pdukor1(at)tampabay.rr.co Guest
Posted: Mon Jan 22, 2007 5:51 am Post subject: Thoughts on Upgrades |
I am new to the list, but was impressed by the plane at the Sebring
Show last weekend. in any case how about a constant speed prop like
the Airmaster (or whatever brand) which is already set up for the
3300? Seems to me the plane and pilot win in better fuel economy,
longer range and improved performance numbers from takeoff to landing.
Yeah, it is more money, I know, but I think it is the missing link to
make this a very happy rocket.
Paul dukor
Sarasota, Florida
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
pete(at)flylightning.net Guest
Posted: Mon Jan 22, 2007 6:47 am Post subject: Thoughts on Upgrades |
We've tried the Airmaster. To our surprise it resulted in a substantial
decrease in cruise performance. The explanation was that the Warp Drive
blades are great for speeds up to 140 knots but hit the wall above that.
We are hoping that Sensenich will get their in flight adjustable up and
running soon with the ZK blade profile that works so well with the 3300
Jabiru.
Pete
Posted: Mon Jan 22, 2007 2:42 pm Post subject: Thoughts on Upgrades |
Whoda thunk that!
Thanks for the quick reply since I was still agonizing over it and
planning a spot on the panel for the controller!
Paul
Kayberg(at)AOL.COM Guest
Posted: Mon Jan 22, 2007 4:30 pm Post subject: Thoughts on Upgrades |
My understanding is that constant speed props dont make for faster airspeeds; only
1) better takeoff thrust
2) more weight
3) more money
4) possible better economy since it allows for higher "lugging power" at lower prop speeds that a prop optimosed for top speed.
If there is a radical difference between stall speeds and top speed, changing prop speeds can make a difference in fuel burn and keep the prop from cavitating at static/early takeoff.
But generally you need in excess of 150 hp for it to be worth it....which is why Piper and Cessna havent messed with putting one on the Cessna 150 or the Piper 140 Cherokee.
I suspect the best prop deal for the Lightning is simply the lightest wooden fixed pitch one that will allow
3300 rpm at WOT.
But I could be wrong.......
Doug Koenigsberg
In a message dated 1/22/2007 5:44:41 PM Eastern Standard Time, pdukor1(at)tampabay.rr.com writes:
Quote: |
Quote: | I am new to the list, but was impressed by the plane at the
Sebring
like
landing.
to
N1BZRich(at)aol.com Guest
Posted: Mon Jan 22, 2007 4:44 pm Post subject: Thoughts on Upgrades |
In a message dated 1/22/2007 7:39:41 P.M. Eastern Standard Time, Kayberg(at)aol.com writes:
Quote: | I suspect the best prop deal for the Lightning is simply the lightest wooden fixed pitch one that will allow
3300 rpm at WOT.
lozhoffman(at)yahoo.com Guest
Posted: Mon Jan 22, 2007 4:57 pm Post subject: Thoughts on Upgrades |
Doug,
Re pitch change allowing faster cruise speeds....
We have a Hoffmann 3 position variable pitch prop on
our 80hp Dimona motorglider. Fine for takeoff, course
for cruise and feather for gliding engine off. The
prop is ground adjustable for pitch variations in any
of these settings.
In fine, the Limbach engine provides a rate of climb
of around 400'-450'fpm (at) 55kts. It would rapidly
approach and exceed red line of 3200rpm (3000-3200rpm
continuous for <5mins permitted on takeoff) beyond
60kts IAS even in climb.
Resetting the pitch to cruise provides an IAS of
85-90kts (at) 2700rpm. In our case at least the pitch
variation does make a big difference to cruise speed
achieved.
As an aside, I am amazed at just how small a variation
in pitch there is between our fine and course
settings. Observing the pitch change from outside the
cockpit while someone in it alters the settings, the
change is barely discernable.
Laurie
Sydney
--- Kayberg(at)aol.com wrote:
make for faster
airspeeds; only
2) more weight
3) more money
speed.
Piper 140 Cherokee.
3300 rpm at WOT.
Doug Koenigsberg
Standard Time,
plane at the
> Sebring
constant speed prop
> like
set up for the
takeoff to
> landing.
the missing link
> to
Never Miss an Email
Stay connected with Yahoo! Mail on your mobile. Get started!
http://mobile.yahoo.com/services?promote=mail
N1BZRich(at)AOL.COM Guest
Posted: Mon Jan 22, 2007 5:04 pm Post subject: Thoughts on Upgrades |
3300 rpm at WOT.
I agree with Doug on this. With the Lightning's low stall speed, short takeoff roll, and good rate of climb, why not just put on a prop that will do as Doug says - the lightest wooden fixed pitch one that will allow 3300 rpm at WOT. Even with this so called "cruise / speed prop" on the Lightning the take off roll is still very short, the climb rate is still very good, and the low stall speed allows for relatively slow approaches. Therefore, with the right cruise prop installed the Lightning can operate out of short runways and still "go like stink". In my book, the simplest answer is normally the best plan. Cheaper, lighter, foolproof.
And besides, are we really talking about a constant speed prop (one that uses engine oil as the hydraulic media to keep the prop at a constant set rpm), or one that has a variable pitch control from the cockpit and is electrically operated by the pilot to change pitch and might need lots of attention to keep a constant rpm. Kind of like the old electric props on the older Bonanzas. Sensenich showed me a pre-production model of this type of hub at Oshkosh two years ago. It looked good, but is going to be costly. I think you will probably be able to buy four or five Sensenich fixed pitch props for the price of one of these. Just my $.02 worth. Your mileage may vary.
Blue Skies,
Buz
Posted: Mon Jan 22, 2007 5:28 pm Post subject: Thoughts on Upgrades |
On re-reading my post it could seem that I'm
advocating a variable pitch prop for the Lightning. On
the contrary, as Buz has well described, I don't
believe the benefits would outway the losses in terms
of cost, weight and complexity.
I'll be going for a ground adjustable fixed pitch prop
for my Lightning when the time comes for me to order
my kit.
Laurie
--- N1BZRich(at)aol.com wrote:
Standard Time,
3300 rpm at WOT.
the cockpit and is
mileage may vary.
Blue Skies,
Buz
Need Mail bonding?
Go to the Yahoo! Mail Q&A for great tips from Yahoo! Answers users.
http://answers.yahoo.com/dir/?link=list&sid=396546091
Posted: Mon Jan 22, 2007 6:05 pm Post subject: Thoughts on Upgrades |
Laurie,
I know you have already responded to Buz and agree at least in principle with both of us, but I want to just note that the Limbach is a fine motor, but different in design....as well as only 2/3 the horsepower of the 3300 Jabiru. Not to mention it is bolted to a motorglider. I suspect the weights of both aircraft are similar, as well as the engines. In fact, the Limbach may be slightly heavier.
Without that prop, you really cannot motorglide, of course. Or at least not nearly as well.
Ryan has been amusing himself lately by shutting the Jabiru engine down and gliding from significant distances away from the field to see how well he can glide/practice engine-outs. It really is quite substantial. The suggested 17:1 glide ratio is not far off. I suspect you are closer to 25:1 Our skills dont include soaring just yet, even tho we are near a good ridge to practice on.
But It really is about the horsepower.
Doug Koenigberg
In a message dated 1/22/2007 8:01:05 PM Eastern Standard Time, lozhoffman(at)yahoo.com writes:
Quote: |
Doug,
of these settings.
achieved.
Laurie
Sydney
Posted: Mon Jan 22, 2007 7:29 pm Post subject: Thoughts on Upgrades |
Thnx Doug,
The 17:1 glide ratio was one thing that had caught my
eye. Not so much from the perspective of shutting down
and attempting to soar the Lightning but more as
indicative of how aerodynamically clean the airframe
must be. The polar curve for the aircraft would be
interesting though. Anyone have any idea of the
Lightning's best glide speed ie at which speed it
achieves 17:1 and the subsequent sink rate?
Laurie
Quote: |
Laurie,
slightly heavier.
nearly as well.
closer to 25:1 Our
practice on.
Doug Koenigberg
Standard Time,
Doug,
course
any
of these settings.
climb
(3000-3200rpm
achieved.
variation
the
the
Laurie
Sydney
Never Miss an Email
Posted: Mon Jan 22, 2007 7:44 pm Post subject: Thoughts on Upgrades |
Doug,
just in case you aren't already aware of it, shock
cooling is a major source of premature cylinder head
failure. Its something to be very mindful of if
shutting down midflight.
We fitted a LCD shock cooling alert to the Super cub
that I flew towing gliders for many years and it was
invaluable. We also had one fitted to another
motorglider which had cowl flaps just in case adequate
checks weren't carried out.
Its not so much the absolute temp changes but the rate
of cooling which is critical. Initial power reductions
should be very minor and incremental. We gradually
pull power back over several minutes until the CHT is
quite low before shutting down. Something to keep in
mind with the Lightning.
Sure is nice to be able to shutdown and glide those
last 50 miles from a good cruising level even when no
lift is available!
Laurie
Quote: |
Laurie,
slightly heavier.
nearly as well.
closer to 25:1 Our
practice on.
Doug Koenigberg
Standard Time,
Doug,
course
any
of these settings.
climb
(3000-3200rpm
achieved.
variation
the
the
Laurie
Sydney
Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center.
http://autos.yahoo.com/green_center/
dashvii(at)hotmail.com Guest
Posted: Mon Jan 22, 2007 8:24 pm Post subject: Thoughts on Upgrades |
One of the things that I am going to try to do is to determine the
coefficient of drag on the Lightning before and after my modifications.
Quote: | From that I can give you a better guess at how much performance gains I can
get out of the speed mods. I'll also do the glide testing to verify data.
I'll have use of an instrumentation package to record the inflight data and
can download that into the laptop when I get down. Should be interesting.
Brian W.
Search for grocery stores. Find gratitude. Turn a simple search into
something more.
http://click4thecause.live.com/search/charity/default.aspx?source=hmemtagline_gratitude&FORM=WLMTAG
Scotty
Joined: 08 Oct 2006 Posts: 44 Location: Peachtree City, GA
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
