davelammers(at)mchsi.com Guest
Posted: Sun Jan 21, 2007 8:02 am Post subject: Timer module |
Hi Listers,
I'm looking for a module that I can use to turn off courtesy lights
after a predetermined (setable) period of time, similar to the function
in your automobile interior lighting.
I would like these courtesy lights to be usable independent of the
master switch, (i.e.: on an "always hot" bus), however, I want them to
turn off after a period of time to eliminate the possibility of battery
drain.
The requirements are:
Input & Output voltage: 12/14v
Output current: Less than 100 ma. (Drives several gangs of multiple
LED's)
Input current: As required for the output, but must be absolutely ZERO
in the off state.
Size: Less than several cubic inches.
Weight: Not much (I've found some controllers that would work but they
are big and hefty).
Activated by momentary on switch.
Optionally, after in the ON state, another press of the momentary ON
will turn the output OFF.
It seems that such a thing could be found reasonably easy, but I have
searched and come up with nothing.
I would appreciate your ideas/suggestions.
Thanks in advance.
Dave Lammers
willslau(at)alumni.rice.e Guest
Posted: Sun Jan 21, 2007 9:10 am Post subject: Timer module |
I want one, too! I was just thinking about the same application yesterday
for my baggage comparments.
William Slaughter
RV-8
Bret Smith
Joined: 09 Jan 2006 Posts: 174 Location: Mineral Bluff, GA
Posted: Sun Jan 21, 2007 10:27 am Post subject: Timer module |
Dave, I'm searching for the same timer module. I want to actuate it from a
contact switch when the canopy is opened. I, too, plan to have it drive 3-4
banks of LEDs.
Please let me know if you identify an acceptable module and I will do
likewise.
Bret Smith
RV-9A (91314)
Mineral Bluff, GA
www.FlightInnovations.com
_________________ Bret Smith
RV-9A (Emp) |
jgarner(at)dslextreme.com Guest
Posted: Sun Jan 21, 2007 10:50 am Post subject: Timer module |
How about using a relay and R-C circuit to time it? We use similar on
elevators all the time...
+12--|-----||--------------------> leds
| relay contact
----/_-----|----O------------gnd
switch | relay coil
|-/\/\/\/--|(-----gnd
resistor capacitor
When the switch closes it picks the relay, contacts light the led.
Switch opens and RC holds the relay in for a 'while'.
The resistor / capacitor / relay coil resistance sets the timing...
Sorry for the ascii art :} and note that I left out fuses, led
resistors, etc.
Hope this helps, YMMV!!
/Joe
Dave Lammers wrote:
<davelammers(at)mchsi.com>
Hi Listers,
drain.
LED's)
in the off state.
are big and hefty).
Thanks in advance.
Dave Lammers
Joe Garner IASEL-RV 6(at)OAK aka 'Snoopy'
jgarner(at)elelink.org |
jgarner(at)dslextreme.com .______(o)______.
kc6utr(at)w6pw www.elelink.org / \
bferrell(at)123mail.net Guest
Posted: Sun Jan 21, 2007 11:14 am Post subject: Timer module |
I bought such a module for my aircraft, and though it was a b*$ch to hook up
right, I'm really pleased with the result. It's called the "lights out"
module.
Here's a similar module, though it's not the one I bought. Let me know if this
doesn't meet your needs, I have papework on the one I used, but it's at the
hangar.
http://www.webelectricproducts.com/products.htm
Brett
Quoting Bret Smith <smithhb(at)tds.net>:
banks of LEDs.
likewise.
Bret Smith
RV-9A (91314)
Mineral Bluff, GA
klehman(at)albedo.net Guest
Posted: Sun Jan 21, 2007 11:31 am Post subject: Timer module |
I'd suggest a solid state device with 4 components such as I use for
autoshutoff circuits on small battery powered devices such as multimeters.
A switch, mosfet, capacitor, and diode. The switch is the largest component.
You'd perhaps want a larger mosfet but I've used a VN10KM mosfet (radio
shack 276-2070) good for 0.5amp successfully. It looks like a tiny
plastic transistor with three leads.
I put the capacitor and diode in parallel from the Source to the gate
with the banded end of the diode and the + end of the cap connected to
the Gate. Ground the Source. Your LED's (with current limiting
resistors) goes between +12 volts and the Drain. Now you can
momentarilly switch +12volts onto the Gate and the LED's will stay on
until the charge on the cap bleeds off. As an example I typically get 1
min. with a .22uf capacitor and 1 hr. with 10uf. Just play with
capacitor values to get the time that you want.
I like to use a 3 positon switch. Center is normal. Up is on
continuously but usually I just put it up and immediately back to center
to let the timer run. Down shorts the cap or discharges it to ground for
an immediate off. A momentary switch (spring loaded to center) or just a
push button will also work well.
Ken
Joe Garner wrote:
| relay contact
switch | relay coil
resistor capacitor
resistors, etc.
/Joe
>Hi Listers,
>drain.
>LED's)
>in the off state.
>are big and hefty).
>Thanks in advance.
>Dave Lammers
lerohl(at)rea-alp.com Guest
Posted: Sun Jan 21, 2007 11:35 am Post subject: Timer module |
Check precisiontimer.com . They have compact modules, about 4 oz.
Gaylen Lerohl
Terminaltown.com
nuckollsr(at)cox.net Guest
Posted: Sun Jan 21, 2007 12:31 pm Post subject: Timer module |
At 10:01 AM 1/21/2007 -0600, you wrote:
Hi Listers,
I'm looking for a module that I can use to turn off courtesy lights after
a predetermined (setable) period of time, similar to the function in your
I would like these courtesy lights to be usable independent of the master
switch, (i.e.: on an "always hot" bus), however, I want them to turn off
after a period of time to eliminate the possibility of battery drain.
Output current: Less than 100 ma. (Drives several gangs of multiple LED's)
in the off state.
are big and hefty).
Optionally, after in the ON state, another press of the momentary ON will
That is one of the products we're developing that will fit into
our standard A enclosure. You can see the package at:
http://www.aeroelectric.com/Pictures/Products/Enclosures/A_Enclosure.pdf
Weight on this puppy is about 3 oz.
It will have an externally programmable time delay ranging from
10 to 1000 seconds. It can be externally strapped to default
ON or default OFF at power up. Will handle 5 amp loads. External
controls are a steady pull to ground which initiates an ON
cycle limited to 1000 seconds. A momentary pull to ground on same
line initiates an ON-cycle for the programmed limit. A pull-to-ground
either momentary or continuous for OFF. If momentary (normally
open) then the system will default according to the strapping
on power up. If continuously held to ground, the system is OFF
under all conditions including right after power up.
This will be our 9024-100-1 On Limit Timer to be on the website
sometime this year. In the mean time, if you're of a notion to
roll-yer-own, consider the schematic at
http://www.aeroelectric.com/Pictures/Schematics/On_Limit_Timer.pdf
Parts are available from Digikey and while it doesn't have the
software driven features of control logic cited for the 9024,
it may well do what you need done. This defaults off on power up.
Momentary pull down to ground initiates a timed ON function, a
momentary pull down shuts the load off.
| Quote: | It seems that such a thing could be found reasonably easy, but I have
There are dozens of ways to skin this cat . . . here
are a few.
< with experiment. >
< --Lawrence M. Krauss >
gregcampbellusa(at)gmail. Guest
Posted: Mon Jan 22, 2007 5:09 am Post subject: Timer module |
I went to Home Depot and got a wind up timer switch for $9.
It weighs 4.1 oz and is rated for 20A (at) 125 Vac or a 1HP motor.
They sell a 0-60 minute version and a 0-12 hour version.
It's a little bulky behind the panel, but the knob on the front is small, sturdy,
and intuitive. You wind it up and you've got lights for 0 to 60 minutes.
It even has an audible reminder that the courtesy lights are on!
(It goes "ticka-ticka-ticka"
I found a piece of "nearly useless" panel space near the upper left of my panel
that had very little room behind it and was otherwise hard to get to -
but it's perfect for the timer. It's easy to reach immediately after opening
the door at night to start a preflight. It also makes a decent backup light & timer.
I like the high tech stuff too, but this low tech "turn past 10" gizmo
filled the bill nicely for under $10.
Greg
mjurotich(at)hst.nasa.gov Guest
Posted: Mon Jan 22, 2007 5:23 am Post subject: Timer module |
Bob
Could you put the schematic and a parts list for the on-limit timer
in a more readable format. I am having difficulty reading some of
the parts and have to make assumptions such as the left most caps are
0.1 mircrofarrads and and V1A is same part as V1B and V1C and there
is a floating symbol that does not make sense to me.
Matthew M. Jurotich
e-mail mail to: <mjurotich(at)hst.nasa.gov>
phone : 301-286-5919
Posted: Mon Jan 22, 2007 6:36 am Post subject: Timer module |
At 08:21 AM 1/22/2007 -0500, you wrote:
Bob
Could you put the schematic and a parts list for the on-limit timer in a
more readable format. I am having difficulty reading some of the parts
and have to make assumptions such as the left most caps are 0.1
mircrofarrads and and V1A is same part as V1B and V1C and there is a
Look up the CD4093 integrated circuit. It has 4 sections
of which only three are used and the forth is "tied off".
The caps are either 0.1 uF and 10 uF except the
timing cap which may be 10 to 47 uF set by experiment
to achieve desired time delay.
The resistors are 1K, 100 ohms, 470 ohms, and 100K
except for the time-adjust resistor which you'll
have to experiment with to achieve the desired
time delay.
plaurence
Posted: Tue Jan 23, 2007 5:06 pm Post subject: Timer module |
Dave, Here's another way to skin this cat.
Check out :
http://www.uoguelph.ca/~antoon/circ/relay1h.html
Peter
_________________ Peter Laurence
RV9A Fuse |
trigo(at)mail.telepac.pt Guest
Posted: Wed Jan 24, 2007 8:12 am Post subject: Timer module |
Peter
Very nice and very useful this site you indicated, with plenty of projects
to exercise your electronic circuit building skills.
Carlos
Posted: Wed Jan 24, 2007 9:12 am Post subject: Timer module |
In the circuit design shown in
the power source is indicated at 9 V.
Please forgive an electronics ignorant question, but what should be done to
connect this circuit to 12/14 V ?
Carlos
plaurence
Posted: Wed Jan 24, 2007 7:21 pm Post subject: Timer module |
Carlos,
Here is one way of regulating the 9 volts. See:
http://www.uoguelph.ca/~antoon/circ/ps-lm317.html
Peter
Carlos
RV9A Fuse |
retasker(at)optonline.net Guest
Posted: Wed Jan 24, 2007 8:34 pm Post subject: Timer module |
Probably nothing. The LMC555 is rated to 15V. The characteristic of
the 555 series is that the timing is relatively insensitive to the
supply voltage. If you run it from 12-14V you will have to choose a
relay that is rated at more than the 6V the schematic shows and has a
resistance of 1000 ohms or more. Depending on what you want to control
with the relay, you could also use an NPN transistor or FET to control
the load in place of the relay.
The only weakness in the circuit shown is that if you get transients on
your aircraft voltage you might destroy the LMC555 - depends on the
length and voltage of the transient. You could mitigate this problem
with a small series resistor and filter capacitor to ground. If you
want it to be bulletproof a zener in parallel with the capacitor would
do it.
I know this might be too much for you to absorb . If you have
other questions, please feel free to ask.
Dick
Carlos Trigo wrote:
<trigo(at)mail.telepac.pt>
done to connect this circuit to 12/14 V ?
Carlos
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Posted: Thu Jan 25, 2007 5:01 am Post subject: Timer module |
Peter, and all electronic experts
Could it be easier (and enough) to replace the Relay (6-9V) of the Timer
circuit by a 12/14V Relay, and then you already can use it with 12/14V power
source ?
Carlos
From: "Peter Laurence" <PLaurence(at)the-beach.net>
| Quote: | > In the circuit design shown in
> to
> Carlos
Posted: Thu Jan 25, 2007 5:18 am Post subject: Timer module |
Dick
Thank you very much for your elaborate and knowledgeable answer. I hadn´t
read it when I put my today's previous post, asking about the substitution
of the relay.
You´re right that, at this moment, all you explained is "too much for me to
absorb", at least right away, but since I'm in this group to learn, I will
try to do exactly that by studying the circuit and your answer, and then
come back with additional rookie questions. After all, this is nothing but
the normal process of learning ....
Carlos
