nuckollsr(at)cox.net Guest
Posted: Tue Jan 23, 2007 10:36 am Post subject: Wing root connector sources. |
| Quote: | Your article at . . .
http://www.aeroelectric.com/articles/wingwire/wingwire.html
shows a very useful connector for my demountable wings, but I'm having a
deuce of a time finding the very one you display.
Can you tell me where you got it, as all my attempts to find are thwarted.
I get across to USA fairly frequently and will search the standard
hardware/auto shops.
Good afternoon my friend. The connector illustrated is
a trailer-wiring device that would be found in stores that
offer RV and trailer parts. I think I purchased the connector
shown in a blister pack at Pep Boys, Oriley's, or
AutoZone. They're pretty common in a variety of pin-counts.
Here are some 'net leads . . .
http://tinyurl.com/34k7ug
http://tinyurl.com/32d9nu
http://preview.tinyurl.com/3325t6
Consider lap-splicing the wires as suggested in
http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html
This should reduce the splicing bulk in adjacent
cabling.
< with experiment. >
< --Lawrence M. Krauss >
rshannon(at)cruzcom.com Guest
Posted: Tue Jan 23, 2007 2:04 pm Post subject: Wing root connector sources. |
FWIW, I'll second the recommendation of the Switchcraft EN3 weathertight
connectors, which someone mentioned awhile back (see
http://dkc3.digikey.com/PDF/T071/0321.pdf). They're feather weight,
rated 7.5A, and very high quality. I'm going to use them for both trim
and wing root connections.
Ron
Posted: Tue Jan 23, 2007 8:43 pm Post subject: Wing root connector sources. |
At 02:03 PM 1/23/2007 -0800, you wrote:
http://dkc3.digikey.com/PDF/T071/0321.pdf. They're feather weight,
Cute little fellers . . . thanks for the heads-up on these.
They look really good.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
