Lynn Matteson
Posted: Thu Jan 25, 2007 1:44 pm Post subject: Oshkosh Skiplane Fly-in |
Is anybody going to the fly-in this Saturday? I've got my plane
ready, and maybe I need somebody to tell me I'm nuts to go. Barring
that, weather willing, creek doesn't rise, I'm gonna give it a shot.
I've got about 15 takeoffs and landings since I installed the skis,
and all is well landing on mostly grass with about 3 inches of snow
around here. Biggest detriment that I can see so far is the weather.
Any tips out there for a beginning (by air) Oshkosher?
I just finished installing a redundant set of safety cables/shock
cords, and feel like I can just about slice through anything. : )
Lynn
Kitfox IV Speedster...Jabiru 2200
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Thu Jan 25, 2007 3:54 pm Post subject: Oshkosh Skiplane Fly-in |
When parking in un-packed snow it is sometimes a good idea to taxi the plane
in a circle and stop in your own tracks the second time around. Helps to
keep the skis from sticking to the snow.
An old bush pilot told me that one...
He also said when it really got cold he would drain the oil and bring it
inside and also bring in the battery. Oh yes.. And in very cold weather lay
some boughs on the ground and run the plane up on them also helps to keep
Have fun!!
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
84KF Guest
Posted: Thu Jan 25, 2007 4:26 pm Post subject: Re: Oshkosh Skiplane Fly-in |
Go wide around Chicago....Plan fuel stops well...you'll need the snow
I've done Oshkosh a few times from New Hudson Mi in the Fall Long trip, (85 MPH) and you need to know where you are at when rounding the lake and heading east. I always went past Mode C airspace before starting North, but that was an equipment issue. more relaxing though This was before common GPS
Steve
Lynn Matteson
Posted: Thu Jan 25, 2007 5:32 pm Post subject: Oshkosh Skiplane Fly-in |
I just got the VFR Terminal Area chart, and it shows the popular
route along the lake, which looks doable to me...a little up and down
here and there to stay out of "B" space, but seems doable. Of course
the chart doesn't show all those planes zooming by either. : )
I've done the Oshkosh drive 6 or 7 times, and it's gonna be fun
(weather permitting) to look down and see those damned orange cones
from another view.
I'm planning to mark the chart, but keep an eye on the GPS as
well...or vice versa, probably.
With 26 gallons aboard, and less than 4 gph, I *shouldn't* have to
stop for fuel, but certainly will for nature calls, and will refuel
then, I'll mark the best-looking spots on the chart.
Thanks, Steve.
Lynn
On Jan 25, 2007, at 7:26 PM, 84KF wrote:
Steve
http://forums.matronics.com/viewtopic.php?p=90461#90461
N369LM |
Lynn Matteson
Posted: Thu Jan 25, 2007 5:36 pm Post subject: Oshkosh Skiplane Fly-in |
Thanks Noel...sounds like some of the stories I read last year about
the Alaskan bush pilots.
NOW I know what to do with my still-to-be-taken-down Christmas tree!
I understand that tossing the boughs out can give you a better
perspective on landing.
Lynn
On Jan 25, 2007, at 6:53 PM, Noel Loveys wrote:
the plane
Helps to
bring it
weather lay
to keep
Have fun!!
Noel
N369LM |
Lynn Matteson
Posted: Thu Jan 25, 2007 5:53 pm Post subject: Oshkosh Skiplane Fly-in |
Re sticking to the snow....I've got wheel-penetration skis, so with
packed snow, this shouldn't be an issue, should it? Also the
polyurethane "feet" should help that situation, I would think...we
shall see...
Lynn
the plane
Helps to
bring it
weather lay
to keep
Have fun!!
Noel
N369LM |
cliffh(at)outdrs.net Guest
Posted: Thu Jan 25, 2007 7:13 pm Post subject: Oshkosh Skiplane Fly-in |
I used to carry two short pieces of 2X4 and would lift up the skis and put
them under the skis to keep them from freezing down.
Floran H.
kitfoxmike
Posted: Fri Jan 26, 2007 10:12 am Post subject: Re: Oshkosh Skiplane Fly-in |
from my snowmobile days, we did have problems with ski's sticking in the snow, then came the plastic ski's, wow now we were spoiled pups, slide and no stick in the snow, no build up of snow on the ski's either. hope this helps.
Lynn Matteson
Posted: Fri Jan 26, 2007 3:06 pm Post subject: Oshkosh Skiplane Fly-in |
I spoke with O'kosh today, and the wind was blowing the snow around,
but they are still a go for tomorrow, as am I.
Yeah, thank God for plastic...I'm a "newbie" on skis, and I'm already
spoiled.
Lynn
On Jan 26, 2007, at 1:12 PM, kitfoxmike wrote:
<customtrans(at)qwest.net>
kitfoxmike
N369LM |
dave
Posted: Fri Jan 26, 2007 5:19 pm Post subject: Oshkosh Skiplane Fly-in |
Lynn, --------------------- Good luck on your trip. ----------------
I love Ski fly ins.
Also if you do not have a metal runner on bottom of ski you will not get
much sticking.
One thing I would suggest is to lift up each ski and put a stick under each
ski to be sure.
One thing i Usually do prior to getting in the plane is grab the strut and
move the plane back and forth a bit to ensure you not stuck. Or grab the
tail handle and move it side to side and watch each ski to make sure they
loose.
Also if landing in deep snow make sure you land and don't stop until you go
in a loop an d come back to the tracks you just made if possbile. If not
you might be looking at tramping down a path to get back out.
Another thing is make sure you not in slush, once you bog down in it you
will have trouble getting moving again. Even though there is 2 feet of ice
but yet 12 inches of slush will be a mess to get out of. And since you on
wheel skis always be ready for a frozen wheel on landing.
Take some sunglasses and different colours if you have them as it hard to
see the surface on gray days.
And don;'t forget to take some pics to remind us what a great time it was.
Fly safe !
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Fri Jan 26, 2007 7:33 pm Post subject: Oshkosh Skiplane Fly-in |
Thanks, Dave...pictures coming right up...stills that is.
The trip hasn't even started yet and I already caught two typos in
the landing procedures that were emailed to me from EAA...not a big
deal, just saying on one hand that you're heading for downwind, and
on the other hand that you're heading for final...like I say, just a
small matter. : ) Oh, yeah, another small matter was the reference
to the Red Barn as a landmark just north of the field....don't look
for it, I was told, as they demolished it two weeks ago....ho hum.
They are expecting maybe 100 planes, and when I called today, with
about 2 hours left in their day, they gave me registration number 53,
so there may not be as many as they think. With 53-100 planes packing
the snow, I gotta think that it'll be bumpy and skatey.
I'm planning to leave there later in the day and heading back the
northern route, and staying someplace in Upper Michigan for the
night, then maybe heading to the Bush Planes Museum in Sault Ste.
Marie, Ontario....maybe. I'm taking my birth certificate in case I do
that. I'd land stateside, and take ground transportation into Canada,
eh? : )
Lynn
I love Ski fly ins.
not get much sticking.
under each ski to be sure.
strut and move the plane back and forth a bit to ensure you not
stuck. Or grab the tail handle and move it side to side and watch
each ski to make sure they loose.
until you go in a loop an d come back to the tracks you just made
if possbile. If not you might be looking at tramping down a path
to get back out.
it you will have trouble getting moving again. Even though there is
2 feet of ice but yet 12 inches of slush will be a mess to get out
of. And since you on wheel skis always be ready for a frozen
wheel on landing.
hard to see the surface on gray days.
it was.
Fly safe !
Dave
N369LM |
Fox5flyer Guest
Posted: Sat Jan 27, 2007 5:47 am Post subject: Oshkosh Skiplane Fly-in |
Bon Voyage Lynn. I didn't catch when you were leaving and returning,
but on the way home if you need a place to stay for the night I'm
about 30 air minutes south of Alpena MI. I'm downstate right now and
won't be home until Monday. Let me know.
Deke
runwayrex(at)juno.com Guest
Posted: Sat Jan 27, 2007 6:06 am Post subject: Oshkosh Skiplane Fly-in |
"downstate................................................................meeting Rex and Emily!"
I predict we'll be pulling in to Frankenmuth between 11:00 and 11:30
Rex
-- "fox5flyer" <fox5flyer(at)i-star.com> wrote:
--> Kitfox-List message posted by: "fox5flyer" <fox5flyer(at)i-star.com>
Deke
---- Original Message ----
Subject: Re: Kitfox-List: Re: Oshkosh Skiplane Fly-in
Date: Fri, 26 Jan 2007 22:35:03 -0500
| Quote: | --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
to the Red Barn as a landmark just north of the field...don't look
eh? : )
Lynn
> --> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
> I love Ski fly ins.
> to get back out.
> wheel on landing.
> it was.
> Fly safe !
> Dave
> ----- Original Message ----- From: "Lynn Matteson"
> To: <kitfox-list(at)matronics.com>
> Sent: Friday, January 26, 2007 6:07 PM
>> around, but they are still a go for tomorrow, as am I.
>> already spoiled.
>> Lynn
>> do not archive
>>> --> Kitfox-List message posted by: "kitfoxmike"
>>> kitfoxmike
>>> Do not archive
WebMail Express+ - http://www.i-star.com I================================================sp; - The Kitfox-List Email Forum -<= Archive Search & Download, 7-Day B================================================ - NEW MATRONICS WEB FORUMS&n====================================================
Posted: Sat Jan 27, 2007 6:33 am Post subject: Oshkosh Skiplane Fly-in |
Sorry Guys,
The message below was intended only for one person and I mistakenly hit "reply" to the entire list. I appologize.
Rex in Michigan
Rex
Deke
eh? : )
Lynn
> I love Ski fly ins.
> to get back out.
> wheel on landing.
> it was.
> Fly safe !
> Dave
>> already spoiled.
>> Lynn
>> do not archive
>>> kitfoxmike
>>> Do not archive
">http://www.matronics.com/Navigator?Kitfox-List
tronics.com
kitfoxmike
Posted: Sat Jan 27, 2007 7:26 am Post subject: Re: Oshkosh Skiplane Fly-in |
You might be in trouble flying into Canada. I think you have to have a passport when flying. I think that includes our little ones.
msm_9949(at)yahoo.com Guest
Posted: Sat Jan 27, 2007 7:34 am Post subject: Oshkosh Skiplane Fly-in |
Overnight accomodations also available here Lynn. No landing strip on site, but pick-up & delivery assured from Evart (9C8) 5 miles away.
fox5flyer <fox5flyer(at)i-star.com> wrote: [quote]--> Kitfox-List message posted by: "fox5flyer"
Deke
Michel
Posted: Sat Jan 27, 2007 8:42 am Post subject: Oshkosh Skiplane Fly-in |
On Jan 27, 2007, at 2:57 PM, fox5flyer wrote:
Yep, bon voyage, Lynn! I went flying today. A bit of snow here but it
will rain tomorrow. I can't be bothered to put my skis on ...yet.
Winter Norway is no longer what it used to be!
Michel
temco(at)telusplanet.net Guest
Posted: Sat Jan 27, 2007 10:36 am Post subject: Oshkosh Skiplane Fly-in |
You are right you might have trouble --- but the trouble will be in getting
back into the USA, as American Customs requires that you have a passport to
enter regardless whether you are an alien or US citizen.
Ted
DO NOT ARCHIVE
Float Flyr
Posted: Sat Jan 27, 2007 1:25 pm Post subject: Oshkosh Skiplane Fly-in |
Only if you are flying.... So far.
Noel
[quote] --
Kitfox III-A
Lynn Matteson
Posted: Mon Jan 29, 2007 12:55 pm Post subject: Oshkosh Skiplane Fly-in |
Thanks, Michel...I flew all the way over there for a good snow
landing and could have done almost without the skis...but the trip
was what it was all about, and seeing some other examples of skis.
But with only 4 planes there when I got there, there wasn't much to
choose from. : ) And thanks for the pictures of your skis, as they
helped me to build mine.
Lynn
On Jan 27, 2007, at 11:42 AM, Michel Verheughe wrote:
> Bon Voyage Lynn.
it will rain tomorrow. I can't be bothered to put my skis
on ...yet. Winter Norway is no longer what it used to be!
Michel
N369LM |
