ericparlow(at)hotmail.com Guest
jwt(at)roadmapscoaching.c Guest
Posted: Fri Jan 19, 2007 9:21 pm Post subject: Fiberglass supplies needed? |
Eric
I highly recommend using West Marine Epoxy for everything (no Resin).
Things I would get:
Epoxy
Fast hardener and Slow hardener - 106 and 105
Pump set (West Marine)
9 oz cloth, oz cloth (West Marine or Aircraft Spruce), get some really thin
stuff for around window seams and fairing seams
Peal Ply (Dacron)- goes on top of lay-ups to soak up excess epoxy. Pulls off
after cure - (Aircraft Spruce)
Rotary cutter (Aircraft Spruce)
Microballons and Cabisil (Aircraft Spruce)
Plastic spreaders/squeegees
Box large tongue depressors (Aircraft Spruce)
8oz. Paper mixing cups (Aircraft Spruce)
Large box of latex or nitrile gloves (Costco)
Couple dozen 1" chip brushes (Harbor freight)
Durafoam (I think that’s the name) long hard foam sanding bars (18" or so)
(Auto paint store)
40 and 80 3M sandpaper in 18" sticky backed strips - 40 grit is a real time
saver (Auto paint store)
UV Smoothprime (Aircraft Spruce)
SuperFill (Aircraft Spruce)
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
FWF, engine, wiring
wayne.e(at)grandecom.net Guest
Posted: Sat Jan 20, 2007 4:57 am Post subject: Fiberglass supplies needed? |
The name of a good Dermatologist for when you become allergic to this stuff like I did :>} Man that stuff can be ugly.
Wayne Edgerton #40336
