by0ung(at)brigham.net Guest
Posted: Fri Jan 26, 2007 8:28 am Post subject: flaperons |
The Xtra wing uses flaperons.
The Classic wing uses seperate flaps and ailerons.
Was the use of flaperons to save weight, complexity, or parts count???
And would the flaperons cause a bit more adverse yaw than ailerons?
Boyd
jim
Posted: Fri Jan 26, 2007 9:04 am Post subject: flaperons |
Just guessing here, but I would think flaperons would be used to get the
best of both worlds: Maximum surface area for flaps (lower stall speed),
and maxiumum roll authority.
Jim
N. Idaho
Boyd
_________________ Jim
N. Idaho |
Posted: Fri Jan 26, 2007 9:23 am Post subject: flaperons |
get the
speed),
| Jim
Jim:
In the real world of Kolb, it works just the opposite.
Flaps and ailerons perform better on the mkIII.
_________________ John Hauck
Titus, Alabama |
