bmeyette
Posted: Thu Mar 15, 2007 9:40 am Post subject: Molex connector sexual orientation |
I was putting together some Molex connectors for the first time. The plastic parts have a male and a female half. The terminals also are either male or female.
However, I am a bit unclear as to how to mate these parts. Intuition would tell me that the male terminals go into the male plastic part. Yet, I have a feeling it's actually the other way around.
Is a male metal terminal supposed to go into the male plastic housing, or the female plastic housing, or doesn't it matter?
thanks,
brian
_________________ Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm |
ronr(at)advanceddesign.co Guest
Posted: Thu Mar 15, 2007 9:54 am Post subject: Molex connector sexual orientation |
Brian
Here is the molex web site. You should be able to find your answer here.
Ron Raby
http://www.molex.com
rhdudley1(at)bellsouth.ne Guest
Posted: Thu Mar 15, 2007 9:55 am Post subject: Molex connector sexual orientation |
Brian,
I believe that you can think of the male pins being protected by what
you call the "female" shell. The female receptacle pins are protected by
being internal in the "male" shell. So both are mechanically shielded by
their shells.
Hope this helps.
Richard Dudley
RV-6A flying
thanks,
brian
RV-7A QB tipup, Eggenfellner supercharged STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM reserved
http://forums.matronics.com/viewtopic.php?p=100754#100754
Bruce(at)glasair.org Guest
Posted: Thu Mar 15, 2007 10:05 am Post subject: Molex connector sexual orientation |
The male pins go in the female connector. Such is life!
Bruce
www.glasair.org
echristley(at)nc.rr.com Guest
Posted: Thu Mar 15, 2007 10:30 am Post subject: Molex connector sexual orientation |
While technically it will work either way, the convention is that boys
go with girls. Your intuition is correct in this case.
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o http://ernest.isa-geek.org |
klehman(at)albedo.net Guest
Posted: Thu Mar 15, 2007 11:49 am Post subject: Molex connector sexual orientation |
Yes that is what I do.
In addition though I always arrange that the male shell (plastic
surrounds each female pin) is wired to the side that is hot (hardwired
to aircraft power). That insures that two pins can't be pushed together
and short out the power source. These are low cost connectors and that
can happen even sometimes while trying to connect the two halves.
Ken
Murphy Rebel, subaru ej22, built with cheap grid power in a shop heated
by wood grown with solar power...
Richard Dudley wrote:
Quote: |
<rhdudley1(at)bellsouth.net>
Brian,
by being internal in the "male" shell. So both are mechanically
shielded by their shells.
Hope this helps.
Richard Dudley
RV-6A flying
bmeyette wrote:
> <brianpublic2(at)starband.net>
> thanks,
> brian
> N432MM reserved
n801bh(at)NetZero.com Guest
Posted: Thu Mar 15, 2007 3:01 pm Post subject: Molex connector sexual orientation |
Don't ask,,, don't tell...
Sorry, i had to say it.. <G>
I agree with Ken, the male prongs can short if touched to something so make that the load side. The line side should be the female electrical fittings.
Ben Haas
N801BH
www.haaspowerair.com
-- Ken <klehman(at)albedo.net> wrote:
--> AeroElectric-List message posted by: Ken�<klehman(at)albedo.net>
Yes that is what�I do.
to�aircraft power). That insures that two pins can't be pushed together
and short out the power source. These are low�cost connectors and that
can happen�even sometimes while trying to connect the two halves.
Ken
[quote] --> AeroElectric-List message posted by: Richard Dudley
Brian,
�you call the "female" shell. The female receptacle pins are protected
by being internal in the "male" shell.�So both are mechanically
shielded�by their shells.
Hope this helps.
Richard Dudley
RV-6A flying
bmeyette wrote:
> --> AeroElectric-List message posted by: "bmeyette"
> plastic parts have a male and�a female half. The terminals also are
> However, I am a bit�unclear as to how to mate these parts.
> Intuition would tell�me that the male terminals go into�the male
> plastic part. Yet, I have a feeling it's actually the�other way around.
> Is a�male metal terminal supposed to go into the male plastic
> housing, or the female plastic housing, or doesn't�it matter?
> thanks,
>�brian
> Brian�Meyette, Cornish, NH
> RV-7A�QB tipup, Eggenfellner supercharged STi engine, MT CS prop, all
> glass�day/night/IFR panel, being built with solar�and wind power
> N432MM reserved
> http://brian76.mystarband.net/RV-7Aho================================================p;Use the Matronics List Features Navigator&nbshive Search & Download, 7-Day Browse, =============================================== [quote][b]
rdunhamtn(at)hotmail.com Guest
Posted: Sat Mar 17, 2007 4:34 am Post subject: Molex connector sexual orientation |
Brian,
It doesn't matter at all!
When the two halves are mated together, there is no chance of a short
between the pins and you ALWAYS disconnect the BAT ground before fooling
with ANYTHING elctrical, don't you???
I use these goodies a lot and I seldom put all of one "sex" on one end. I
mix them up so that I can't accidentally connect two connectors that don't
belong together. For instance, on my Blue Sea fuse block I twisted pairs and
assigned the "1" fuse to the "1" pin on my "molex" connector. The
corresponding ground (built in to the Blue Sea fuse block) went to the "2"
pin and so on. Grounds are male and +12V are female. There are 6 fuses on
one side numbered odd 1 through 11 and 6 on the other side numbered even 2
through 12. So... on the even side, the "1" pin is ground (male) and the "2"
pin is +12V (female) and so on... Both shells are female so I cannot
accidentally connect the two together. Besides, if the BAT ground is
disconnected, it wouldn't hurt to do so anyway! Each wire or bundle is
clearly labeled at the connector.
I just make each one unigue and there is a good mix of 2, 3, 4, 6, 9 and 12
pin connectors. No two are the same so it isn't possible to connect anything
wrong. If it fits, it right! Always read the label. And ALWAYS disconnect
BAT ground before working on your plane! Simple.
Rodney in Tennessee
i'm making a difference.�Make every IM count for the cause of your choice.
Join Now.
