kuffel(at)cyberport.net Guest
				 Posted: Thu Feb 02, 2006 11:24 pm    Post subject: No Title |
				DVD asks:
 <<don't need the "tube" because the bulkhead fitting is forward of the
 nose about 7/8" and should be in undisturbed air?>>
 As in most things aeronautic, "not exactly".  7/8" in front of the wing or
 nose cone the air is relatively undisturbed *relative to the surface*.  In
 other words, almost static.  Unfortunately, what you need to measure is
 air undisturbed relative to the ground (+/- wind of course).  The general
 rule is to reach such air you should be as far away from the nearest
 surface as the radius of curvature of that surface.
 This effect caused a very low and nervous first flight for a friend in his
 new Mark III.  He had mounted a commercial combined static/pitot probe on
 the front of his nose cone.  It was about 6 " long which is more than
 enough for a wing mounting but in front of the much larger radius nose
 cone put it in stagnant air.  The resulting low pitot pressure had him
 thinking he was on the verge of stall all the way around the pattern when
 it turns out he was doing over 80 mph.
 The good news is you don't have to abide by the "general rule" to get
 useful, repeatable airspeed indications.  The airplane will stall at the
 same indicated airspeed at the same g loading every time.  Just don't
 expect the airspeed to be accurate or the same error through out its
 range.  Use a GPS to find out the actual speed of your 1 g stall and then
 use the GPS to find out which indicated airspeed is 1.3 times the stall
 speed.  This indicated speed is then your normal approach speed (says the
 FAA).
 My friend increased the range of his indicated airspeeds by disconnecting
 the static part of the commercial probe and using the interior of the nose
 cone as his static source.  This worked fine except for the errors in
 caused in his altimeter.....
 Tom Kuffel
 Whitefish, MT
 Building Original FireStar
