kitfox69(at)earthlink.net Guest
Posted: Sat Jan 27, 2007 10:47 am Post subject: Ignition pickup |
Hi Mike,
No, it's Electromotive.com. The pickup I refered to is actually wedge shapped on the trigger wheel end, as opposed to the original pickup which had a flat end. It fits into the same NSI collar.
Michael Logan
Posted: Sun Jan 28, 2007 3:50 pm Post subject: Ignition pickup |
Floyd,
What is the part number for that pickup?
Does Jay have a website? What are the dimensions of the radiator he has?
Mike
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Floyd Johnson
Sent: Saturday, January 27, 2007 1:47 PM
Subject: Ignition pickup
Hi Mike,
_________________ Mike Logan
Fredericksburg, VA |
Posted: Mon Jan 29, 2007 9:18 am Post subject: Ignition Pickup |
Mike,
I did some measuring and investigation and came up with some answers.
The new radiator is 2 1/2 inches deep, as opposed to the 2 inches of the NSI design. In addition, this is a state of the art internal core, which provides much improved cooling. All other dimensions are equal, including where the inlet and outlet are
located. An important note: the hose from the outlet at the top of the radiator has to go to the pump, to work properly. You will need to make two simple brackets to mount it. Seeing as the radiator is deeper, the mounting holes are further back.
If you go with a new radiator, I can send you some photos of my mounting.
Now, the ignition pickup. Part number 250-72212 chisel point, 3/8 inch diameter. It will fit right in the NSI mount. It must be on the right side as you face the engine. The gap is .020>>.050. Mine is set .030 and performs OK. It is a chore to set the gap.
I drilled a 1/4 inch hole in the mount so I could slide a piece of shim stock in place to set the gap.
Jay does not have a website, but I'm going to copy him in on this. Give him a call if you have any questions because he is the expert, I'm only the grunt with the airplane. Regards, Floyd
Floyd Johnson
kitfox69(at)earthlink.net (kitfox69(at)earthlink.net)
EarthLink Revolves Around You.
n10pg(at)neo.rr.com Guest
Posted: Mon Jan 29, 2007 12:42 pm Post subject: Ignition Pickup |
Hi NSI Subaru drivers:
I made a fixture that I use to set the mag pickups to assure a .040" gap. If
you send your NSI "horse shoe" pickup holder and new sensors, I would be
happy to set the sensor for you. I can also furnish the sensor.
Peter Graichen
http:/home.neo.rr.com/n10pg/kitfox.htm
Sent: Monday, 29 January, 2007 12:15
To: Kitfox-List
Subject: Ignition Pickup
Mike,
The new radiator .........
Floyd Johnson
