bobbyhester(at)charter.ne Guest
Posted: Thu Jan 25, 2007 8:05 pm Post subject: Phase I flight area |
How big of an area have you guys gotten for your phase I flight area?
Advisory Circular says 25 statute mile radius from base airport.
Surfing the web with my laptop from Hopkinsville, KY
Visit my RV7A website: http://webpages.charter.net/bobbyhester/FinishingUpPg3.htm
Bruce(at)glasair.org Guest
Posted: Thu Jan 25, 2007 8:41 pm Post subject: Phase I flight area |
Usually, that's a negotiated topic between you and your DAR. It depends on
the cruising speed of your airplane. With our Glasairs we normally want at
least 50 miles or we'll be making turns every 5 minutes.
Bruce
www.glasair.org
dwhite17(at)columbus.rr.c Guest
Posted: Fri Jan 26, 2007 3:50 am Post subject: Phase I flight area |
We were able to get a 100nm test area.
rv6(at)cox.net Guest
Posted: Fri Jan 26, 2007 3:56 am Post subject: Phase I flight area |
Luckily, in Oklahoma we have a senator who is an RV8 pilot and he negotiated
the whole state as the test area excluding specific controlled airspace. I
used the same DAR and got the same thing.
Jerry Calvert
Ednond Ok
N296JC
RV6
kboatright1(at)comcast.ne Guest
Posted: Fri Jan 26, 2007 4:17 am Post subject: Phase I flight area |
I drew out an area on an old sectional and asked the DAR to set it as my
phase 1 test area.
I explained to him my reasoning for the area:
1) A 25 mile circle would put me over Atlanta/Hartsfield, and neither of us
wanted that.
2) The area was familiar to me - I knew lots of alternate landing sites.
3) The area had a wide selection of nice paved runways.
4) The area was fairly lightly populated.
He had no problem with my request.
KB
luckymacy(at)comcast.net Guest
Posted: Fri Jan 26, 2007 5:52 am Post subject: Phase I flight area |
My DAR was new and wanted to go by the book which included the very small ~25 mile radius flight test area minus any Class B space. 25 miles East of me would include a lot of Class B airspace. I took out a sectional and picked up some key strategic airports NE, N, NW, W, SW and S from my airport to avoid the class B airspace East of me. The distance from the NE one to the SW one was probably over 100 NM apart. I then circled within my area where I wanted to do Acro & spins and another area where I wanted to set up a large triangle for my airspeed calibration runs. I also pointed out which airports had cheap fuel and the one that had the prop balancing shop & avionics shops. I also made sure he knew the farthest away one was chosen because it had a large grass strip which I was very familiar with. In the end, he consented. There's no way I would have been happy flying off thos e hour s in any smaller area so I would recommend you try to get what you want.
Lucky
[quote]-------------- Original message --------------
From: "Kyle Boatright" <kboatright1(at)comcast.net>
[quote] --> RV-List message posted by: "Kyle Boatright"
phase 1 test area.
wanted that.
KB
lhelming(at)sigecom.net Guest
Posted: Fri Jan 26, 2007 7:55 am Post subject: Phase I flight area |
Depends on the authority area of your DAR or the FSDO you are working with.
In my case it was not a true circle of a certain size but more defined by
the area the DAR had authority to deal within. I think I was more or less
about 50nm but could not cross into Indiana from Henderson, KY but I could
cross into some parts of southern Illinois. Larry in Indiana
dan(at)rvproject.com Guest
ronlee(at)pcisys.net Guest
gerf(at)gerf.com Guest
Posted: Fri Jan 26, 2007 12:31 pm Post subject: Phase I flight area |
To repeat a similar thread from another list ...
Here's something to consider as you barrel away from your home base deep into your flight testing box that's the size of California - how far away from your home base do you want to be if things start going pear-shaped ?
g
[quote]--
rv9jim(at)juno.com Guest
Posted: Fri Jan 26, 2007 12:39 pm Post subject: Phase I flight area |
Lucky,
I think that equates to a little over three minutes in one
direction before turning. 3 miles / min rate of travel would make me a
bit dizzy with all the turns. I hope to get about a 60 or so miles in an
oval (long axis) where I live. At least that will allow me to do the
testing that will be necessary for my "9-A". Got a BIG water to my west
and Orlando and its garbage to the East. So I want to go North and South
and stay clear of the busy areas.
Jim Nelson
RV9-A FWF
Posted: Fri Jan 26, 2007 1:25 pm Post subject: Phase I flight area |
At 01:30 PM 1/26/2007, you wrote:
| Quote: | To repeat a similar thread from another list ...
That is why you do enough flying close to home to iron out issues.
Ron Lee
jpl(at)showpage.org Guest
Posted: Fri Jan 26, 2007 1:27 pm Post subject: Phase I flight area |
Well certainly during initial testing you'll stay near the airport.
But later in flight testing you're going to be working on things like calibrating airspeed or mucking with the cooling system. Being able to fly straight and level for 20 minutes could make these processes a lot easier than if you can never get settled down cause you're fighting to stay inside the box.
It's a fast airplane. When I get mine in the air, I'm hoping for a box at least 20 minutes on a side.
-J
On Jan 26, 2007, at 2:30 PM, Gerry Filby wrote:
[quote] To repeat a similar thread from another list ...
g
[quote]--
Posted: Fri Jan 26, 2007 1:39 pm Post subject: Phase I flight area |
Hey, I'm with you man! That was the final comment my DAR made. I'd be spending a lot of time turning around over populated areas with his original proposal. I live on the East Coast, sandwiched in between the freakin' DC ADIZ, Atlantic ocean and PHILLY Class B. Lots of populated areas underneath and airways all around. It's darn nice to get away from all that while burning those hours off.
lucky
he Mat [quote][b]
Posted: Fri Jan 26, 2007 5:46 pm Post subject: Phase I flight area |
True, you should go on a cross-country hike the first several trips, but it
doesn't take 25 hours to know that everything is or isn't working as it
should. Just like any flight, one must exercise appropriate judgment.
rv7a(at)prosody.org Guest
Posted: Fri Jan 26, 2007 10:41 pm Post subject: Phase I flight area |
I wish that I knew more about this before I flew my time off.
My DAR sucked.
Thanks Joe
(at)BFI 420 hours
tcervin(at)valkyrie.net Guest
Posted: Sat Jan 27, 2007 3:40 am Post subject: Phase I flight area |
I got a 100 mile circle from my Cleveland FSDO and was glad I did! My RV6-A was doing 155 Knots at 75% squared...no wheel pants or gear leg fairings. With 11 miles I would be doing turns around a point!!
Tom in Ohio
Gary.A.Sobek
Posted: Sat Jan 27, 2007 4:51 am Post subject: Phase I flight area |
FAA Order 8130.2 is the Order by which the FAA (DAR) are required to use for
Airworthiness Certification.
As of July 2006, 8130.2F Change 2 is current.
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgOrders.nsf/0/18b1d64bc8f90136862571d40072d8e1/$FILE/Order%208130F%20with%20chg%202%20incorporated.pdf
(may need to copy paste the link to one line.)
Section 152 on page 160 has the REQUIREMENTS for "FLIGHT TEST AREAS" of
Amateur Built Experimental Aircraft.
FROM THE ABOVE REVERENCED DOCUMENT:
"a. General. Section 91.319(b) requires that an unproven aircraft be
assigned to a flight test area.
The assigned test area is prescribed in accordance with § 91.305. The FAA,
when requested, should
assist applicants in selecting areas that comply with § 91.305. The FAA is
required to evaluate each
application to determine that the flight test area does not exceed that
which is reasonably required to accomplish the program. Actions pertaining
to flight test areas must be coordinated with the nearest office of the Air
Traffic Service."
Since FAR 91.305 is referenced above, here is what it says:
"Sec. 91.305 Flight test areas.
No person may flight test an aircraft except over open water, or sparsely
populated areas, having light air traffic."
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library%5CrgFAR.nsf/0/45980FAAA23BA129852566CF0067BB5C?OpenDocument
IMHO, if you have a WRITTEN "Flight Test Plan", include the detailed "Flight
Test Plan" with your application for airworthiness, and it documents the
need for a test flight area larger than you receive, you need to bring this
info to the FAA's (or DAR's) attention.
Gary A. Sobek
RVdar.com
"My Sanity" RV-6 N157GS O-320 Hartzell,
1,976 + Flying Hours So. CA, USA
Valentine’s Day -- Shop for gifts that spell L-O-V-E at MSN Shopping
http://shopping.msn.com/content/shp/?ctId=8323,ptnrid=37,ptnrdata 4095&tcode=wlmtagline
klwerner(at)comcast.net Guest
Posted: Sat Jan 27, 2007 9:05 am Post subject: Phase I flight area |
Well Joe,
Where you able to fly your time off anyway, regardless of the sucky one?
What did you have to do, fly a slight but constant circle?
[quote]I wish that I knew more about this before I flew my time off. My DAR sucked.
Thanks Joe
(at)BFI 420 hours
