Lightning
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List
N1BZRich(at)AOL.COM
PostPosted: Sun Jan 14, 2007 10:10 am    Post subject: Lightning Reply with quote
Hey Lightning folks,
I knew we could generate some message traffic if I just asked for project updates. Thanks to Earl, Brian, Linda, John, Lynn, Rick, Walt and our down under friend, Dennis, for providing some feedback. As you all can see, a few are flying and several other are really getting close. Those that have flown are very pleased with their birds and, as far as I can tell, all those getting close have been pleased with the build process and especially the support in Tennessee. One thing that I think is great is that those that have built the Lightning so far have put in the extra effort to insure top quality airplanes in fit and finish. Outstanding paint jobs, great panels and interiors - it only takes a little extra effort to do it right and the Lightning design certainly deserves that. I think the Lightning builders are going to get a great reputation as a group that produces great looking and great flying airplanes. Congratulations to all of you and the Lightning team in Shelbyville.
Now to answer or comment on some of your messages:
-Brian, I am sure all builders are looking forward to your results with the drag clean up experiments. Hope the stuff I left with Nick for you comes in handy. If you can achieve even half of the cruise improvements that you are looking for you will have been successful. It is a clean design already, but you have zeroed in on those places that I think could be improved on. In the long run, I am sure Nick and Pete will want to incorporate some of your improvements (flap hinges) into the basic design. Keep us informed.
-As to cold weather starting and other engine questions. I am into my second winter since starting to fly my airplane and in the past 13 months I have about 238 hours on this 3300 Jabiru. I couldn't be more pleased with this little jewel of an engine. The only maintenance has been regular oil changes and new plugs at the 100 and 200 hour points. Heck, when plugs cost less than $2.00 each why ever clean a plug. Just replace. Plugs and oil filters ( $4.00 or so) are available at any local auto parts store. Lynn asked about oil leaks (Continentals seem to all leak) and vibrations. I can say I have seen no oil leaks. One thing that Jabiru did right was to use O-rings instead of gaskets - hence, no leaks. Also, the engine is very smooth when running. If you are having a vibration it is either the propeller or spinner that is causing the problem. As to cold weather starting, if you follow the published procedures, no problems down to temperatures where I really don't like to fly. (I should have moved to Florida many years ago.) Basically, for a cold weather start, pull the choke fully on (aft) and the throttle completely closed (also aft). Then pull the propeller through 6 to 8 blades, complete your preflight, strap in, and start the engine. As I said, this published procedure has gotten me through a winter and a half with no problems. Granted, in Virginia we really don't get the really cold weather, but I have started the engine down to about freezing. One other thing I do on a regular basis when I know my next start might be in cold temperatures - I keep a light bulb under the engine (you can get it in underneath by the nose gear leg) with a blanket over the cowling and cowling intake plugs in place. This seems to help and probably raises the engine compartment temperature at least 10 degrees or so above ambient outside air temperature. I used to do this trick with my Bonanza using two light bulbs and I could raise the temp around the engine from 15 to 20 degrees. Engine pre-heaters also work, but the light bulb is simple and basically is "cheap". Just takes a few seconds before you close the hangar door and a few seconds more to remove before your next flight. PS - don't let a 100 watt bulb touch your bottom fiberglass cowling for 2 1/2 weeks while you drive your new Corvette to Colorado or you will end up with a small brown spot on the outside of your bottom cowling. Yep, I did that. I now use a 60 watt bulb. In fact, don't let the bulb touch the fiberglass at all- rest it on the exhaust or use some other way to suspend it near the bottom of the engine.
-Dennis, I sent photos of my auto pilot servos installation several months ago. I take it that you did not get those or that you could not display them. I will find have to find them again and resend. The TruTrak system is great.
Folks, keep the info flow ongoing. Remember that the list included those that have built, those that are building, those that are considering building, and those that are just gathering information to help them decide at some later date what airplane to build. All can benefit from the list - so don't hesitate to put in your $.02 worth.
Blue Skies,
Buz
- The Matronics Lightning-List Email Forum -
http://www.matronics.com/Navigator?Lightning-List
cdewey6969(at)yahoo.com
PostPosted: Sun Jan 14, 2007 12:44 pm    Post subject: Lightning Reply with quote
Great to hear updates from everybody. Curious how
Dennis Down Under is doing with the installation of
the 8 cylinder Jabiru. Innodyn has an inexpensive
turbine- anyone know whether the Lightning could take
this engine? I know the Vne is 205 or so, but any
guesses as to what the plane will do with a turbine?
Could the plane handle a 250 mph cruise??? Afterall,
ther is a guy with a Lancair Legacy racing in Reno
with a jet engine and beating most everyone. If the
Lightning is stressed to +-9 g's, why can't it handle
250+mph!!! I plan on flying 2000 mile legs regularly
in my Lightning, so speed is important. BRS parachute
will be in my plane, so I would feel safe going faster
than the Vne. Charles in Virginia (currently
building a Lightning)
I just asked for
Lightning team in
Shelbyville.
Keep us informed.
engine.
great.
Blue Skies,
Buz
Now that's room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
http://farechase.yahoo.com/promo-generic-14795097
IFLYSMODEL(at)aol.com
PostPosted: Sun Jan 14, 2007 1:46 pm    Post subject: Lightning Reply with quote
Hey Buz and the rest of you Lightning folks: I really appreciate your comments. I am just a wannabe for the moment. And most likely until I can convince my wife we need to sell the Bonanza (N2JX). It has a lot of modifications, including an IO-550 and 3400 lb gross weight, so if any of you know of someone that is looking for a great airplane, send them my way.
I had sent a request for a test flight to the lightning home, but I suppose they will not read the e-mail until sometime next week. Since the light sport expo was in Sebring (about 20 miles from here) I had hoped for a good chance for a flight.
I will continue to lurk on this site, and see what all I can learn.
Lynn Nelsen
dashvii(at)hotmail.com
PostPosted: Sun Jan 14, 2007 2:13 pm    Post subject: Lightning Reply with quote
Interesting question. I am familiar with Innodyn and they have a 185hp
turbine that weighs less than 180lbs, so the weight is about right. There's
a foreign aircraft manufacturer, can't recall the name, something like an
"Excite" or "Extreme" which looks like a Lightning with tip tanks, a 180hp
turbine, tailwheel, 5 bladed GT prop. It cruises right at 300mph and top
speed was about 320mph I think. I believe fuel burn was about 10 gph. I'll
have to see if I can find the site. Think the company might have tanked
since they didn't have much updated.
As for a 250mph cruise. Well it's been dive tested to about 240 something
true. I have not been up that high though, I've only been to about 200.
Nick might can give you an idea for a "what if" airplane. I know that
Innodyn also makes a 165 hp version. Perhaps one of thes on the plane could
work. I think that a tailwheel version could also be possible. I think
that you'd want that to get the size prop you need on that thing. Very cool
idea though. Let me know if you end up trying some things like this, would
be an interesting project. Brian W.
Dave vs. Carl: The Insignificant Championship Series.  Who will win?
N1BZRich(at)AOL.COM
PostPosted: Sun Jan 14, 2007 2:25 pm    Post subject: Lightning Reply with quote
Hey Charles,
Where in Virginia are you? I am based at JGG and FKN.
As to your questions and aspirations for a 250 mile per hour cruise and a 200 mile range, I think you should look at a Lancair IV or some other aircraft designed for that mission. The Lightning Vne is 208 and it is stressed for +5, not +9. Some of the individual structures of the Lightning may have been tested to 9, but the data / information is quite clear that it is a 5 G airplane.
Of course, it is a homebuilt and you the builder can make changes as you see fit, but then it becomes a "Charles Special" and not a Lightning. The Innodyn turbine is certainly an interesting engine and the one of around 205 HP could probably achieve the speeds you are talking about if you had a clean airframe, the right propeller (expensive), and a perfectly designed air inlet which would probably require lots of testing and changes to optimize the air flow to the turbine. Of course, fuel consumption is higher than for an internal combustion engine, so you would have to GREATLY increase the capacity of your fuel tanks to even match the current Lightning range. A 2000 mile XC leg that you mentioned would probably require some sort of external tanks in order to increase fuel capacity to the amount you would require. So with all these changes, why not just start with an airplane design that is aimed at the mission you describe.
Remember the mission goals for the Lightning were more along the lines of - a great looking safe airplane that is fast and economical to build, and fast and economical to fly. The current Lightning certainly meets those goals.
Blue Skies,
Buz
PostPosted: Sun Jan 14, 2007 3:13 pm    Post subject: Lightning Reply with quote
By "leg" I didn't mean that I actually wanted to fly
2000 miles at once. I can break the trip up as many
times as necessary, so extra gas storage for the
Lightning wouldn't really be necessary. I did some
searching on Innodyn's website and saw someone who put
an Innodyne turbine in a Cub if I remember correctly.
Another 165 HP Innodyn turbine was put in an RV4 and
there is video of it and the Cub on Innodyn's website.
The sound of the turbine really is sweet! He was
having trouble making the brand new engine run
efficiently and it was determined that the engine
wasn't getting enough air, so a larger intake opening
in the cowling was made for it, and then it operated
perfectly. It is interesting to note that Innodyn
suggests that their turbines run most efficiently when
at full power setting. They are burning about 7
gallons per 100 hp (horse power). If the Lightning can
cruise at least 50mph faster, then the extra fuel burn
would be worth it. I am going to call Innodyn on
Monday to see if they think it can be installed in a
Lightning and if so, what kind of cruise speed might
happen. Interestingly, the turbine can also be used
for helicopter operation; they have a list of some
planes it can definitely be used in on the Innodyn
website- mostly RV's and canard type planes are
listed. If it can go in an RV4 why not in a Lightning?
(at)yahoo.com> wrote:
<cdewey6969(at)yahoo.com>
take
handle
parachute
faster
if
> I just asked for
getting
far
to
> Lightning team in
> Shelbyville.
> messages:
a
to
> Keep us informed.
and
be
has
Heck,
was
starting,
where
8
do
I
nose
place.
temperature
will
I
> engine.
> great.
benefit
> Blue Skies,
> Buz
hotels
fit.
browse
Subscriptions page,
FAQ,
=== message truncated ===
Any questions? Get answers on any topic at www.Answers.yahoo.com. Try it now.
PostPosted: Sun Jan 14, 2007 3:26 pm    Post subject: Lightning Reply with quote
Brian, I google'd "excite airplane" and nothing but
radio controlled planes came up. Any chance that the
plane you were thinking of is the freebird extreme? It
is at www.freebirdextreme.com. It's mock-up in a
trailer has been at all the air shows. The jet version
of that plane is at least a couple of years off from
being made, if they ever go through with it. I don't
think they even have the LSA or experimental version
flying yet. The company just traded hands in the fall.
Do you or anyone out there know of 2-seater light jet
that is fuel efficient and fast without spending a
fortune (and with BRS)? Would love to make the
Lightning as close to super fast as possible and would
be willing to be the guinea pig.
--- Brian Whittingham <dashvii(at)hotmail.com> wrote:
Whittingham" <dashvii(at)hotmail.com>
browse
Subscriptions page,
FAQ,
Web Forums!
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives.
http://tools.search.yahoo.com/toolbar/features/mail/
Daniel Vandenberg
PostPosted: Sun Jan 14, 2007 3:33 pm    Post subject: Lightning Reply with quote
IMHO the Innodyne should be viewed with a healthy skepticism. Likely to have VERY HIGH fuel burns at typically used altitudes. If you could get up to the FL's and stay up for a long time it might have potential. No way to get that much fuel into a Lightning.
Please review this thread on Van's Airforce. First customer Innodyne RV-8 (Jim Benson in Colorado) has posted a couple of times. The lastest is that "We lost an inch off the turbine wheel." Translation...the engine is already being rebuilt after just a few hours of early testing.
http://www.vansairforce.com/community/showthread.php?t=12103
Dan
Brian Whittingham <dashvii(at)hotmail.com> wrote:[quote] --> Lightning-List message posted by: "Brian Whittingham"
that you'd want that to get the [quote][b]
PostPosted: Sun Jan 14, 2007 4:29 pm    Post subject: Lightning Reply with quote
Charles,
Interesting airplane, but not the one that I'm thinking of. I've got a
picture of it saved at work and I'll see if I can find what the company is
tomorrow. Can't remember at all the name of the company. I know it's
overseas though, Brian W.
Type your favorite song.  Get a customized station.  Try MSN Radio powered
by Pandora. http://radio.msn.com/?icid=T002MSN03A07001
Daniel Vandenberg
PostPosted: Sun Jan 14, 2007 4:50 pm    Post subject: Lightning Reply with quote
BRS parachute
Charles....
Here is some food for thought on the BRS. Be careful not to let the presence of a BRS breed a false confidence.
I was just reading last night in Flying magazne (Feb 2007 Richard Collins p30) about Cirrus accidents and the unexpectedly high accident rate of this supposedly "safer" airplane. The safety record has come in just about like the much older retractables in the same class. If you factor out the BRS "saves" that have been documented, the Cirrus safety record would be much worse than Bonanzas/Comanches/etc.
One (among several) of the concerns about the Cirrus safety record is that pilots may be pushing the safety envelope somewhat because of the BRS security blanket. This may, in effect, negate the safety advantage of having the parachute on board. Mr. Collins wondered whether the BRS may be similar to the second engine on a light twin...leading pilots to do things they would not do with a single engine...leading them into trouble.
Seems to me pilots should fly the same (carefully and conservatively) with or without the BRS. Then, in the rare circumstance of need (mid-air collision, structural failure, power-loss over rough terrain) the BRS improves the odds of survival.
But "pushing the performance envelope" because of the presence of the BRS needs to be carefully considered...and probably discarded..as a factor in flight planning and flying.
My $.02
Dan
Need Mail bonding?
Go to the Yahoo! Mail Q&A for great tips from Yahoo! Answers users. [quote][b]
N1BZRich(at)AOL.COM
PostPosted: Sun Jan 14, 2007 6:15 pm    Post subject: Lightning Reply with quote
In a message dated 1/14/2007 6:15:50 P.M. Eastern Standard Time, cdewey6969(at)yahoo.com writes:
Charles,
If I am not mistaken, the Innodyn runs at 100% power all the time. The controlled pitch propeller is how they vary the thrust. This is what I remember when I was reading up on their company several years ago. I had thoughts of doing what you are thinking about, but I was going to use an RV as a test aircraft - not the Lightning.
Blue Skies,
Buz
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Lightning-List All times are GMT - 8 Hours
You cannot download files in this forum
