owl40188(at)yahoo.com Guest
Posted: Wed Jan 17, 2007 2:39 pm Post subject: Window Trim |
Has anyone installed the fiberglass window trim from Accuracy Avionics? I am trying to decide whether to get them or not.
Niko
40188
Fun with fiberglass
Deems Davis
Posted: Wed Jan 17, 2007 3:14 pm Post subject: Window Trim |
If you haven't installed your windows yet, it's not all that hard to
make you're own. Gary Speceter told me how (at) Osh last year and I made
some up for me. check here for how it did it.
http://deemsrv10.com/43-windowrings.htm.
Depending on how Accuracy trimed the openings for the windows, there
could be some variance between planes.
Deems Davis # 406
Finishing - ( A Misnomer ! )
Niko wrote:
| Quote: | Has anyone installed the fiberglass window trim from Accuracy
Niko
40188
Fun with fiberglass
rv10builder(at)bellsouth. Guest
Posted: Wed Jan 17, 2007 3:41 pm Post subject: Window Trim |
I sure wish I had known that little trick of Deems prior to installing
my rear windows! Well...at least it's not too late for the remaining
three. So what are they charging for the trim? I sent them an e-mail a
couple of weeks ago and didn't get a response.
Niko
40188
Fun with fiberglass
Posted: Wed Jan 17, 2007 3:42 pm Post subject: Window Trim |
Brian
#40308
Niko
40188
Fun with fiberglass
Posted: Wed Jan 17, 2007 4:35 pm Post subject: Window Trim |
Deems,
Thats very nice. I will try that also.
By the way, I believe the cost from Accuracy is $295 for a set. I am not sure how many you get though. I don't think you get the windshield fairing it might only be the two side windows in the Cabin Cover.
Niko
40188
LarryRosen
Posted: Wed Jan 17, 2007 5:05 pm Post subject: Window Trim |
So Deems, when you bend the fiberglass over the window towards the
outside. So the frame makes the window opening slightly smaller.
What did you use to trim the "green" fiberglass flush with the outside,
just a razor blade?
Did you use plastic wrap as peel ply to smooth the inside?
Larry
Deems Davis wrote:
Deems Davis # 406
> Niko
> 40188
> Fun with fiberglass
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Wed Jan 17, 2007 5:34 pm Post subject: Window Trim |
From the looks of their site you get 5 pieces:
http://www.accuracyavionics.com/v1/fiberglassoptions.html
Brian
Niko wrote:
[quote] Deems,
Cover.
Niko
40188
rvbuilder(at)sausen.net Guest
Posted: Wed Jan 17, 2007 6:26 pm Post subject: Window Trim |
An old scissors (still sharp but not your significant others favorite)
is your best bet.
Michael
Deems Davis
Posted: Wed Jan 17, 2007 7:42 pm Post subject: Window Trim |
I just used a razor blade to trim the FG when green. It's a timing sort
of thing, too soon and it's gooey, too late and its' ..... too late. I
didn't use anything on the inside surface as my intent is to cover them
with Tweed auto upholstery fabric, same as the headliner/ohead console..
Deems Davis # 406
Larry Rosen wrote:
outside. So the frame makes the window opening slightly smaller. What
just a razor blade? Did you use plastic wrap as peel ply to smooth the
inside?
Larry
> Deems Davis # 406
>> Niko
>> 40188
>> Fun with fiberglass
