DAquaNut(at)aol.com Guest
Posted: Thu Apr 12, 2007 7:54 pm Post subject: Decarbon CD |
Group,
Does anyone know of a CD that walks you through a 50 hour decarbon or inspection. I have 48 hours on my 447 and want to do what I can to keep her running as good as she has so far. Is it possible to have a stuck ring and still have proper compression?
Ed Diebel (FF 62)
See what's free at http://www.aol.com. [quote][b]
JetPilot
Posted: Fri Apr 13, 2007 5:11 am Post subject: Re: Decarbon CD |
I would not dissasemble the engine at 50 hours, no way. You run a much higher chance of damaging something or putting something back together wrong than having carbon at just 50 hours. It is possible to have carbon and have good compression, but at just 50 hours, it should not be a concern unless you have abused the engine horribly. There are ways to check for carbon by looking in the exhaust port, but its not perfect....
Stick some seafoam in the engine to get rid of what little carbon that might have built up in just 50 hours, and go flying
Mike
Kolb MK-III Xtra, 912-S |
Paul Petty
Posted: Fri Apr 13, 2007 6:31 am Post subject: Re: Decarbon CD |
Ed,
I have a Rotax overhual video I bought off e-bay. I think they address de-carbon. Your welcome to it. E-mail your mailing address.
paulpetty(at)myway.com
_________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Fri Apr 13, 2007 6:38 am Post subject: Re: Decarbon CD |
Forgive the newbie question but what symptoms and problems result from carbon build up? Sticking Rings? Misfires?
Is there a recommended interval to decarbon?
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
