relaxed on the cable.
Steven
MkIII 912S
N58SG
full trottle.
Rick,
> Steven Green
Steven Green
Dennis.Kirby(at)kirtland.
PostPosted: Fri Jan 12, 2007 8:45 am    Post subject: Trottle cables 912ULS Reply with quote
<< My cable pull force was high so I greased everything one part at a
time ... Vic >>
Vic - What kind of grease did you use for the throttle cables?
Dennis Kirby
New Mexico
MKIIIX040
PostPosted: Fri Jan 12, 2007 1:04 pm    Post subject: Trottle cables 912ULS Reply with quote
time ... Vic >>
Marine Grease (the blue stuff), all I had on hand anyway.
Vic
912 Extra
Maine
MKIIIX040
912UL
APilot(at)webtv.net
PostPosted: Fri Jan 12, 2007 8:54 pm    Post subject: Trottle cables 912ULS Reply with quote
I have used teflon grease that I had on hand that I bought from the
trailer supply store. It is white and seems to work pretty good.
rap(at)isp.com
PostPosted: Sat Jan 13, 2007 6:19 am    Post subject: Trottle cables 912ULS Reply with quote
Richard: I don't know for sure what the cable is it is the stock throttle cable that came with the Kolb kit. 1/16" dia.How is your throttle cable set up? You are running a 912 aren't you?
