Richard Pike
Posted: Mon Jan 15, 2007 9:34 am Post subject: Oil pump |
Got an interesting situation with the oil pump on the Firestar II's 582. Apparently when sitting for a day or so, oil appears to be slowly forcing it's way through the oil injection pump and into the intake manifold of the carb closest to the PTO end. For a while, this engine has tended to have a lot of oil accumulate in the aft end of the intake silencer and sometimes drool out, making a mess. Lately it has sometimes exhibited a tendency to run rough at startup, blowing a lot of oil smoke for about five minutes and then clearing up and being normal. Today I found out why, went out and pulled the float bowls off, and the rear one was purple from the oil that had found it's way into the float bowl and created about a 20:1 gas/oil mix.
The pump works normally in flight, it just allows oil to seep through while sitting in the hangar. Has anybody else ever had a situation like this, and if so, what did you do to fix it? I do have a spare oil pump, graciously given to me by one of our listers, and will probably go ahead and install it, but am I overlooking something??? (Always a good possibility...)
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Steven Green
Posted: Mon Jan 15, 2007 4:33 pm Post subject: Oil pump |
Richard,
I had this same problem with my 582s. The solution is to fly more often. I never quite convinced my wife this was the only solution but it will work. :<)
Steven
Richard Pike
| [b]
_________________ Steven Green |
Posted: Mon Jan 15, 2007 4:56 pm Post subject: Oil pump |
Richard,
A low cost solution would be to place a shut off valve ahead of the pump, and add a preflight check flag.
Jack B. Hart FF004
Winchester, IN
