[JamesAircraft] First RV-10 to fly in Canada takes off in Ch
rvbuilder(at)sausen.net
PostPosted: Wed Jan 24, 2007 5:01 pm    Post subject: [JamesAircraft] First RV-10 to fly in Canada takes off in Ch Reply with quote
Repost from the James Aircraft list. Some new, some not........
[mailto:JamesAircraft(at)yahoogroups.com] On Behalf Of lizzyjames4_7
Sent: Wednesday, January 24, 2007 4:30 PM
To: JamesAircraft(at)yahoogroups.com
Subject: [JamesAircraft] First RV-10 to fly in Canada takes off in
Charlottetown
Cool News! Pictures posted
Hi Will.
I will get you some stats after I get used to this hot rod,I only have
3 hours on it so far and it is a beauty. I want to thank you folks at
James Aircraft you were a pleasure to work with. We were climbing at
2200 feet per minute with full fuel and two adults over 400 total crew
weight. It is very fast compared to my Cherokee pa 140. You can use
any info you want for your web page or for any thing you want use it
for.
Cheers
David Corrigan
Sent: Sunday, January 21, 2007 6:41 PM
Subject: Article for COPA magazine
First RV-10 to fly in Canada takes off in Charlottetown
By
Barry Martin
The first Vans RV-10 to fly in Canada took to the air on January 18,
2007 from the Charlottetown Airport on PEI. After approximately 16
months of building and, much to the delight of Owner and Builder David
Corrigan and co-builder Deryck Hickox, the RV-10 lifted off around
noon in clear skies and light winds, although the temperature was a
little cool, being around minus 5 degrees C. With the IO-540 purring
like a kitten, the RV-10 was through circuit height before reaching
the end of the runway.
Test pilot Glen McLarty took the RV to 4000 feet over the airport to
do the initial tests then headed north of the airport to finish the
first round of tests. In communication with the ground crew, Glen
relayed that the plane flew straight and level even with his hands off
the stick.
The RV-10 is equipped with a Lycoming IO-540 that was rebuilt by
Aerotec in Halifax and has a MT 3 blade propeller up front. The
instrument panel is well equipped with an AF-2500 engine monitor,
Garmin 430, Garmin SL-30, PS Engineering Audio Panel, Garmin GTX 327
Transponder, ATD-300 Traffic Watch and a TruTrak Autopilot. As all the
instruments are electrically run, there is also a back-up battery.
This is the first homebuilt project for Dave, locally known as "The
Flying Real Estate Agent", but Deryck has over 30 years experience
building and restoring aircraft, much of it with the Canadian Warplane
Heritage in Hamilton. Deryck, originally from PEI, moved back after
retiring from Air Canada where he worked as an AME. Since starting the
project, Deryck has formed D. Hickox Aviation Services specializing in
aircraft restoration, fabric covering and home built aircraft. He can
be contacted at 902-894-4522 if you have a project you would like him
to build or restore.
__._,_.___
Messages in this topic
<http://groups.yahoo.com/group/JamesAircraft/message/523;_ylc=X3oDMTMzMH
A0ZDBtBF9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRtc2
dJZAM1MjMEc2VjA2Z0cgRzbGsDdnRwYwRzdGltZQMxMTY5Njc4MDUyBHRwY0lkAzUyMw-->
(1) Reply (via web post)
<http://groups.yahoo.com/group/JamesAircraft/post;_ylc=X3oDMTJwMGNsa2VxB
F9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRtc2dJZAM1M
jMEc2VjA2Z0cgRzbGsDcnBseQRzdGltZQMxMTY5Njc4MDUy?act=reply&messageNum=523
| Start a new topic
<http://groups.yahoo.com/group/JamesAircraft/post;_ylc=X3oDMTJmMW1zdmpwB
F9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRyB
HNsawNudHBjBHN0aW1lAzExNjk2NzgwNTI->
Messages
<http://groups.yahoo.com/group/JamesAircraft/messages;_ylc=X3oDMTJmZW0zZ
nFwBF9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZ
nRyBHNsawNtc2dzBHN0aW1lAzExNjk2NzgwNTI-> | Files
<http://groups.yahoo.com/group/JamesAircraft/files;_ylc=X3oDMTJncW9uYXJy
BF9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRy
BHNsawNmaWxlcwRzdGltZQMxMTY5Njc4MDUy> | Photos
<http://groups.yahoo.com/group/JamesAircraft/photos;_ylc=X3oDMTJmZnMwZmR
nBF9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnR
yBHNsawNwaG90BHN0aW1lAzExNjk2NzgwNTI-> | Links
<http://groups.yahoo.com/group/JamesAircraft/links;_ylc=X3oDMTJnMHF0bWVz
BHNsawNsaW5rcwRzdGltZQMxMTY5Njc4MDUy> | Database
<http://groups.yahoo.com/group/JamesAircraft/database;_ylc=X3oDMTJkaW1mM
XVhBF9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZ
nRyBHNsawNkYgRzdGltZQMxMTY5Njc4MDUy> | Polls
<http://groups.yahoo.com/group/JamesAircraft/polls;_ylc=X3oDMTJnZHAwaDBk
BHNsawNwb2xscwRzdGltZQMxMTY5Njc4MDUy> | Members
<http://groups.yahoo.com/group/JamesAircraft/members;_ylc=X3oDMTJmMWFhaW
Q1BF9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZn
RyBHNsawNtYnJzBHN0aW1lAzExNjk2NzgwNTI-> | Calendar
<http://groups.yahoo.com/group/JamesAircraft/calendar;_ylc=X3oDMTJldGNnZ
W9jBF9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZ
nRyBHNsawNjYWwEc3RpbWUDMTE2OTY3ODA1Mg-->
Yahoo! Groups
<http://groups.yahoo.com/;_ylc=X3oDMTJlMjBpMjdrBF9TAzk3MzU5NzE0BGdycElkA
zE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRyBHNsawNnZnAEc3RpbWUDMTE2O
TY3ODA1Mg-->
Change settings via the Web
<http://groups.yahoo.com/group/JamesAircraft/join;_ylc=X3oDMTJnOWFxcnFzB
HNsawNzdG5ncwRzdGltZQMxMTY5Njc4MDUy> (Yahoo! ID required)
Change settings via email: Switch delivery to Daily Digest
<mailto:JamesAircraft-digest(at)yahoogroups.com?subject=Email%20Delivery:%2
0Digest> | Switch format to Traditional
<mailto:JamesAircraft-traditional(at)yahoogroups.com?subject=Change%20Deliv
ery%20Format:%20Traditional>
Visit Your Group
<http://groups.yahoo.com/group/JamesAircraft;_ylc=X3oDMTJlc3FjbHQxBF9TAz
k3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDZnRyBHNsaw
NocGYEc3RpbWUDMTE2OTY3ODA1Mg--> | Yahoo! Groups Terms of Use
<http://docs.yahoo.com/info/terms/> | Unsubscribe
<mailto:JamesAircraft-unsubscribe(at)yahoogroups.com?subject=>
Recent Activity
* 4
New Photos
<http://groups.yahoo.com/group/JamesAircraft/spnew;_ylc=X3oDMTJnZTgxOThz
BF9TAzk3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDdnRs
BHNsawN2cGhvdARzdGltZQMxMTY5Njc4MDUy>
Visit Your Group
<http://groups.yahoo.com/group/JamesAircraft;_ylc=X3oDMTJmZjkxdjVkBF9TAz
k3MzU5NzE0BGdycElkAzE1NjUwNDgzBGdycHNwSWQDMTcwNTc4NjA4MwRzZWMDdnRsBHNsaw
N2Z2hwBHN0aW1lAzExNjk2NzgwNTI->
* Aviation
<http://groups.yahoo.com/gads;_ylc=X3oDMTJkOTZnZ2xhBF9TAzk3MzU5NzE0BF9wA
zEEZ3JwSWQDMTU2NTA0ODMEZ3Jwc3BJZAMxNzA1Nzg2MDgzBHNlYwNzbG1vZARzdGltZQMxM
TY5Njc4MDUy?t=ms&k=Aviation&w1=Aviation&w2=Experimental+aircraft&w3=Expe
rimental+jet+aircraft&c=3&s=72&g=2&.sig=6346i6Mg3v7NbOLfmoSK-A>
* Experimental aircraft
<http://groups.yahoo.com/gads;_ylc=X3oDMTJkZWYyMGllBF9TAzk3MzU5NzE0BF9wA
zIEZ3JwSWQDMTU2NTA0ODMEZ3Jwc3BJZAMxNzA1Nzg2MDgzBHNlYwNzbG1vZARzdGltZQMxM
TY5Njc4MDUy?t=ms&k=Experimental+aircraft&w1=Aviation&w2=Experimental+air
craft&w3=Experimental+jet+aircraft&c=3&s=72&g=2&.sig=GBqZNUsg9D-mi_tUfSd
qqQ>
* Experimental jet aircraft
<http://groups.yahoo.com/gads;_ylc=X3oDMTJkcjF2czN2BF9TAzk3MzU5NzE0BF9wA
zMEZ3JwSWQDMTU2NTA0ODMEZ3Jwc3BJZAMxNzA1Nzg2MDgzBHNlYwNzbG1vZARzdGltZQMxM
TY5Njc4MDUy?t=ms&k=Experimental+jet+aircraft&w1=Aviation&w2=Experimental
+aircraft&w3=Experimental+jet+aircraft&c=3&s=72&g=2&.sig=22ccgOTO-9MAamG
nCVqx_g>
Yahoo! News
Kevin Sites
<http://us.ard.yahoo.com/SIG=12iugdt5j/M=493064.9803190.10510181.8674578
/D=groups/S=1705786083:NC/Y=YAHOO/EXP=1169685252/A=3848607/R=0/SIG=10q7s
9jm5/*http:/hotzone.yahoo.com>
Get coverage of
world crises.
Y! GeoCities
Share Photos
<http://us.ard.yahoo.com/SIG=12ihatt95/M=493064.9803219.10510212.8674578
/D=groups/S=1705786083:NC/Y=YAHOO/EXP=1169685252/A=3848528/R=0/SIG=11vts
2tqq/*http:/us.rd.yahoo.com/evt=42416/*http:/geocities.yahoo.com/>
Put your favorite
photos online.
Sitebuilder
Over 380 Templates
<http://us.ard.yahoo.com/SIG=12i3enpu3/M=493064.9803229.10510223.8674578
/D=groups/S=1705786083:NC/Y=YAHOO/EXP=1169685252/A=4025308/R=0/SIG=12uhb
64pb/*http:/us.rd.yahoo.com/evt=44092/*http:/smallbusiness.yahoo.com/web
hosting/sitebuilding.php>
Build and custo-
mize your web site
