icubob(at)newnorth.net Guest
Posted: Sat Jan 27, 2007 5:15 am Post subject: shielded wires |
have used bobs illustrations and have done a good job making pigtails and daisy chaining the shielded wires for my ptt switch. now i notice the 2 wire shielded cable a little stiff to easily slip into my control stick. wouldnt it work to attach the shield to my alum. control stick and then use plain 22ga wire inside the stick? wont the stick act as the shield?
appreciate any input, bob noffs
nuckollsr(at)cox.net Guest
Posted: Tue Jan 30, 2007 7:00 am Post subject: shielded wires |
At 07:14 AM 1/27/2007 -0600, you wrote:
Quote: | have used bobs illustrations and have done a good job making pigtails and
Bob, sorry for the delay on this. There's been a lot
of conversation on the List recently and your inquiry
moved a long way up the IN box . . .
Sure . . . first, as I mentioned in another posting
earlier, the vast majority of shielding called out in
various drawings probably contributes nothing of electrical
value in the typical small aircraft installation.
This is because there are VERY few noise sources that
propagate chiefly by electrostatic coupling . . . which
is the form of firewall provided by shielding.
I also confessed to using a lot of shielded wire as
a convenience for quick-n-dirty multiple-conductor
signal pathways in a bundle. I've got multi-thousand
foot spools of single, twisted pair and twisted trio
on the rack. If I need a trio for some task, I'm quite
likely to grab a hunk of shielded than to build my own
length of twisted wires.
So, having confessed to all that, know that your suggestion
for not taking the shields up the stick is a sound one but
not for the reason you've guessed. It's not that the shielding
is really useful but that it mostly likely doesn't matter.
< CAUTION >
When installing a system wherein the
instructions CALL OUT shielded wire,
don't use this mini-dissertation to
justify dumping shields unless you have
a strong understanding of what those wires
do an what the risks might be for electro-
static noise ingress.
All the LED annunicator fixtures I supply
are wired with shielded wire as a fabrication
convenience. See pages 10 and 11 of:
http://www.aeroelectric.com/articles/lvwarn/LVWarn-ABMM.pdf
As I mentioned above, it's EASY to use
shielded wire whether or not the shield
is necessary . . . but it can be damned
difficult to pull the new shielded wire
in later. I've offered these words as
enlightenment to the realities of shielding,
not as a general recommendation to ignore
the callouts on manufacturer's installation
instructions.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
