capedavis(at)yahoo.com Guest
Posted: Thu Jan 11, 2007 7:20 am Post subject: Transition aircraft -> to Kolb Firestar |
John, I see you live in Nevada perhaps there are glider schools near you? If you cant find a 2 place Kolb I would recomend a Schwitzer 2-33 , the most comman glider trainer I learned to fly in one while I was building my KXP and had no problem transitioning to the Kolb from the 2-33, When I had an engine out later on there was no panic as the KXP flys beautiful with engine out .Just my 2 cents .Chris Davis
Posted: Thu Jan 11, 2007 8:56 am Post subject: Transition aircraft -> to Kolb Firestar |
I would think a Challenger would be good for transistion too...>>
Hi,
for what its worth I changed from a Tail wheel Thruster to a Trcycle wheeled
Challenger without any problem . Apart from insufficient tension on the
throttle which closed when I took my hand off it to apply the flaps/trim.
The control for that was above and behind my right shoulder. This was
disconcerting trying to make it back into a small field on my first flight.
I did a go-round and managed it easily if not tidily next time round. I
always held off as if I was landing a tail dragger and she just sank on..
Changing from the Challenger to the Xtra was a non event. I taxied around a
bit to get used to the different `picture` and did a few flights with an
instructor and just did it. I think keeping the speed up was rather more
important in the Xtra. The Challenger would just mush if the speed was low
but the Xtra tends to just let go.
If you are coming from normal GA some 2 seat time is only good sense because
the difference in inertia takes some getting used to. but from another
ultralight, no sweat.
Cheers
Pat
a58r(at)verizon.net Guest
Posted: Thu Jan 11, 2007 9:30 pm Post subject: Transition aircraft -> to Kolb Firestar |
John,
This form of training, Crow Hopping, is great, IF you already have
flying experience, It's not a good ida for the novice because all of
a sudden he's 10' up, and can't figger out how to land!
regards,
Bob N. FireFly 070 Old Kolb
APilot(at)webtv.net Guest
Posted: Fri Jan 12, 2007 4:26 am Post subject: Transition aircraft -> to Kolb Firestar |
Re: High speed taxi..........they can be dangerous. It is easier in a
tricycle gear airplane. Kolbs are easy to fly for a tail dragger, but
they are still tail draggers and required caution. Some practice on a
flight simulator might help. I like the J-3 Cub on Microsoft's FS 2004
simulator.
jindoguy(at)gmail.com Guest
Posted: Fri Jan 12, 2007 4:47 am Post subject: Transition aircraft -> to Kolb Firestar |
John, In a tricycle gear airplane high speed taxiing is no big deal. In a tail dragger, even one as nicely mannered as a Kolb, welllllllllll, hmmmm. I'm not an expert by any stretch, but I'd go with the nays. The reason is pretty simple. While the tires are still touching the ground a taildragger is unstable because the CG is behind the main gear. Cross winds and ham handed control inputs can put you out of control too quickly to recover. Once those tires leave the ground stability returns and you are much safer.
Rick
On 1/11/07, John H Murphy <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)> wrote: | Quote: | --> Kolb-List message posted by: "John H Murphy" <jhm9812(at)yahoo.com (jhm9812(at)yahoo.com)>
I've had several people e-mail with the suggestion of doing high speed taxi runs on a long runway. The idea is to get up off the deck a couple of feet and bring her down. After enough practice of these enough high speed runs..take off. Any comments on this?
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
Posted: Fri Jan 12, 2007 7:38 am Post subject: Transition aircraft -> to Kolb Firestar |
high speed taxi runs on a long runway. . Any comments on this?>>
Yeah! Dont do it.
Taxi around until you are familiar with rudder, brakes and throttle. Then,
get just fast enough to just raise the tail and give youself some rudder
control. Only try it if the wind is dead ahead. If you take off get away
from the ground as quickly as possible and then only if you know how to fly.
If you can fly, go for it and get some height. Its the ground thats hard,
not the air. If you can`t fly, stay away from the plane until someone
checks you out.
I know you can do it all your own but most of the pilots who have taught
themselves to fly, and there are some on this list, do not recommend it.
Cheers
Pat
WillUribe(at)aol.com Guest
Posted: Fri Jan 12, 2007 8:06 am Post subject: Transition aircraft -> to Kolb Firestar |
John,
I have 300 hours on my FireStar II and I wouldn't do it, too scary for me.
Will Uribe
FireStar II N4GU
El Paso, TX but working in Sonora, Mexico
http://home.elp.rr.com/airplane/
kkcmax(at)msn.com Guest
Posted: Fri Jan 12, 2007 12:43 pm Post subject: Transition aircraft -> to Kolb Firestar |
thats how you wreck a good plane its the worst part of tacking off and
landing at high speed near ground in normal opp. you speed up /slow down
very quickley with high speed taxis you are at risk to have some thing go
wrong at a fast speed for much longer get instruction in a light tail
dragger piper taylorcraft kolb drifter ect. it will save you money and plane
repairs from stalls ground loops ect airplanes are not toys they can and
haved killed and in a kolb you can be 100 feet off the ground before you
know you left
| Quote: | From: "John H Murphy" <jhm9812(at)yahoo.com>
Reply-To: kolb-list(at)matronics.com
Subject: Re: Transition aircraft -> to Kolb Firestar
Date: Thu, 11 Jan 2007 21:13:06 -0800
http://forums.matronics.com/viewtopic.php?p=87016#87016
Type your favorite song. Get a customized station. Try MSN Radio powered
by Pandora. http://radio.msn.com/?icid=T002MSN03A07001
Ed in JXN
Posted: Fri Jan 12, 2007 11:15 pm Post subject: Transition aircraft -> to Kolb Firestar |
Hi Keith,
That's one looong damn sentence. Are your caps and punctuation keys
all broke? ;^)
Ed in JXN
Do not archive.
Posted: Sat Jan 13, 2007 3:28 am Post subject: Transition aircraft -> to Kolb Firestar |
I did not know this was enlish class thanks and get a life
[quote]From: "Ed Chmielewski" <edchmiel(at)mindspring.com>
To: <kolb-list(at)matronics.com>
Subject: Re: Re: Transition aircraft -> to Kolb Firestar
Date: Sat, 13 Jan 2007 02:15:23 -0500
Hi Keith,
keys all broke? ;^)
Ed in JXN
Do not archive.
Posted: Sat Jan 13, 2007 4:57 am Post subject: Transition aircraft -> to Kolb Firestar |
Keith, No need to get upset. What Ed was pointing out is that your posts are virtually unreadable, and as such do not impart the information you wish to offer. 'Part of life is the need to communicate easily and accurately.
As I told my ex wife, if words and phrases have multiple and contradictory meanings, I choose interpretation 49, "Please go get your pistol and blow my F****** brains out." As you can probably see, my communications skills weren't too good either, then. I really think they're much better now.
Rick
On 1/13/07, Keith Callfas <kkcmax(at)msn.com (kkcmax(at)msn.com)> wrote:[quote] --> Kolb-List message posted by: "Keith Callfas" <kkcmax(at)msn.com (kkcmax(at)msn.com)>
[quote]From: "Ed Chmielewski" < edchmiel(at)mindspring.com (edchmiel(at)mindspring.com)>
Reply-To: kolb-list(at)matronics.com (kolb-list(at)matronics.com)
To: <kolb-list(at)matronics.com (kolb-list(at)matronics.com)>
--> Kolb-List message posted by: "Ed Chmielewski" < edchmiel(at)mindspring.com (edchmiel(at)mindspring.com)>
Hi Keith,
keys all broke? ;^)
Ed in JXN
Do not archive.
Posted: Sat Jan 13, 2007 5:00 am Post subject: Transition aircraft -> to Kolb Firestar |
Rick
Hi Keith,
keys all broke? ;^)
Ed in JXN
Do not archive.
Posted: Sat Jan 13, 2007 11:43 am Post subject: Transition aircraft -> to Kolb Firestar |
youpepole are like a bunch of old women this is about airplanes nothing else
there is probley a place on line were your crtiques may be welcome but not
by me thanks you doint have to read my posts if they errateeed you
[quote]From: "Richard Girard" <jindoguy(at)gmail.com>
Date: Sat, 13 Jan 2007 06:53:23 -0600
are
my
Rick
> >Hi Keith,
> >keys all broke? ;^)
> >Ed in JXN
> >Do not archive.
Posted: Sat Jan 13, 2007 11:58 am Post subject: Transition aircraft -> to Kolb Firestar |
I haved unsubscribed to your old lady chat club thanks for saving me time
reading your non aviation related posts
[quote]From: "Keith Callfas" <kkcmax(at)msn.com>
Date: Sat, 13 Jan 2007 13:43:08 -0600
else there is probley a place on line were your crtiques may be welcome but
not by me thanks you doint have to read my posts if they errateeed you
>are
>to
>my
>Rick
>> >Hi Keith,
>> >keys all broke? ;^)
>> >Ed in JXN
>> >Do not archive.
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Sat Jan 13, 2007 12:10 pm Post subject: Transition aircraft -> to Kolb Firestar |
Another Satisfied customer!!!
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
Richard Pike
Posted: Sat Jan 13, 2007 12:24 pm Post subject: Transition aircraft -> to Kolb Firestar |
Shucks, if only we were iliterate - illuterate - ilutarate -
if only we didn't know how to rite gud 2 lik hem, he'd still be here...
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
biglar
Posted: Sat Jan 13, 2007 2:31 pm Post subject: Transition aircraft -> to Kolb Firestar |
Adios, M.F. We enjoyed you about as much. Do not Archive.
Larry Bourne
Santa Fe, NM
www.gogittum.com
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
planecrazzzy Guest
Posted: Sat Jan 13, 2007 4:34 pm Post subject: Re: Transition aircraft -> to Kolb Firestar |
Well said Big Lar...
Gotta Fly...
Mike in MN
Posted: Sat Jan 13, 2007 5:10 pm Post subject: Transition aircraft -> to Kolb Firestar |
Kolbers,
Most days, I really like this list.
Jack B. Hart FF004
Winchester, IN
Richard Pike
Posted: Sat Jan 13, 2007 5:25 pm Post subject: Transition aircraft -> to Kolb Firestar |
Ever onct inna while the great Big Juke Box of Life rejects a Slug.
regards,
