occom
Posted: Sun Jan 28, 2007 4:19 am Post subject: Coverings (again) |
I have a friend who has been suggesting that I consider the Hipec system for recovering my wings. I have ordered his book and information. It appears to be a Canadian product. Has anyone got any experience??
dave
Posted: Sun Jan 28, 2007 4:49 am Post subject: Coverings (again) |
Dave, It is kinda like the arguement about to rib stitch or not.
You can even use other than aircraft paints if you prefer. Another arguement.
Then you can look at history of how many Kitfox alone have had fabric separate from the ribs with no stitching.
1.7 cecontite is about 7or 8 $ a yard in Canada -- how does this compare with HIPEC?
Dave
http://www.supercub.org/phpBB2/viewtopic.php?p=134061
http://www.airtalk.org/any-info-on-hipec-no-rib-stitching-vt17520.html
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
occom
Posted: Sun Jan 28, 2007 7:44 am Post subject: Coverings (again) |
The Hipec fellow uses Ceconite as the fabric, I think my 1992 Denney Mod IV was originally covered in something other than Polyfiber fabric. I'm not sure what the factory shipped then but it's light and very tightly woven. The link to Hipec is here. http://hipec.falconaravia.com/ Prices in $Can and $ US are there. It sure uses a lot less coats. As far as rib sitching, Polyfiber recommends it, but that seems to be due to an abundance of liability lawyers. Whatever process I use, I'll use the full process recommended.
occom
Posted: Sun Jan 28, 2007 7:47 am Post subject: Coverings (again) |
Just curious, I'm not aware that this has ever happenned on a 'fox let alone with any disasterous results. Do you know otherwise?
vadert(at)telusplanet.net Guest
Posted: Sun Jan 28, 2007 8:12 am Post subject: Coverings (again) |
Dave G.
I covered my Classic IV with the Hipec system. I modified it slightly though in that I used the Attach Gloo and the Sun Barrier to attach the fabric (2.7 oz.Ceconite) to the airframe. After that dried I scuff sanded the Sun Barrier to provide a tooth to the surface and painted the plane with 1.3 HG Imron one part water based polyurethane paint. I chose the Imron because it has very low volatile organic compounds (VOCs). It is also very resistant to fuel and covers fabric, metal or fibreglass. It also has a very glossy lustre. The Sun Barrier was very easy to apply; just use a foam roller to fill the weave of the fabric. Use the Sun Barrier in a well ventilated room as it contains isocyanates just like some of the other covering methods. When I sprayed the Imron I just used a particulate mask. The Imron dries to a nice glossy lustre in about twenty minutes. Since covering in August 2005 I have tacked up a piece of finished fabric and my fence outside and have not noticed any loss of lustre or any other bad effects. I am very satisfied with the results. No finish tapes. One coat of sun barrier, one coat of Imron. About six gallons of total product used.
Tim Vader
dave
Posted: Sun Jan 28, 2007 8:42 am Post subject: Coverings (again) |
Dave, yes that was my point .
I am not aware of and non stitched Kitfoxes with separation. Some choose to stitch and the other 90% seem to not have problems. I do in fact stand to be corrected though.
Dave
