Pre Start Procedure
info(at)usjabiru.com
PostPosted: Fri Jan 19, 2007 11:51 am    Post subject: Pre Start Procedure Reply with quote
Hi All,
In response to lots of inquiries from customers I have added a Pre Start Procedure to the Tech Tips section of the Jabiru USA web site www.usjabiru.com. This is the procedure we use before the first start of a Jabiru engine.
Pete Krotje
Jabiru USA Sport Aircraft, LLC
hawk(at)digisys.net
PostPosted: Fri Jan 19, 2007 4:47 pm    Post subject: Pre Start Procedure Reply with quote
Hello Pete,
One of the fellows at my airport was told that when motoring his new engine with the starter to pre-oil it prior to first start, the spark plugs that are removed should remain attached to the plug wires, and the plug bodies left in contact with an engine grounding surface. I believe that one of the Technical staff in Tennessee advised this, presumably because he felt that firing the ignition system without a load could cause some type of damage to the coils.
Is this still a valid concern?
Thank you very much,
Hawkeye Hughes, Polson MT
jim(at)jabirupacific.com
PostPosted: Fri Jan 19, 2007 7:33 pm    Post subject: Pre Start Procedure Reply with quote
Hello Hawkeye
I simply ground the P leads on the coils to keep them from energizing while your spinning the motor
Jim McCormick
Jabiru Pacific LLC
255 W Fallbrook 202B
Fresno, CA 93711
Office 559-431-1701
Fax 559-233-3676
www.jabirupacific.com [quote] --
