bgill1(at)charter.net Guest
Posted: Thu Jan 25, 2007 9:57 am Post subject: Axel extension & firewall questions |
Had two different questions relative to the RV-10 build:
On the variations of axel extension spacers that folks are looking at - I assume that all of these are aluminum - any body recommend a particular grade? I see that ACS has 6061T6 that may fit the bill...I may order a bit to play with on my mini- lathe.
Fire wall through hole sealing...I have seen 3M fire putty used as well as Biotherm 100. Any sources identified? I have looked a bit on the web but most all of the suppliers were industrial (full case only sales). ACS carries a "firewall 2000 caulk" that appears to be made for attaching firewall blanket and is probably a siliconized caulking and Vans now has somthing that looks like proseal but is firewall sealant - I believe that the Biotherm may be very similar to the siliconized caulk but I have not compared the specification sheets yet. I am trying to lay out all of my holes and line up the carry through connectors etc. Any other recommendations from those past this point?
Thanks in advance!
Byron N253RV assigned
FFW and Finishing - awaiting panel re-start
LloydDR(at)wernerco.com Guest
Posted: Thu Jan 25, 2007 10:32 am Post subject: Axel extension & firewall questions |
Goto Lowes aviation department and get fireplace sealer. Works the same
and is cheaper.
Dan
N289DT
