Strobe Light Selection
mwcreek(at)frontiernet.ne
PostPosted: Fri Jan 19, 2007 12:01 pm    Post subject: Strobe Light Selection Reply with quote
I'm about to purchase a strobe/nav/position light kit. Can anyone tell
me if it is better to use an Aeroflash system with the two power
supplys monted in each wing or say a Creative-Air kit with one power
supply that runs sheilded cable the legth of the wing?
Anyone have any comments on either manufatures product?
MIke C.
larry(at)macsmachine.com
PostPosted: Fri Jan 19, 2007 1:10 pm    Post subject: Strobe Light Selection Reply with quote
Mike,
I've got strobes and power packages in the tips of my wings. Don't know
about reliability issues after 90 hours flight time and 4 years
installed yet,
but the idea of having a wing with more mass at the tips seems a good
idea because of in flight convective. I was surprised at the stability
of my HDS
and the way it cuts through turbulence. Not at all like the C150 I used
to fly. A convective day it would wear you out. The extra weight in the
tips along with usual 6 or 8 gallons in the wing tanks might just be a
factor.
Larry McFarland at www.macsmachine.com
mwcreek(at)frontiernet.net wrote:
<mwcreek(at)frontiernet.net>
MIke C.
glastar(at)gmx.net
PostPosted: Fri Jan 19, 2007 1:53 pm    Post subject: Strobe Light Selection Reply with quote
Hi Mike,
I had Aeroflash wingtip PS in my Glastar, on one of them the main
condenser failed, as they're custom made you need to get them swapped by
the manufacturer 50$ ticket. Meanwhile I've a central PS with the set
from GS-Air and I'm happy, the Aeroflash lasted about 100hrs, the GS-Air
have over 150 on it by now.
br Werner
tell me if it is better to use an Aeroflash system with the two
power supplys monted in each wing or say a Creative-Air kit with one
power supply that runs sheilded cable the legth of the wing?
MIke C.
Dennis Johnson
PostPosted: Sun Jan 21, 2007 10:13 am    Post subject: Strobe Light Selection Reply with quote
Hi Mike,
I haven't flown yet (hoping for next month!) but I installed the combined wingtip LED position lights and strobe lights from GS-Air
https://ssl.perfora.net/gs-air.com/sess/utn;jsessionid=1541ee915db8cd2/shopdata/index.shopscript
They look great and are probably a tiny bit more aerodynamic than the certified ones from Whelen and Aeroflash, plus, they're cheaper. They have a single power supply, which has a variety of selectable flash sequences and two power levels. Customer support from GS-Air has been outstanding.
Good luck,
Dennis Johnson
